    Firmware 1.20 released
    Firmware installation
    20
    89
    14.2k
    • peirofundefined
      peirof
      Hi…
      For cutiosity... Examples of printers of more 3 axis?
      Thanks
        @peirof:
        Hi…
        For curiosity... Examples of printers of more 3 axis?
        Thanks
        The ones I can remember:
        IDEX printers (dual X carriages) - 4 axes (RRF treats the second X carriage as an additional axis)
        Kulitorum's concrete printer - 4 axes (the 4th axis rotates the concrete extruder)
        Ian (deckingman's) printer with dual CoreXY gantries - 5 axes
        Various printers that split the (N) Z motors during homing, so they can be homed separately - 2 + (N) axes (one temporary axis per additional Z motor)
        Someone's (sorry, I can't remember who it was) printer with dual X, dual Y and dual Z axes - 6 axes
          Chrishamm has now released DWC 1.20, so I've updated the release to include it instead of DWC 1.20 RC3.
          • MarMedundefined
            MarMed
            So thankful for this release! Wait for thermostatic fans on power off, adjustable PWM frequency, and so much more!
            Thanks!
              deckingman
              @dc42:
              I am pleased to announce the release of firmware version 1.20 at https://github.com/dc42/RepRapFirmware/releases.
              • Fixed the sending of motor currents to DWC
              Confirmed fixed. Thanks.
              • Synapsisundefined
                Synapsis
                Just wanted to say that I updated with no problems very straight forward and reconnected to my network upstairs with noproblems
                and then reconnected to a different network downstairs and also here no problems. connects right away to the router every time for now.
                  @Synapsis:
                  Thanks for your feedback!
                  • BMMalundefined
                    BMMal
                    I've been running for a few hours now with no significant problems. Only thing I can complain about is that since 1.20 went to RC, my WiFi issues are more prevalent again. A while back I was wondering if I was running too high of a step frequency due to the Step Errors and causing some kind of under-run. Never really figured anything out about that though or if it is at all related.
                    [[language]]
                    Used output buffers: 3 of 32 (15 max)
                    RepRapFirmware for Duet WiFi version 1.20 running on Duet WiFi 1.0 + DueX5
                    Board ID: 08D6M-91AST-L23S4-7JTD8-3S86K-1PX1K
                    Static ram used: 15448
                    Dynamic ram used: 99992
                    Recycled dynamic ram: 3344
                    Stack ram used: 1392 current, 8440 maximum
                    Never used ram: 3848
                    Last reset 03:59:41 ago, cause: software
                    Last software reset at 2017-12-26 13:20, reason: User, spinning module GCodes, available RAM 3848 bytes (slot 0)
                    Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0441f000, BFAR 0xe000ed38, SP 0xffffffff
                    Error status: 2
                    Free file entries: 8
                    SD card longest block write time: 404.0ms
                    MCU temperature: min 26.3, current 27.7, max 28.4
                    Supply voltage: min 24.2, current 24.5, max 25.0, under voltage events: 0, over voltage events: 0
                    Driver 0: ok, SG min/max 0/787
                    Driver 1: ok, SG min/max 0/1023
                    Driver 2: standstill, SG min/max 0/1023
                    Driver 3: standstill, SG min/max 0/585
                    Driver 5: ok, SG min/max 0/1023
                    Driver 6: standstill, SG min/max 0/543
                    Driver 7: standstill, SG min/max not available
                    Expansion motor(s) stall indication: yes
                    Date/time: 2017-12-26 17:24:08
                    Slowest main loop (seconds): 0.407292; fastest: 0.000045
                    MaxReps: 5, StepErrors: 12803, FreeDm: 164, MinFreeDm 150, MaxWait: 4260061081ms, Underruns: 0, 1
                    Scheduled moves: 216447, completed moves: 216420
                    Bed compensation in use: none
                    Heater 0 is on, I-accum = 0.0
                    Heater 3 is on, I-accum = 0.0
                    Segments left: 1
                    Stack records: 3 allocated, 0 in use
                    Movement lock held by null
                    http is idle in state(s) 0
                    telnet is idle in state(s) 0
                    file is doing "G1 X252.578 Y56.169 E0.0484" in state(s) 0
                    serial is idle in state(s) 0
                    aux is idle in state(s) 0
                    daemon is idle in state(s) 0
                    queue is idle in state(s) 0
                    Code queue is empty.
                    Network state is running
                    WiFi firmware version 1.20
                    WiFi MAC address a0:20:a6:16:e6:c6
                    WiFi Vcc 3.26, reset reason Turned on by main processor
                    WiFi flash size 4194304, free heap 16752
                    WiFi IP address 10.0.0.115
                    WiFi signal strength -31dBm, reconnections 0, sleep mode modem
                    HTTP sessions: 1 of 8
                    Socket states: 2 0 0 0 0 0 0 0
                    Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                    Duet Ethernet - Most likely the most recent Edge firmware
                    Duet X5
                    7" Panel Due V2
                    Cartesian, 4 Nozzles with Flex3Drives, Heated Chamber, Simple Switch Filament Sensing
                    • Ak Ericundefined
                      Ak Eric
                      Have done a few prints now with 1.20 on a DuetEthernet/delta : No issues so far.
