    IDEX BOTH ON CORE XY
    MultiAxis Printing
    8.5k
    • dwuk3dundefined
      dwuk3d @o_lampe
      @o_lampe You might be right - I have been thinking about a Double Voron Tridex - but the price of the SV08 and the fact that it is mostly pre built is pretty attractive to me.
      It might I guess even be possible to adapt it to have a moving bed instead of gantry.
      I agree that swapping around the front heads would help with parallel printing - but then that would limit the ability to make the front heads tool changers - like @TeachingTech is trying to develop with the stealth changer people..
      9 colours, 4 or which could be printed in parallel is getting close to the perfect printer for me...
      Shame the SV08 print heads are so big.
      • o_lampeundefined
        o_lampe @dwuk3d
        @dwuk With a toolchanger the frame is pretty cramped. Imagine you want to replace the left green tool with the right-most parked tool or the other way round....
        dwuk3dundefined 1 Reply Last reply Reply Quote 0
        • dwuk3dundefined
          dwuk3d @o_lampe
          @o_lampe I think you are right - didn't think about both print heads needing to tool change at the same time.
          Have reduced the numbers of racked tools to 4 - but then added a second row for the back gantry to use. - Would obviously need hardware and holders.
          I think I could as you suggested flip the whole front gantry and racked tools around - too - so that all of the racked tools are in the middle - however for the purposes of aesthetics I'll leave them facing all facing in the same direction for the simulations.
          • dwuk3dundefined
            dwuk3d
            Tool changing harder to animate than some of the other concepts - initial basic animation created.
            IDEX Part13 - Sovol SV08 IDEX Dual Gantry Tool Changer Concept - Youtube
            • dwuk3dundefined
              dwuk3d @o_lampe
              @o_lampe After a fair bit of work to sort out the post processor - to make sure it doesn't miss out any important not G0/G1 commands, first test print completed on single headed printer.
              I need to do some work on feed rates and travel move speeds as I think they are getting messed up - but the actual first few layers of the E31D3F92-1AB8-4DBA-A7B3-7ED02429CFE2.jpeg print worked.
              This was print with the outer wall single threaded, with the bottom surface done in 4 chunks - 2,0,3,1
              • dwuk3dundefined
                dwuk3d @dwuk3d
                @dwuk
                @o_lampe Prints now working quite well - have attached link to a video containing two full prints.
                Segmented test prints on single head printer
                o_lampeundefined 1 Reply Last reply Reply Quote 1
                • o_lampeundefined
                  o_lampe @dwuk3d
                  @dwuk Seems to work already! 👍
                  But around 32:00 I saw a potential improvement. Your post processor seems to print some tracks "from the far end" which adds unnessesary travel moves. A small routine that checks for shortest travel move would help here.
                  Other than that, I think the result will look even better with two tools. It would avoid oozing during travel moves.
                  Maybe add the option to do the top infill layer in one go?
                  A bit of concern is the mesh-bed compensation: That printer seems to be aligned badly. Just for fun you could try to print without mesh leveling. It'll give you a good taste of things to come with 2+2 tools. (not being able to use mesh levelling was the major reason I disassembled my hashPrinter)
                  • dwuk3dundefined
                    dwuk3d @o_lampe
                    @o_lampe Thanks - agree that there is a lot of room for optimisation of travel moves etc. as you suggest.
                    I haven't even implemented any additional z hopping or retractions for long moves yet either - which should further improve the results.
                    Will add in option for top surface to be single threaded - and possibly bottom too - although it is hard to notice the gaps on the bottom.
                    Will look into the mesh levelling. I usually only enable bed levelling very occasionally - and didn't for those test prints - so will do a rerun with levelling on.
                    Will see if it makes a difference when I do the next tests.
                    Will also do side by side tests with portioned and non partitioned prints too - Maybe in a colour where it is easier to see the detail.
                    Re mesh levelling for 2/4 tools - I would like to find a way for auto levelling and alignment to work - especially once I have given the ability for each of the heads to be independently lifted for Z hopping etc.
                    • dwuk3dundefined
                      dwuk3d
                      Probably an idea too far -
                      Would really like to print the occasional object around 600m long - but don't really want a massive printer - so a 350mm bed probably a good compromise..
                      Did think about extending the whole frame - but had another idea - occasional moving bed - most printing would be done with the CoreXY 350x350 non moving bed (with up to 4 print heads in parallel) - but up to three times a layer the whole bed could be moved back or forward in 115mm steps.
                      This could combine quite nicely with the parallel printing capability - as 6 x 115mm segments would cover the whole double bed length - and would mean there is no risk of head clashes.
                      Could potentially combine quite nicely with some sort of auto eject system too if the two build plates were kept separate.
                      The whole system will likely then have 3 levels of colour change:
                      1. Fast change for 2-4 colours - using double gantry IDEX
                      2. Efficient change - using 4 more tool changer heads - possibly with different nozzle sizes too.
                        • tool changer could also be used to offload one of the front IDEX heads - for really fast single head printing.
                      3. Slow change - using a AMS/MMY multiplexer with 16+ less frequently used colours
                      • o_lampeundefined
                        o_lampe @dwuk3d
                        @dwuk said in IDEX BOTH ON CORE XY:
                        The camera gave a different impression? I could clearly see the edge of the bed moving up/down. But maybe it's the cameramount moving....
