    Motors are not moving
    231
    • msugarundefined
      msugar
      I have a Duet 2 and a Duex5 in a 3 axis machine and its been working perfectly fine for the past year until yesterday. I can not seem to move the machine in any direction. It seems unlikely that all three motors have stopped working at the same time. I read some of the other forums with similar issues and did some basic trouble shooting based on some of the responses. I entered some commands that can be seen below M906, M122, M913, and M584. I also moved the gantry to satisfy the homing routine and tried to send a command to force move it G91 G1 S2 X10 F1000. There was still no movement.
      How can I tell if the drives on the board are bad?
      I also attached my config file at the bottom
      In the diagnostics there was one line that stood out to me "Movement lock held by null". Could this be the problem?
      9:32:36 AM M584
      Driver assignments: X0 Y1 Z2 E3:4:5:6:7:8:9, 3 axes visible
      9:32:24 AM  M913
      Motor current % of normal - X:100, Y:100, Z:100, E: 100 : 100: 100: 100 : 100: 100: 100
      9:32:01 AM M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later + DueX5
      Board ID: 08DLM-996AL-K65SW-6JKD8-3S06L-9U7QZ
      Used output buffers: 3 of 24 (8 max)
      Static ram: 25712
      Dynamic ram: 93580 of which 484 recycled
      Exception stack ram used: 544
      Never used ram: 10752
      Tasks: NETWORK(ready,628) HEAT(blocked,1232) DUEX(suspended,160) MAIN(running,3736) IDLE(ready,160)
      Owned mutexes:
      Last reset 00:25:49 ago, cause: power up
      Last software reset at 2024-10-22 14:04, reason: User, spinning module GCodes, available RAM 10800 bytes (slot 1)
      Error status: 0
      Free file entries: 10
      MCU temperature: min 27.0, current 40.7, max 40.9
      Supply voltage: min 24.1, current 24.2, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: ok, SG min/max 0/0
      Driver 1: ok, SG min/max 0/0
      Driver 2: ok, SG min/max 0/0
      Driver 3: ok, SG min/max not available
      Driver 4: ok, SG min/max not available
      Driver 5: ok, SG min/max not available
      Driver 6: ok, SG min/max not available
      Driver 7: ok, SG min/max not available
      Driver 8: ok, SG min/max not available
      Driver 9: ok, SG min/max not available
      Date/time: 2024-10-23 09:32:00
      Slowest loop: 18.27ms; fastest: 0.07ms
      Hiccups: 0, FreeDm: 160, MinFreeDm: 156, MaxWait: 87765ms
      === DDARing ===
      Scheduled moves: 11, completed moves: 11, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
      Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1
      Segments left: 0
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 69.22ms; fastest: 0.00ms
      HTTP sessions: 1 of 8
      - WiFi -
      Network state is running
      WiFi module is providing access point
      WiFi firmware version 1.23
      WiFi MAC address e2:98:06:a4:3a:77
      WiFi Vcc 3.38, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 24840
      WiFi IP address 11.22.33.44
      Connected clients 1
      9:31:53 AM  M906
      Motor current (mA) - X:1600, Y:1600, Z:1600, E:0:0:0:0:0:0:0, idle factor 30%
      CONFIG:
      ;Configuration file for Duet WiFi (firmware version 2.05.1)
      ;Sigma Z1024
      ;Version	1.06	12/27/2022
      ;__________________________________________________________________________________________
      ;__________DISABLE ALL FANS__________
      M106 P0 I-1
      M106 P1 I-1
      M106 P2 I-1
      M106 P3 I-1
      M106 P4 I-1
      M106 P5 I-1
      M106 P6 I-1
      M106 P7 I-1
      ;__________TURN OFF ALL FAN OUTPUTS__________
      M42 P20 S0
      M42 P21 S0
      M42 P22 S0
      M42 P23 S0
      M42 P24 S0
      M42 P25 S0
      M42 P26 S0
      M42 P27 S0
      ;__________DISABLE ALL HEATERS__________
      M307 H0 A-1 C-1 D-1
      M307 H1 A-1 C-1 D-1
      M307 H2 A-1 C-1 D-1
      M307 H3 A-1 C-1 D-1
      M307 H4 A-1 C-1 D-1
      M307 H5 A-1 C-1 D-1
      M307 H6 A-1 C-1 D-1
      M307 H7 A-1 C-1 D-1
      ;__________TURN OFF ALL HEATER OUTPUTS__________
      M42 P0 S0
      M42 P1 S0
      M42 P2 S0
      M42 P3 S0
      M42 P4 S0
      M42 P5 S0
      M42 P6 S0
      M42 P7 S0
      M42 P1 S1				;TURN WHITE LIGHT ON
      ;__________General preferences__________
      G90   				; Send absolute coordinates...
