    Software bundle 3.6.0-beta.1 now available
    Beta Firmware
    8
    17
    1.3k
    • Exerqtorundefined
      Exerqtor @DangerMouse88
      @DangerMouse88 I just noticed that too, suspect he forgot to upload it 😅
        dc42 administrators @Exerqtor
        @Exerqtor correct. I've just added it.
        • NeoDueundefined
          NeoDue @dc42
          @dc42 does the new input shaping algorithm also mean that something similar to the Klipper "minimum cruise ratio" (https://www.klipper3d.org/Kinematics.html#minimum-cruise-ratio ) is supported by RRF 3.6.0?
            dc42 administrators @NeoDue
            @NeoDue no we haven't implemented that yet, it's separate from input shaping.
            NeoDueundefined 1 Reply Last reply Reply Quote 0
            • edspedundefined
              edsped
              @dc42 I'm not sure what's changed between the last alpha and the current beta but the Jubilee is once again dropping tools even with the M400's...
              edit: on a side note it primarily appears to happen after I cancel a print and it parks the tool. At this point I'm reverting to the alpha 5 as it's been pretty solid.
              • edspedundefined
                edsped
                I didn't have an M400 command after the tool park in my cancel.g file so that may be the culprit. I'll add it and retry but it won't be until tomorrow.
                • edspedundefined
                  edsped
                  A few prints in and it seems as if adding the M400 to cancel.g addressed the issue. I guess I haven't been cancelling prints on the alpha.. Otherwise all seems to be working as expected.
                  • NeoDueundefined
                    NeoDue @dc42
                    @dc42 said in Software bundle 3.6.0-beta.1 now available:
                    Thanks! Then I will wait until 3.6 is final.
                    • Notepadundefined
                      Notepad
                      Im tracking a possible bug (hard to determine if its hardware or firmware) relating to motor idle current.
                      Testing hardware is a E3D Roto
                      Current working theory is when pause.g is pressed and the motors go into the lower power idle state. the Extruder motor also goes to a lower amperage mode, however when resuming or manually extruding the motor does wake up and stays at a low power mode.
                      Once I'm back from the trade show I am on (1 week left) I can swap extruders to check different types to see if the behaviour is consistent or just a behaviour of the Roto
                      The real bamboo printer manufacturer
                      Kioliaundefined 1 Reply Last reply Reply Quote 0
                      • Kioliaundefined
                        Kiolia @Notepad
                        @Notepad I have run into something similar to this, but I can't reproduce it yet... detailed my experience at the bottom of the earlier 3.6.0 alpha build thread.
                        AWD 48V Duet 3 6HC+3HC Linear Kossel XL "CarbonShrike"
                        https://www.printables.com/@Kiolia | youtube.com/@jamespray
                        aka Colphaer (Discord) | aka the Deltavangelist | aka that one duct guy
                        • Kioliaundefined
                          Kiolia @dc42
                          [3.6.0-beta.1]
                          Did you get around to trying to reproduce Z axis clicking on linear delta with very slow, long-lasting moves? I'm still seeing this in the beta, albeit possibly somewhat reduced from the alpha.
                          • samlogan87undefined
                            samlogan87
                            Hey @dc42
                            I can't see anything in the release notes as to whether the new input shaping/3.6 release, has been released for the 1HCL boards or is it in development?
                            Sam
                            Custom Core-XY
                              @samlogan87 yes it's implemented in 3.6beta1 on all expansion boards including 1HCL and M23CL motors.
                              samlogan87undefined 1 Reply Last reply Reply Quote 0
                                samlogan87 @dc42
                                @dc42 awesome thank you. Will update tonight and give it a try
                                Custom Core-XY
                                • Notepadundefined
                                  Notepad
                                  Possible bug in 3.6.b1. Once a printer is Estop'ed the PanelDue sometimes doesn't reconnect and gets stuck in a connecting state. I have absolutely no idea how to gather data for this other than an observation + the behaviour is inconsistent.
                                  This may be related to another issue I am diagnosing (I am not sure its a RRF issue or just a user setup issue so I didn't mention it before) where the PanelDue connected to a D36HC w/ SBC seems to have random slow response times. Pressing a button can take up to 2 seconds before the press is registered/actioned, some other times is instant like normal. This behaviour is not present in any of my D2 machines that do not include an SBC
