    Firmware 1.20 released
    Firmware installation
    20
    89
    14.2k
    • BMMalundefined
      BMMal
      I've been running for a few hours now with no significant problems. Only thing I can complain about is that since 1.20 went to RC, my WiFi issues are more prevalent again. A while back I was wondering if I was running too high of a step frequency due to the Step Errors and causing some kind of under-run. Never really figured anything out about that though or if it is at all related.
      [[language]]
      Used output buffers: 3 of 32 (15 max)
      RepRapFirmware for Duet WiFi version 1.20 running on Duet WiFi 1.0 + DueX5
      Board ID: 08D6M-91AST-L23S4-7JTD8-3S86K-1PX1K
      Static ram used: 15448
      Dynamic ram used: 99992
      Recycled dynamic ram: 3344
      Stack ram used: 1392 current, 8440 maximum
      Never used ram: 3848
      Last reset 03:59:41 ago, cause: software
      Last software reset at 2017-12-26 13:20, reason: User, spinning module GCodes, available RAM 3848 bytes (slot 0)
      Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0441f000, BFAR 0xe000ed38, SP 0xffffffff
      Error status: 2
      Free file entries: 8
      SD card longest block write time: 404.0ms
      MCU temperature: min 26.3, current 27.7, max 28.4
      Supply voltage: min 24.2, current 24.5, max 25.0, under voltage events: 0, over voltage events: 0
      Driver 0: ok, SG min/max 0/787
      Driver 1: ok, SG min/max 0/1023
      Driver 2: standstill, SG min/max 0/1023
      Driver 3: standstill, SG min/max 0/585
      Driver 5: ok, SG min/max 0/1023
      Driver 6: standstill, SG min/max 0/543
      Driver 7: standstill, SG min/max not available
      Expansion motor(s) stall indication: yes
      Date/time: 2017-12-26 17:24:08
      Slowest main loop (seconds): 0.407292; fastest: 0.000045
      MaxReps: 5, StepErrors: 12803, FreeDm: 164, MinFreeDm 150, MaxWait: 4260061081ms, Underruns: 0, 1
      Scheduled moves: 216447, completed moves: 216420
      Bed compensation in use: none
      Heater 0 is on, I-accum = 0.0
      Heater 3 is on, I-accum = 0.0
      Segments left: 1
      Stack records: 3 allocated, 0 in use
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is doing "G1 X252.578 Y56.169 E0.0484" in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      Network state is running
      WiFi firmware version 1.20
      WiFi MAC address a0:20:a6:16:e6:c6
      WiFi Vcc 3.26, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 16752
      WiFi IP address 10.0.0.115
      WiFi signal strength -31dBm, reconnections 0, sleep mode modem
      HTTP sessions: 1 of 8
      Socket states: 2 0 0 0 0 0 0 0
      Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
      Duet Ethernet - Most likely the most recent Edge firmware
      Duet X5
      7" Panel Due V2
      Cartesian, 4 Nozzles with Flex3Drives, Heated Chamber, Simple Switch Filament Sensing
      • Ak Ericundefined
        Ak Eric
        Have done a few prints now with 1.20 on a DuetEthernet/delta : No issues so far.
          @BMMal:
          Your MaxReps figure is low so there isn't a problem with the step rate. But I would like to investigate why you have so many step errors. Can you provide the Gcode file and your config.g file?
          • BMMalundefined
            BMMal
            @dc42:
            @BMMal:
            You can get the files from here: https://www.dropbox.com/sh/4er7llhg7vifkfu/AADv9KP6UQct_5WiclzfOFOia?dl=0
            Duet X5
            7" Panel Due V2
            • anglachelundefined
              anglachel
              Haven't upgraded my firmware yet (want to finish current project before I change anything on the printer) I was looking changes I need to make to my config…
              would it make more sense to start logging as custom g-code in slic3r, rather than in the config.g?
              For start gcode:
              M929 S0 ; stop any existing logs that might be running
              M929 P"[input_filename_base].log" S1	;Start logging
              ```and at the end
              M929 S0 ; Stop logging
                Thanks! I have reproduced the step errors, both on the bench and in the simulator. I have located the reason for the vast majority of the step errors, and fixed it. The step errors are benign and should not affect print quality. I am still getting a small number of step errors reported with a different cause, and I will investigate those today.
                I already found another bug that needs to be fixed in 1.20 (also present in 1.19) concerning filament sensor support, so I am planning a 1.20.1 release, which will also have the fixes for the step error reports.
                • Thomllamaundefined
                  Thomllama
                  OK then, I just today fired up my Duet Wifi on my CoreXY after many months of idle. Was mounted for a short time on m old i3 clone just for kicks. anyway, it's still running 1.8. what do I have to do to update? just get all those files? upload to SD card and then run the update like is in the Docs for 1.9? Honestly I tried the 1.9 update back then and it failed miserably. had to re set to 1.8.