                        • o_lampeundefined
                          o_lampe @dwuk3d
                          @dwuk Regarding Z-hop: I made a dovetail(ish) hotend mount for a different project and it was meant to adjust z-height for each toolhead individually. A motorized version with a small geared N20 motor was in the making, but the FW didn't have means to poll the heightmap for dual head printing (2021). Also driving dc motors with encoder was experimental, now it would be much easier with the step/dir interface of simpleFOC.
                          • dwuk3dundefined
                            dwuk3d @o_lampe
                            @o_lampe Interesting. When I say I don't run bed levelling - I mean't I don't enable the re-mesh - (where it goes and does lots of bed probing every time).
                            I think in that case what the Bambu Lab printers do is just a small number of taps to check that the mesh seems roughly the same. If it is they just use the stored mesh.
                            If the taps show a big difference then I think they do then re-mesh anyway.
                            It might be possible I guess to completely turn off the use of a mesh - via changing the start gcode.
                            • o_lampeundefined
                              o_lampe @dwuk3d
                              @dwuk There are two different methods:
                              G32 = calibrating the bed tilt, by probing next to the leadscrews
                              G29 = using a probing grid or continuous probing to create a mesh
                              • dwuk3dundefined
                                dwuk3d @o_lampe
                                @o_lampe Interesting - will have to do something like that.
                                I got the idea to enable Z Hopping and therefore the ability to more independently print on the second gantry from @8MEKAN8 commenting on this video
                                https://youtu.be/WbJ0lNdXzsI?si=LUPyYutux6sHN9Hc
                                It looks like the Voron Tap might be a possible solution - although it might not be accurate enough to take into account mesh adjustments if it just uses a servo.
                                The other idea I had was to completely double up the flying Z gantry - with one on top of the other - with its own 4x Z axis motors - with the extruders on the top gantry being longer - so that they can fit through.
                                In the first instance I am going to try adding a 2nd gantry to the basic printer - probably without any Z hopping - so it will only be able to mirror or duplicate the first gantry - and just try out how much the extra weight affects performance and speed.
                                Then if it works ok will add the Z hopping to one of the extruders - so that I can try some parallel printing.
                                • dwuk3dundefined
                                  dwuk3d @o_lampe
                                  @o_lampe There are five few different G29's in the start GCODE - with what looks like some sort of conditional logic that is done by the printer -(rather than the slicer) using M1002's -
                                  • o_lampeundefined
                                    o_lampe @dwuk3d
                                    Yes, a servo wouldn't be the best option for mesh levelling. But there is another problem: You'd have to calculate the z-adjustment of the "mini-z axis" based on the current XY position of the other tool (which uses the classic mesh leveling) or have a mini-z axis on every tool.
                                    Unfortunately RRF allows only one z-plane and it doesn't provide "realtime" XY coordinates.
                                    You could direct the real z-motion to the main steppers (during layer change, homing etc.) and redirect the z-adjustments to the mini-z axes.
                                    Your post processor can easily detect, which is which:
                                    If there's no E(xtrusion) value in the gcode line it's a real z-move
                                    If you see a retraction/unretraction gcode with z-hop or a gcode line with extrusion, it's a mini-z thing.
                                    • dwuk3dundefined
                                      dwuk3d @o_lampe
                                      @o_lampe agreed - will certainly try and pursue accurate independent Z adjustments for each print head. Both for z hopping and will also add mesh adjustment.
                                      Whilst ideally done by the firmware I guess it should be possible to take in for example 49 mesh probing adjustment points and apply them to the gcode for each print head - if necessary splitting long extrusion moves into smaller chunks if they span a bad area of the mesh.
                                      Auto mesh adjustments in the firmware would need to be turned off.
                                      Should be possible to test this out on my single headed printer.
                                      I presume the mesh adjusting would need to reduce as the height increases.
                                      • dwuk3dundefined
                                        dwuk3d @dwuk3d
                                        @dwuk Better version of my Sovol SV08 video - with a surprise 'revolutionary' mode at the end.
                                        IDEX Part 14 - SOVOL SV08 Upgrade ideas
                                        • dwuk3dundefined
                                          dwuk3d
                                          Updated post - after better understanding.
                                          Have started to spec up the electrics I am going to need for my proposed system - and the numbers of steppers is getting rather high.
                                          Looking at Duet Hardware it looks like I need a separate driver board for each extruder - presumably a 1LC - at about £43.50 each. - Will need 8 of those in the end - but only 4 initially.
                                          Then the AXIS drivers, plus extra Gantry etc - it looks like I am going to need a controlling £225 - 6HC board for the first 6 motors - with £112 Mini 5's for each set of 5 further motors. With finally I might be able to get away with a 3HC for the last 3 motors in phase 5.
                                          Is that correct - can I have for example a 6HC controlling 4 x Mini5 boards + a 3HC in the same system collaborating with each other?
                                          Illustration here - with the -a,-b etc. suffixes are extra board instances required.
                                          Have tried putting some of it into the system config tool - but am hitting some limits.
                                          • o_lampeundefined
                                            o_lampe @dwuk3d
                                            @dwuk Seems you've reached the end of the Duet3 galaxy...
                                            AFAIK there is no toolchanging system which keeps the extruder motor and only replaces the extruder.
                                            Although you can use a MMU like enraged rabbit.
                                            My hashprinter was happy with 11 stepper drivers on a Duet2 (5+2) with DUEX5.
                                            But Duet2 isn't ready for dual g-code streams. Maybe a post processor can make it happen, if it puts all moves in one file.
