    Layer count way off
    Duet Web Control
    1.4k
    • DaveAundefined
      DaveA
      I think this started with 3.6 but I'm not absolutely sure. I have a simple .stl of a 1mm thick spacer created via openscad. It is sliced by Simplyfy3d. In both of these apps the layer count is displayed correctly as 5 .2mm layers. When I bring the .gcode into DWC 3.6 beta2 it shows that there are 4000 layers. It prints correctly but seeing printing 3 of 4000 seem a bit weird.
      I'm including the .gcode file sliced for my delta printer if anyone wants to look at it. Thanks.
      ReservoirSpacer-1mm.gcode
      • oliofundefined
        oliof @DaveA
        @DaveA do you have a stop.g or end macro that lifts the print head?
        DaveAundefined 1 Reply Last reply Reply Quote 0
        • DaveAundefined
          DaveA @oliof
          @oliof No stop.g file and no end macro. What I do have is the following from Simplify3d at the end of a print.
          G1 E-.5 ; retract filament
          G28 ; home all axes
          M104 S0 ; turn off extruder heater
          M140 S0 ; turn off bed heater
          M106 P0 S0; turn off fan
          Should I have a stop.g?
          • oliofundefined
            oliof @DaveA
            @DaveA no, stop.g is optional. I would have expected some end gcode moving the print head away from the print, that final move usually throws off the layer line computation (its filtered out when there is a comment like ; E... behind the final Z move). But that doesn't seem to happen in your gcode file so I wondered if other sources existed worth checking.
            • DaveAundefined
              DaveA @oliof
              @oliof As this is on a delta I just use the G28 to move the effector up to the max height.
              DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
              • Phaedruxundefined Phaedrux moved this topic from General Discussion
                Can you roll back to 3.5.4 to confirm it parses correctly there?
                • DIY-O-Sphereundefined
                  DIY-O-Sphere @DaveA
                  @DaveA
                  Maybe set the custom end G-code as described here
                  https://forum.duet3d.com/post/314534
                  (UTC+1)
                  • DaveAundefined
                    DaveA @Phaedrux
                    @Phaedrux Bingo! I reverted back to 3.5.4 and the Jobs list shows the file as 1mm high. I deleted the file and reinstalled 3.6.0-2. I reloaded the file and the height is displayed with a object height of 800mm.
                    Edit to add that 3.6.0-1 appears to display the height correctly so beta 2 has the fault.
                    dc42undefined 2 Replies Last reply Reply Quote 0
                      dc42 administrators @DaveA
                      @DaveA this is a bug in RRF, which is reporting object height 800mm and 4000 layers to DWC. I am looking into it.
                      m36 "1732895968432-reservoirspacer-1mm.gcode"
                          "err": 0,
                          "fileName": "1732895968432-reservoirspacer-1mm.gcode",
                          "size": 100995,
                          "lastModified": "2024-12-01T08:49:22",
                          "height": 800,
                          "layerHeight": 0.2,
                          "numLayers": 4000,
                          "filament": [
                              824.1
                          "thumbnails": [],
                          "generatedBy": "Simplify3D(R) Version 4.1.2"
                        @DaveA this is now fixed in time for the next 3.6 beta release. Thank you for reporting it.
                            "err": 0,
                            "size": 100995,
                            "height": 1,
                            "layerHeight": 0.2,
                            "numLayers": 5,
                            "filament": [
                                824.1
                            "thumbnails": [],
