BLTouch alternative for hotbed with magnets
For me, it is definitely the magnet. The BLTouch measures 4 positions perfectly. Then the magnet comes and the pin is not retracted and flashes blue and red. There are also neodymium magnets which are embedded in the plate from below.
@jensus11 yes BLTouch is affected by magnetic fields. My comment was about inductive sensors.
ok. I'll order an inductive one and try it out and then report back.
Unfortunately, I have a problem with my Keenovo heating pad. I've just installed it. When I want to heat the bed to 60 degrees, everything is quiet up to 55 degrees. From 55 degrees onwards the heating pad makes noise. A humming noise that only stops when it's turned off.
Do you have any ideas? The heating pad is new.
@jensus11 the humming sound is most likely caused by the PWM being reduced as the temperature nears the target. It's unlikely that you will be able to get rid of it completely (other than by using a different type of bed heater) but you may be able to shift it to a less annoying pitch using the M950 F parameter.
That sounds good, what I have to change it?
M307 H0 R0.475 K0.931:0.000 D7.84 E1.35 S1.00 B0 M308 S0 P"e0temp" Y"thermistor" T100000 B3950 C7.06e-8 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bed" T0 ; create bed heater output on bedheat and map it to sensor 0 M140 H0 ; map heated bed to heater 0 M143 H0 S100 ; set temperature limit for heater 0 to 100C
@jensus11 add the
FQ parameter to the M950 command. Assuming it's a DC heater, try e.g. Q10, Q30, Q100. -
I want to test the F25 and became this message.
Fehler in Startdatei macro Zeile 69: exactly one of EFHJPSR must be given M950 H0 C"bed" T0 F25
@jensus11 Use the Q parameter for PWM frequency. See https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m950-create-heater-fan-spindle-led-strip-or-gpioservo-pin
@jensus11 Q50 is fine. You will probably hear a slight buzz.
I haven't bought an inductive sensor yet. I can't find one, they're sold out everywhere.But an idea is, of it is possible to define measuring points for the BLTouch so that I can find the position of the magnet and measure there and use this for the heightmap.
@jensus11 you can define points in the mesh for the BLTouch to avoid, see the notes on G29 S4 here: https://docs.duet3d.com/User_manual/Reference/Gcodes#notes-8
I have been using a bltouch with a magnetic bed for years with no issues. did you get it figured out?
In my opinion your best bet is to replace that sheet of magnets with 3M flexible magnetic self-adhesive sheet.
I've used that with all sorts of Z probes and they seem to work just fine.
I used to be a fan of BuildTak until the went with a sheet of little magnets - I've moved on from them.
