    RRF 3.6.0-beta2+4 | Error: Movement halted... error code 7...
    Beta Firmware
    • Argoundefined
      Argo
      I printed about 30h or so with RRF 3.6.0-beta2+4 without issues but just now I got this error:
      Error: Movement halted because a step timing error occured on drive 2 (code 7). Please reset the controller.
      Drive 2 is my left rear Z motor.
      config.g:
      G4 S1        ; wait 1s for expansion boards to start
      G90                                         ; Send absolute coordinates...
      M83                                         ; ...but relative extruder moves
      M550 P"Walross"                        	; Set machine name
      M552 S1                                     	; Enable network
      ;*** Access point is configured manually via M587
      M586 P0 S1                                  ; Enable HTTP
      M586 P1 S1                                  ; Disable FTP
      M586 P2 S1                                  ; Disable Telnet
      M575 P1 S1 B57600							; Panel Due
      ; Printer geometry
      M669 K1                	                    ; Select CoreXY mode
      M208 X0:290 Y-3:300 Z-0.2:270              ; Axis Limits
      M564 H0							            ; allow unhomed movement
      ;------- drives from top---------------------------------------------------
      ;  B -------+------ A
      ;   | P.02 | P.03 |
      ;   -------+-------  Z-Drives
      ;   | P0.1 | P0.4 |
      ;        Front
      ; Drive Mappings
      M569 P121.0 S0 D2                             ; Drive 0: E Axis
      M569 P0.1 S1 D2                             ; Drive 1: Z-LeftFront Axis
      M569 P0.2 S0 D2                             ; Drive 2: Z-LeftRear Axis
      M569 P0.3 S1 D2                             ; Drive 3: Z-RightRear Axis
      M569 P0.4 S0 D2                             ; Drive 4: Z-RightFront Axis
      M569 P0.5 S1 D2                             ; Drive 5: Expansion: B motor (X-axis)
      M569 P0.6 S0 D2                             ; Drive 6: Expansion: A motor (Y-axis)
      ; Motor remapping for dual Z and axis Limits
      M584 X5 Y6 Z1:2:3:4 E121.0                              ; Motor mapping
      M671 X-60:-60:360:360 Y-10:370:370:-10 S20	        ; Z leadscrews positions Left Front - Let Rear - Right Rear - Right Front
      ; Microstepping and Speed
      M350 X32 Y32 E16 Z32 I1                     ; Configure microstepping with interpolation
      M92 X160.00 Y160.00 Z800.00 E682.00         ; Set steps per mm	1.8 motors
      ; Speeds, Acceleration and Jerk
      M566 X300.00 Y300.00 Z25.00 E600.00 P1          ; Set maximum instantaneous speed changes (mm/min)
      M203 X18000.00 Y18000.00 Z900.00 E7200.00       ; Set maximum speeds (mm/min) ; SpreadCycle
      M201 X5000.00 Y5000.00 Z1000.00 E3000.00        ; Set accelerations (mm/s^2) ; SpreadCycle
      ; Motor currents
      M906 X1250.00 Y1250.00 Z1100.00 E1200.00 I50        ; Set motor currents (mA) and motor idle factor in percent
      M84 S30                                            ; Set idle timeout
      ; Endstops for each Axis
      M574 X2 S1 P"io1.in" 					 	; Set X endstop controlled by switch
      M574 Y2 S1 P"io2.in"                      	; Set Y endstop controlled by switch
      M574 Z1 S2                                  ; Set endstops controlled by probe "OLD" VINDA
      ;M574 Z1 S1 P"io6.in"						; Z endstop switch
      ; Stallgaurd Sensitivy (maybe use to pause print after crash)
      M915 X S2 F0 H200 R0		                ; Set X axis Sensitivity  1.8 motors
