    BLTouch alternative for hotbed with magnets
    545
    • jensus11undefined
      jensus11
      I want to test the F25 and became this message.
      Fehler in Startdatei macro Zeile 69: exactly one of EFHJPSR must be given
      M950 H0 C"bed" T0 F25
        droftarts administrators @jensus11
        @jensus11 Use the Q parameter for PWM frequency. See https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m950-create-heater-fan-spindle-led-strip-or-gpioservo-pin
        • jensus11undefined
          jensus11
          I'm using this external mosfet. If I use a different one, will the noise go away?
          With Q50 the annoying sound is almost silent. Can I use it or will something break?
            dc42 administrators @jensus11
            @jensus11 Q50 is fine. You will probably hear a slight buzz.
            • jensus11undefined
              jensus11 @dc42
              I haven't bought an inductive sensor yet. I can't find one, they're sold out everywhere.
              But an idea is, of it is possible to define measuring points for the BLTouch so that I can find the position of the magnet and measure there and use this for the heightmap.
                @jensus11 you can define points in the mesh for the BLTouch to avoid, see the notes on G29 S4 here: https://docs.duet3d.com/User_manual/Reference/Gcodes#notes-8
                jensus11undefined 1 Reply Last reply Reply Quote 0
                • jensus11undefined
                  jensus11 @droftarts
                  I have defined the mesh point in the probePoint.csv file.
                  But the result looks not good. I think the magnets are so strong and interfere with the BLTouch when measuring.
                  So on, I need an inductive sensor.
                  • jensus11undefined
                    jensus11
                    I have now installed an inductive sensor. Unfortunately it doesn't work that way either.
                    The measurement stops above a magnet and this message appears.
                    Error: M280: Probe already triggered before probing move started.
                    What can I do?
                    troydemingundefined 1 Reply Last reply Reply Quote 0
                    • troydemingundefined
                      troydeming @jensus11
                      I have been using a bltouch with a magnetic bed for years with no issues. did you get it figured out?
                      • fcwiltundefined
                        fcwilt @jensus11
                        @jensus11
                        In my opinion your best bet is to replace that sheet of magnets with 3M flexible magnetic self-adhesive sheet.
                        I've used that with all sorts of Z probes and they seem to work just fine.
                        I used to be a fan of BuildTak until the went with a sheet of little magnets - I've moved on from them.
