    Variables not working as expeccted in M558?
    • Chrissundefined
      Chriss
      Hi *,
      I use some variables to control the settings in M558 under different conditions. The idea is to probe differently in different situations. Long story short, I saw that "F" does not extend the variables as I expect it should do.
      Here an example:
      echo global.probe_settingsF1
      60
      ok
      echo global.probe_settingsF2
      10
      ok
      M558 P8 H{global.probe_settingsH} A{global.probe_settingsA} S0.003 F{global.probe_settingsF1}:{global.probe_settingsF2} C"^121.io2.in" T8000 B0 R0
      I would expect "F60:10" now but I see "F60:60" when I query "M558":
      Z Probe 0: type 8, input pin 121.io2.in, min interval 2ms, dive heights 2.0,2.0mm, probe speeds 60,60mm/min, travel speed 8000mm/min, recovery time 0.00 sec, heaters normal, max taps 30, max diff 0.00
      Lets hardcode the 2nd F parameter to "33" while use the variable for the first one:
      M558 P8 H{global.probe_settingsH} A{global.probe_settingsA} S0.003 F{global.probe_settingsF1}:33 C"^121.io2.in" T8000 B0 R0
      ok
      m558
      Lets hardcode both:
      M558 P8 H{global.probe_settingsH} A{global.probe_settingsA} S0.003 F44:55 C"^121.io2.in" T8000 B0 R0
      ok
      m558
      Z Probe 0: type 8, input pin 121.io2.in, min interval 2ms, dive heights 2.0,2.0mm, probe speeds 44,55mm/min, travel speed 8000mm/min, recovery time 0.00 sec, heaters normal, max taps 30, max diff 0.00
      ok
      Lets use the variable for the 2nd F:
      M558 P8 H{global.probe_settingsH} A{global.probe_settingsA} S0.003 F44:{global.probe_settingsF2} C"^121.io2.in" T8000 B0 R0
      ok
      M558
      Z Probe 0: type 8, input pin 121.io2.in, min interval 2ms, dive heights 2.0,2.0mm, probe speeds 44,10mm/min, travel speed 8000mm/min, recovery time 0.00 sec, heaters normal, max taps 30, max diff 0.00
      ok
      Let us reverse the usage of the variables for fun:
      M558 P8 H{global.probe_settingsH} A{global.probe_settingsA} S0.003 F{global.probe_settingsF2}:{global.probe_settingsF1} C"^121.io2.in" T8000 B0 R0
      ok
      m558
      Z Probe 0: type 8, input pin 121.io2.in, min interval 2ms, dive heights 2.0,2.0mm, probe speeds 10,10mm/min, travel speed 8000mm/min, recovery time 0.00 sec, heaters normal, max taps 30, max diff 0.00
      ok
      You see what mean? M558 use the first variable for both "F" values if I use a variable at the first of the two values and it ignores the values behind the ":" whether it is a hardcoded value or a variable. But it works as expected if the value left of the ":" is hardcoded and not a variable.
      Is that a bug or do I do something wrong with the variables here?
      I tried to place both "F" parameters in a var as as string without success. (Which was not a surprise)
      global F="10:22"
      ok
      M558 P8 H{global.probe_settingsH} A{global.probe_settingsA} S0.003 F{global.F} C"^121.io2.in" T8000 B0 R0
      Error:  at column 78: M558: expected numeric operand
      Any ideas?
      Cheers, Chriss
        Can you share the results of M115 please?
        Chrissundefined 1 Reply Last reply Reply Quote 0
          dc42 administrators @Chriss
          @Chriss the syntax for using variables in GCode command parameters where the parameter takes multiple values changed in RRF 3.5. See https://docs.duet3d.com/en/User_manual/Reference/Gcode_meta_commands#use-of-expressions-within-gcode-commands for the correct syntax.
          • Chrissundefined
            Chriss @Phaedrux
            @Phaedrux said in Variables not working as expeccted in M558?:
            #FIRMWARE_NAME: RepRapFirmware for Duet 3 Mini 5+ FIRMWARE_VERSION: 3.5.2 ELECTRONICS: Duet 3 Mini5plus WiFi FIRMWARE_DATE: 2024-06-11 17:14:16
            Sorry, my bad. 😞 Let me see what David has pointed out.
            • Chrissundefined
              Chriss @dc42
              @dc42 Thanks... that makes sense that it is not working as expected than. 😄 And that explains the behaviour too. Let me get that together somehow.
              • Phaedruxundefined Phaedrux has marked this topic as solved
