Filament drive counting backwards
@T3P3Tony yes - it was correct to start with.
I am not sure at what point it flipped -
@Aurimas assuming the print is still going, can you see what the move.virtualEPos and move.extruders[0].position are showing as in the Object model please
@Aurimas is that extruder driven by the main board or by a tool board? What is the extruder steps/mm?
@T3P3Tony no - print is finished
@dc42 no sure why would steps matter?
Filament counter reports correctly, while Extruders Drives got inverted mid print
These are two different counters from what I understand and because of that it has software setting issue -
@Aurimas it's possible that the step counter is overflowing hence why dc42 wants to know the steps/mm of the extruder.
@T3P3Tony said in Filament drive counting backwards:
its only 400/mm
@Aurimas thanks
@Aurimas the microstep counter from which the position is computed will wrap around at 2^31 microsteps. At 400 microsteps/mm that will occur after extruding 5368709 mm of filament. So this explains it.
@dc42 just as suspected
filament counter is counting correctly anyway.