      M915 Y S2 F0 H200 R0		                ; Set y axis Sensitivity  1.8 motors
      ; Input Shaper and Accelerometer
      M955 P121.0 I05 ;Accelerometer
      M593 P"zvdd" F50.7 S0.12
      M558 P8 C"121.io2.in" I1 H1.5 F350:300 T12000 A500 S0.0025	; VINDA
      ; Mesh Grid
      M557 X5:260 Y30:250 P7                         ;
      ; Z Probe Offset (Probe behind Afterburner)
      G31 P1000 X0 Y25 Z0.585		; VINDA - 3DSWay Textured   0.4 nozzle
      ;G31 P1000 X0 Y25 Z0.580		; VINDA - 3DSWay Textured   0.4 nozzle
      ; Filament Runout sensor
      ;M591 D0 P3 L25.95 E3 R1:900 C"121.io1.in" S1		 		; Filament Sensor
      ; Heatbed Heaters and Thermistor Bed
      M308 S0 P"temp0" Y"thermistor" T100000 B4725 C7.060000e-8       ; Heatbed Thermistor
      M950 H0 C"out0" T0 Q10					                        ; Creates Bed Heater (SSR)
      M307 H0 R0.889 K0.762:0.000 D3.02 E1.35 S0.6 B0
      M140 H0										                    ; Bed uses Heater 0
      M143 H0 S116                                                    ; Set temperature limit for heater 0 to 115C Bed
      ; HotEnd Heaters and Thermistor HotEnd
      M308 S1 P"121.temp0" Y"thermistor" T100000 B4725 C7.06e-8     	; define E0 temperature sensor
      M950 H1 C"121.out0" T1 Q100					                            ; Create HotEnd Heater
      M307 H1 R4.568 K0.683:0.000 D4.04 E1.35 S1.00 B0 V24.4				; PID as heater
      M143 H1 S295                                                    	; Set temperature limit for heater 1 to 285C HotEnd
      M302 S15 R15														; min extrusion (cold extrusion) temp
      ; Fans Hotend + Part
      M950 F3 C"121.out1" Q100				; Creates HOTEND Fan
      M106 P3 T65 L1.0 X1.0 H1                 ; HOTEND Fan Settings
      M950 F0 C"121.out2" Q100				; Creates PARTS COOLING FAN
      M106 P0 H-1                         ; Parts Cooling Fan
      ; Fans Electronic compartment & Exhaust
      M950 F1 C"out3" Q100				    ; Creates Case Fan 1
      M106 P1 T40 S170 L170 X170 H0                 ; Case Fan 1 Settings
      M950 F2 C"out4" Q100				    ; Creates Case Fan 2
      M106 P2 T40 S170 L170 X170  H0                  ; Case Fan 2 Settings
      M950 F5 C"out5" Q100				    ; Creates Exhaust Fan
      M106 P5 T82 S150 L150 X150 H0                  ; Exhaust fan
      ; Chamber Thermistor
      M308 S3 P"temp1" A"Chamber" Y"thermistor" T100000 B4725 C7.060000e-8     	; define chamber sensor
      M563 P0 D0 H1 F0                            ; Define tool 0
      G10 P0 X0 Y0 Z0                             ; Set tool 0 axis offsets
      G10 P0 R0 S0                                ; Set initial tool 0 active and standby temperatures to 0C
      dc42undefined T3P3Tonyundefined 3 Replies Last reply Reply Quote 0
        dc42 administrators @Argo
        @Argo thanks for reporting this. Please test again with beta 3 when we release it.
          T3P3Tony administrators @Argo
          @Argo please could you test if this is resolved in 3.6beta3. test builds are available here:
          https://www.dropbox.com/scl/fo/22qkmz3oqxo2jb97l7716/AMVS8V_burccxcC5HWIfwEk?rlkey=v5vi2k9q1qjqviq97otkjqn1g&dl=0. Please try them on your machine(s) if you can.
          Release notes are at https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x-Beta#reprapfirmware-360-beta3-in-preparation.
            T3P3Tony administrators @T3P3Tony
            @Argo Beta 3 is now released:
            https://github.com/Duet3D/RepRapFirmware/releases/tag/3.6.0-beta.3
              @Argo Please can you see if you still get these in beta4. dc42 has added extra debug info the beta 4 for code 7 halts.
