Filament drive counting backwards
Duet Web Control
358
    Aurimas @magnets99
    @magnets99 said in Filament drive counting backwards:
    you could probably lost pla cast a whole engine block with that!
    lol. it would depend on the size of the engine block 🙂
    Australian design and build large scale 3d printers
    https://aurarum.com.au
      Aurimas @T3P3Tony
      @T3P3Tony yes - it was correct to start with.
      I am not sure at what point it flipped
      undefined undefined 2 Replies Last reply 1 Jan 2025, 17:20 Reply Quote 0
        T3P3Tony administrators @Aurimas
        @Aurimas assuming the print is still going, can you see what the move.virtualEPos and move.extruders[0].position are showing as in the Object model please
        undefined 1 Reply Last reply 1 Jan 2025, 20:19 Reply Quote 0
          dc42 administrators @Aurimas
          @Aurimas is that extruder driven by the main board or by a tool board? What is the extruder steps/mm?
          undefined 1 Reply Last reply 1 Jan 2025, 20:20 Reply Quote 0
            Aurimas @T3P3Tony
            @T3P3Tony no - print is finished
              Aurimas @dc42
              @dc42 no sure why would steps matter?
              Filament counter reports correctly, while Extruders Drives got inverted mid print
              These are two different counters from what I understand and because of that it has software setting issue
              undefined 1 Reply Last reply 1 Jan 2025, 20:38 Reply Quote 0
                @Aurimas it's possible that the step counter is overflowing hence why dc42 wants to know the steps/mm of the extruder.
                undefined 1 Reply Last reply 1 Jan 2025, 22:39 Reply Quote 0
                  Aurimas @T3P3Tony
                  @T3P3Tony said in Filament drive counting backwards:
                  its only 400/mm
                  undefined 1 Reply Last reply 1 Jan 2025, 22:41 Reply Quote 0
                    @Aurimas thanks
                    undefined 1 Reply Last reply 2 Jan 2025, 05:25 Reply Quote 0
                      Aurimas @T3P3Tony
                      @T3P3Tony @dc42 it doesn't really affect anything - I am just reporting that there is something in the code that is doing that.
                      thanks
                      undefined 1 Reply Last reply 2 Jan 2025, 06:37 Reply Quote 0
                        @Aurimas the microstep counter from which the position is computed will wrap around at 2^31 microsteps. At 400 microsteps/mm that will occur after extruding 5368709 mm of filament. So this explains it.
                        undefined 1 Reply Last reply 2 Jan 2025, 07:13 Reply Quote 0
                          Aurimas @dc42
                          @dc42 just as suspected 🙂
                          filament counter is counting correctly anyway.
                          18 out of 20