                        @BMMal:
                        Your MaxReps figure is low so there isn't a problem with the step rate. But I would like to investigate why you have so many step errors. Can you provide the Gcode file and your config.g file?
                        • BMMalundefined
                          BMMal
                          @dc42:
                          @BMMal:
                          You can get the files from here: https://www.dropbox.com/sh/4er7llhg7vifkfu/AADv9KP6UQct_5WiclzfOFOia?dl=0
                          Duet X5
                          7" Panel Due V2
                          • anglachelundefined
                            anglachel
                            Haven't upgraded my firmware yet (want to finish current project before I change anything on the printer) I was looking changes I need to make to my config…
                            would it make more sense to start logging as custom g-code in slic3r, rather than in the config.g?
                            For start gcode:
                            M929 S0 ; stop any existing logs that might be running
                            M929 P"[input_filename_base].log" S1	;Start logging
                            ```and at the end
                            M929 S0 ; Stop logging
                              Thanks! I have reproduced the step errors, both on the bench and in the simulator. I have located the reason for the vast majority of the step errors, and fixed it. The step errors are benign and should not affect print quality. I am still getting a small number of step errors reported with a different cause, and I will investigate those today.
                              I already found another bug that needs to be fixed in 1.20 (also present in 1.19) concerning filament sensor support, so I am planning a 1.20.1 release, which will also have the fixes for the step error reports.
                              • Thomllamaundefined
                                Thomllama
                                OK then, I just today fired up my Duet Wifi on my CoreXY after many months of idle. Was mounted for a short time on m old i3 clone just for kicks. anyway, it's still running 1.8. what do I have to do to update? just get all those files? upload to SD card and then run the update like is in the Docs for 1.9? Honestly I tried the 1.9 update back then and it failed miserably. had to re set to 1.8.
                                Do want to update as right now the wifi won't connect every time I reboot or just fire it up for the day. I have to go and kick my computer's Wifi over the the Duet. do the 192.1.1…. then the window pops up asking for the wifi info.. select network and type in password and reboot and then it'll work,... till I have to reboot again and I'll have to go through the whole process once more. Ugg. anyway, it's late and I'm off to bed.. hoping tomorrow to be a bit better a day for it 😉
                                  One way is to upload the new DuetWiFiFirmware.bin and DuetWiFiServer.bin files WITHOUT installing them (or copy them to the SD card on a PC). Also comment out the M552 S1 command in config.g. Then connect via USB and send M997 S0 to update the main firmware. You can watch the progress on PanelDue if you have one. After a minute you should be able to reconnect via USB, then send M997 S1 to update the WiFi firmware. Then follow the "getting connected" instructions for firmware 1.19 and later on the wiki.
                                  • vhowardundefined
                                    vhoward
                                    I upgraded from 1.19 to 1.20. Now my BL Touch does not work correctly. It self tests fine, but when I home z, the probe does deploy, but now my printer tries to drive the nozzle through the heat bed. It does not stop.
                                    If I down grade to 1.19 on the firmware, do I need to downgrade the wifi server also?
                                      Thomllama
                                      @dc42:
                                      did exactly that.. Uploaded and told it not to install. Turned off the wifi, disconnected everything and brought over to computer -
                                      plugged into USB, connect with Printrun(pronto face) type in M997 S0,.. keep getting errors.. Remove SD card and plug in direct to computer.. Can't drag and drop the file won't let me. ?? now what?
                                        Thomllama
                                        I seriously think my WiFi module is bad. this thing has been nothing but issues, drops connection. won't reconnect 1/2 the time with out a complete power down and restart and then I always had to go in and reconfigure the network info. Every single time. did everything you stated above ad it won't work. Now I can't even get the wifi to turn back on under 1.8. 😕
                                          Thomllama
                                          M552 S1
                                          SENDING:M552 S1
                                          WiFi module started
                                          Error: Failed to initialise WiFi module, code -10
                                          [ERROR] Error: Failed to initialise WiFi module, code -10
                                          or,…
                                          M552 S0
                                          SENDING:M552 S0
                                          WiFi module started
                                            That error usually means that the main firmware and wifi firmware are out of step, i.e. one is pre-1.19 and the other is 1.19 or later. So use M115 to check that your main firmware is version 1.20; then use your PC to put a fresh copy of DuetWiFiServer.bin from the 1.20 release area of github into /sys on the SD card; put it in the Duet, start the Duet, connect via USB, and send M997 S1 to install it. If/when it reports success, try M552 S1 again.