      M83   				; ...but relative extruder moves
      M555 P1 				; SET FIRMWARE COMPATABILITY TO REPRAP
      M669 K1 X-1: -1:0:0 Y1:-1 :0:0 Z0:0:1:0 U0:0:0:1				;Select CoreXY mode
      ;__________DEVICE NAME__________
      M550 P"SONOTEK Z1024"				; SET DEVICE NAME
      ;__________Network__________
      M552 S0				;WIFI ON
      G4 S1				;WAIT 1 SECOND
      M552 S2				;ENABLE NETWORK AS HOST
      ;M552 S1                   				;ENABLE NETWORK AS CLIENT
      ; __________Drives__________
      M569 P0 S1				;Drive 0 goes forwards
      M569 P1 S1				;Drive 1 goes forwards
      M569 P2 S0				;Drive 2 goes backwards
      M92 X80 Y80 Z414.4				;SET STEPS PER MM 16X MICOR STEPS
      M350 X16 Y16 Z16 I1				;SETP MICRO STEPPING
      M566 X1000 Y1000 Z2000				;(jerk) Set maximum instantaneous speed changes (mm/min)
      M203 X18000 Y18000 Z6000				;Set maximum speeds (mm/min)
      M201 X1500 Y1500 Z1500				;Set max accelerations (mm/s^2)
      M906 X1600 Y1600 Z1600 I30				;Set motor currents (mA) and motor idle factor in per cent
      M84 S5				;Set idle timeout
      ; __________Axis Limits__________
      M208 X0 Y0 Z40 S1				;Set axis minima
      M208 X330 Y300 Z105 S0				;Set axis maxima
      ; __________Endstops__________
      M574 X2 Y2 Z2 S1				;Set active high endstops
      ; __________Tools__________
      M563 P0 S"TOOL 0" D0				;DEFINE TOOL 0
      G10 P0 X0 Y0 Z0				;SET TOOL 0 AXIS OFFSET
      ;__________BED__________
      M140 H-1				;DISABLE BED HEAT
      ;__________ESTOP I/O__________
      M581 E0 T0 S1 C0				;WHEN DRIVE 0 HOME SENSOR IF LOW EXECUTE E-STOP
      ;__________DOOR I/O__________
      M581 E1 T1 S1 C0				;WHEN DRIVE 6 HOME SENSOR IS LOW EXECUTE PAUSE
      M582 T1				;CHECK PAUSE TRIGGER
      ;__________EXHAUST CHECK__________
      M581 E2 T2 S1 C0				;CHECK EXHAUST SWITCH AT ALL TIME IF OPEN RUNTRIGGER2.G
      M582 T2				;CHECK EXHAUST TRIGGER
      ;__________ENABLE COLD EXTRUDE__________
      M302 P1				;ALLOW COLD EXTRUDE
      ;__________ALARMS__________
      M581 E3 T3 S1 C1				;GENERATOR ALARM 1
      ;M581 E4 T4 S1 C1				;GENERATOR ALARM 2
        droftarts administrators @msugar
        @msugar That sounds more like the 7.5A fuse has blown that supplies power to the stepper motor drivers and heaters. You should be able to pull it out and check it visually.
        The "Movement lock held by null" message is normal, it just means movement is not locked.
        msugarundefined 1 Reply Last reply Reply Quote 0
        • msugarundefined
          msugar @droftarts
          @droftarts I checked all 4 fuses with a multimeter and was able to get continuity across them.
            @msugar While it is possible that something on the board has failed, I would think you wouldn't be able to connect via DWC, or there would be more indication in the M122 report. So I think there is something else that is causing the problem, and my best guess would be a wiring or switch failure.
            You have 4 triggers set up in your config.g, for E-stop, door, exhaust and alarm. It's possible one of these is triggered (failed microswitch, faulty wiring, etc) and stopping the motors moving. Try disconnecting them one at a time, or commenting them out of config.g.
            • msugarundefined
              msugar @droftarts
              @droftarts I tried disconnecting them one at a time and I also tried commenting them out of the config.g and still nothing worked.
              I pressed the reset button on the board and it was working. When I power cycled the board, it stopped working. I pressed the reset button again and that didn't work.
                Can you send M98 P"config.g" and report any errors?
                Has anything changed recently?
                Do you get any errors when you attempt to home the printer after startup?
                • msugarundefined
                  msugar @Phaedrux
                  @Phaedrux When I send that command I immediately lose connection. The only way for me to regain connection is if I turn the machine off and on.
                  Nothing has changed recently and I don't get any errors when I attempt to home the printer. I have to physically move the gantry to satisfy the homing sensors.
                    Can you move the motors to different drivers, change the config, and test again?
                    Your firmware is pretty ancient at this point. There may be more useful error messages in newer firmware. If there were errors witht he drivers I would expect them to say something.
