    Connecting Multiple SERVO Driver Motor Systems with 6XD Board
    • marco_meierundefined
      marco_meier
      Hello everyone,
      I am currently working on connecting multiple SERVO driver motor systems to a 6XD board. Specifically, I am using the .
      https://www.omc-stepperonline.com/fr/kit-de-servomoteur-ac-serie-t6-1000w-3000rpm-3-18nm-encodeur-23bits-ip67-t6-rs1000h2a1-m23
      I have already read several forum posts on this topic and am now wondering what the best approach is. The external driver signal is output via the Driver0 - Driver5 connectors on the 6XD board with a nominal potential of 5V (min. 4.2V @ 20mA). However, the motor drivers from Stepperonline require a 24V signal.
      I have read that the signal can be converted using a level converter. Has anyone had experience with whether this solution works?
      Here are some level converters I found:
      https://www.amazon.com/dp/B07KQRGN32/ref=sspa_dk_detail_2?psc=1&pd_rd_i=B07KQRGN32&pd_rd_w=zKT8h&content-id=amzn1.sym.953c7d66-4120-4d22-a777-f19dbfa69309&pf_rd_p=953c7d66-4120-4d22-a777-f19dbfa69309&pf_rd_r=Y0YWNQG41C8RBCPRZTV1&pd_rd_wg=AcSRN&pd_rd_r=2a9eb409-5b9c-461b-b2ea-539412c81931&s=industrial&sp_csd=d2lkZ2V0TmFtZT1zcF9kZXRhaWwy
      https://de.aliexpress.com/item/33021062283.html?gatewayAdapt=glo2deu
      6XD to Yaskawa Breakout on GitHub https://github.com/SynchronicityLabs/6XD_to_Yaskawa_Breakout @Maestro
      Additionally, I am wondering if the Stepperonline drivers, along with the 6XD board (possibly with a CAN Bus expansion board), can also be controlled via CAN Bus.
      I look forward to your feedback and experiences!
      Thank you in advance
      Maestroundefined 1 Reply Last reply Reply Quote 0
      • Maestroundefined
        Maestro @marco_meier
        @marco_meier Those drives can use a 24v signal, however they will also accept 5v Step/Dir signals on the proper pins, so you can simply run 6XD 5v to CN1 pins 3 and 5, and Step- and Dir- to CN1 pins 4 and 6, respectively.
        All you really need to concern yourself with voltage-wise is the 24v enable signal, which the Duet team has confirmed the 6XD CANNOT sink on the EN- pin. The enable circuit on my breakout board would do what you need, and you could easily coble something like that together without making the whole board. Really, any simple relay/electronic-switch style setup that allows you to trigger a 24v connection with the 5v-tolerant EN- pin from the 6XD will accomplish what you need.
