    Software bundle 3.6.0-beta.1 now available
    Beta Firmware
    8
    17
    1.3k
      On behalf of the Duet3D team I am pleased to announce the release of firmware 3.6.0-beta.1. Users running Duets in standalone mode can download it from https://github.com/Duet3D/RepRapFirmware/releases/tag/3.6.0-beta.1. Users running with attached SBC can update from the unstable feed of the package server.
      RRF release notes: https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x-Beta#reprapfirmware-360-beta1
      DWC release notes: https://github.com/Duet3D/DuetWebControl/wiki/Changelog-DWC-3.x-Beta#version-360-beta1-changes-since-353
      DSF release notes: https://github.com/Duet3D/DuetSoftwareFramework/wiki/Changelog-DSF-3.x-Beta#version-360-beta1-changes-since-353
      Compared to firmware 3.5.3 the major feature in this release is the new input shaping algorithm. Additionally, support for communication with devices supporting Modbus RTU is provided on Duet 3 boards.
      If you encounter any issue with this release, please describe them in a new thread, including [3.6.0-beta.1] in the topic title.
      NeoDueundefined Kioliaundefined 2 Replies Last reply Reply Quote 3
      • DangerMouse88undefined
        DangerMouse88
        Is the mini 5+ going to be included not seeing a file for it
        Exerqtorundefined 1 Reply Last reply Reply Quote 2
        • Exerqtorundefined
          Exerqtor @DangerMouse88
          @DangerMouse88 I just noticed that too, suspect he forgot to upload it 😅
            dc42 administrators @Exerqtor
            @Exerqtor correct. I've just added it.
            • NeoDueundefined
              NeoDue @dc42
              @dc42 does the new input shaping algorithm also mean that something similar to the Klipper "minimum cruise ratio" (https://www.klipper3d.org/Kinematics.html#minimum-cruise-ratio ) is supported by RRF 3.6.0?
                dc42 administrators @NeoDue
                @NeoDue no we haven't implemented that yet, it's separate from input shaping.
                NeoDueundefined 1 Reply Last reply Reply Quote 0
                • edspedundefined
                  edsped
                  @dc42 I'm not sure what's changed between the last alpha and the current beta but the Jubilee is once again dropping tools even with the M400's...
                  edit: on a side note it primarily appears to happen after I cancel a print and it parks the tool. At this point I'm reverting to the alpha 5 as it's been pretty solid.
                  • edspedundefined
                    edsped
                    I didn't have an M400 command after the tool park in my cancel.g file so that may be the culprit. I'll add it and retry but it won't be until tomorrow.
                    • edspedundefined
                      edsped
                      A few prints in and it seems as if adding the M400 to cancel.g addressed the issue. I guess I haven't been cancelling prints on the alpha.. Otherwise all seems to be working as expected.
                      • NeoDueundefined
                        NeoDue @dc42
                        @dc42 said in Software bundle 3.6.0-beta.1 now available:
                        Thanks! Then I will wait until 3.6 is final.
                        • Notepadundefined
                          Notepad
                          Im tracking a possible bug (hard to determine if its hardware or firmware) relating to motor idle current.
                          Testing hardware is a E3D Roto
                          Current working theory is when pause.g is pressed and the motors go into the lower power idle state. the Extruder motor also goes to a lower amperage mode, however when resuming or manually extruding the motor does wake up and stays at a low power mode.
                          Once I'm back from the trade show I am on (1 week left) I can swap extruders to check different types to see if the behaviour is consistent or just a behaviour of the Roto
                          The real bamboo printer manufacturer
                          Kioliaundefined 1 Reply Last reply Reply Quote 0
                          • Kioliaundefined
                            Kiolia @Notepad
                            @Notepad I have run into something similar to this, but I can't reproduce it yet... detailed my experience at the bottom of the earlier 3.6.0 alpha build thread.
                            AWD 48V Duet 3 6HC+3HC Linear Kossel XL "CarbonShrike"
                            https://www.printables.com/@Kiolia | youtube.com/@jamespray
                            aka Colphaer (Discord) | aka the Deltavangelist | aka that one duct guy
                            • Kioliaundefined
                              Kiolia @dc42
                              [3.6.0-beta.1]
                              Did you get around to trying to reproduce Z axis clicking on linear delta with very slow, long-lasting moves? I'm still seeing this in the beta, albeit possibly somewhat reduced from the alpha.
                              • samlogan87undefined
                                samlogan87
                                Hey @dc42
                                I can't see anything in the release notes as to whether the new input shaping/3.6 release, has been released for the 1HCL boards or is it in development?
                                Sam
                                Custom Core-XY
                                  @samlogan87 yes it's implemented in 3.6beta1 on all expansion boards including 1HCL and M23CL motors.
                                  samlogan87undefined 1 Reply Last reply Reply Quote 0
                                    samlogan87 @dc42
                                    @dc42 awesome thank you. Will update tonight and give it a try
                                    Custom Core-XY
                                    • Notepadundefined
                                      Notepad
                                      Possible bug in 3.6.b1. Once a printer is Estop'ed the PanelDue sometimes doesn't reconnect and gets stuck in a connecting state. I have absolutely no idea how to gather data for this other than an observation + the behaviour is inconsistent.
                                      This may be related to another issue I am diagnosing (I am not sure its a RRF issue or just a user setup issue so I didn't mention it before) where the PanelDue connected to a D36HC w/ SBC seems to have random slow response times. Pressing a button can take up to 2 seconds before the press is registered/actioned, some other times is instant like normal. This behaviour is not present in any of my D2 machines that do not include an SBC
