    Define area for Mesh Compension Question
    • Theboz1419undefined
      Theboz1419
      When it ask for my bed area, I put the following
      X=0
      X=170
      Y=10
      Y=230
      X spacing= 10
      Y spacing= 10
      For some reason it will not start at Y10, it will go to Y28 and start probing.
      When I home, it will show Y-2.0, so I know I have to fix that. Should it not still start probing at Y=8.
      Theboz1419undefined 1 Reply Last reply Reply Quote 0
        Theboz1419 @Theboz1419
        So, I changed Home so that it reports the it's X0 Y0, when I home.
        I added
        M557 X0:170 Y20:220 to the Config.g file
        But it still will go to
        Y39 and start the probing, it won't start at Y20.
          For some reason when I put
          Y20:220
          It will start at Y39 and when it will continue to Y239.
          So it's offsets
          How do I fix this issue
          • oliofundefined
            oliof @Theboz1419
            @Theboz1419 it does apply the probe offset to the position
              Theboz1419 @oliof
              @oliof said in Define area for Mesh Compension Question:
              Where is this probe offset? how to change it. It only applies to Y and not X or Z
              • oliofundefined
                oliof @Theboz1419
                @Theboz1419 its part if the G31 probe definition
                See also
                https://docs.duet3d.com/User_manual/Reference/Gcodes#g31-set-or-report-current-probe-status
                https://docs.duet3d.com/en/User_manual/Tuning/Defining_tool_and_Z_probe_offsets
                  Theboz1419 @oliof
                  @oliof Thank you. Yeah for some reason I have
                  G31 X0 Y-21 Z0
                  I have not clicked on the links in your last post, but I believe G31 to be the offset of the z-probe.
                  When I first installed the Duet on my Makergear M2 I had to print a mount for the Probe and I did have the offset on the Y axis. My new print I have it on the X axis. Now, I understand, thank you very much.
                  • Phaedruxundefined Phaedrux has marked this topic as solved