                  Do want to update as right now the wifi won't connect every time I reboot or just fire it up for the day. I have to go and kick my computer's Wifi over the the Duet. do the 192.1.1…. then the window pops up asking for the wifi info.. select network and type in password and reboot and then it'll work,... till I have to reboot again and I'll have to go through the whole process once more. Ugg. anyway, it's late and I'm off to bed.. hoping tomorrow to be a bit better a day for it 😉
                    One way is to upload the new DuetWiFiFirmware.bin and DuetWiFiServer.bin files WITHOUT installing them (or copy them to the SD card on a PC). Also comment out the M552 S1 command in config.g. Then connect via USB and send M997 S0 to update the main firmware. You can watch the progress on PanelDue if you have one. After a minute you should be able to reconnect via USB, then send M997 S1 to update the WiFi firmware. Then follow the "getting connected" instructions for firmware 1.19 and later on the wiki.
                    • vhowardundefined
                      vhoward
                      I upgraded from 1.19 to 1.20. Now my BL Touch does not work correctly. It self tests fine, but when I home z, the probe does deploy, but now my printer tries to drive the nozzle through the heat bed. It does not stop.
                      If I down grade to 1.19 on the firmware, do I need to downgrade the wifi server also?
                        Thomllama
                        @dc42:
                        did exactly that.. Uploaded and told it not to install. Turned off the wifi, disconnected everything and brought over to computer -
                        plugged into USB, connect with Printrun(pronto face) type in M997 S0,.. keep getting errors.. Remove SD card and plug in direct to computer.. Can't drag and drop the file won't let me. ?? now what?
                          Thomllama
                          I seriously think my WiFi module is bad. this thing has been nothing but issues, drops connection. won't reconnect 1/2 the time with out a complete power down and restart and then I always had to go in and reconfigure the network info. Every single time. did everything you stated above ad it won't work. Now I can't even get the wifi to turn back on under 1.8. 😕
                            Thomllama
                            M552 S1
                            SENDING:M552 S1
                            WiFi module started
                            Error: Failed to initialise WiFi module, code -10
                            [ERROR] Error: Failed to initialise WiFi module, code -10
                            or,…
                            M552 S0
                            SENDING:M552 S0
                            WiFi module started
                              That error usually means that the main firmware and wifi firmware are out of step, i.e. one is pre-1.19 and the other is 1.19 or later. So use M115 to check that your main firmware is version 1.20; then use your PC to put a fresh copy of DuetWiFiServer.bin from the 1.20 release area of github into /sys on the SD card; put it in the Duet, start the Duet, connect via USB, and send M997 S1 to install it. If/when it reports success, try M552 S1 again.
                                Thomllama
                                seems to be working. 🙂 thanks… so far anyway!! AWESOme!
                                Connecting...
                                Printer is now online.
                                m115
                                SENDING:M115
                                FIRMWARE_NAME: RepRapFirmware for Duet WiFi FIRMWARE_VERSION: 1.20 ELECTRONICS: Duet WiFi 1.0 FIRMWARE_DATE: 2017-12-23
                                Disconnected.
                                Connecting...
                                M997 S1
                                SENDING:M997 S1
                                Trying to connect at 230400 baud:
                                success
                                Erasing 4096 bytes...
                                Erasing 233472 bytes...
                                Uploading file...
                                5% complete
                                10% complete
                                15% complete
                                20% complete
                                25% complete
                                30% complete
                                35% complete
                                40% complete
                                45% complete
                                50% complete
                                55% complete
                                60% complete
                                65% complete
                                70% complete
                                75% complete
                                80% complete
                                85% complete
                                90% complete
                                95% complete
                                Upload successful
                                M552 S1
                                SENDING:M552 S1
                                WiFi module started
                                Wifi module is connected to access point ####, IP address #######
                                  Thomllama
                                  so it is working… I recorded this so I could show it if it didn't work and see if I was doing something wrong or it was omething that you guys could see I was missing, or what ever... anyway.. I'll post it for kicks. 🙂
                                  https://youtu.be/ICiRkWutB2U
                                  • Captain_squndefined
                                    Captain_sq
                                    I had problems installing newer versions than 1.19 on my Duet 0.6 - it would not run.
                                    Can I use the 1.20 on this old board or is the board limited to 1.19?
                                    Custom made Kossel Mini - Duet WiFi / Modded Tronxy X5S - Duet WiFi / Prusa i3 MKIII
                                    Embedded systems designer, RC Pilot, maker and Gadget-o-holic
                                      Yes there is a build of 1.20 for the Duet 0.6 and 0.8.5.
                                        Captain_sq
                                        Great! Thanks.
                                          Captain_sq
                                          I'm still having problems I'm afraid. Cannot connect to my Duet 0.6 after upgrade to 1.20.1 (RepRapFirmware.bin). I can see that it boots up and runs for about 25 secs, then both ethernet connecor LEDs go out for 3-4 seconds and pattern repeats over an over.
                                          I've installed manually the DuetWebControl associated with this firmware release.
                                          Any ideas?
                                          Regards /Thom
                                            I tested 1.20 on a Duet 0.8.5 but not on a 0.6. You could try putting a minimal config.g file on the SD card, with the network parameters and not much else in it.
                                            Version 1.19.2 was tested on a Duet 0.6.
