    Set hostname on Duet2 wifi
    171
    • Dave2025undefined
      Dave2025
      Hi, so Im looking if anyone can tell me how to set the hostname on Duet2 wifi boards? Looking through the documentation there's no mention of how to do this or if its even a feature. I did a google search and googles AI says something about executing the M589 S"[hostname] command. I tried that in the DWC web gui terminal and it did absolutely nothing except give me the error "Missing parameter P" Im assuming P has something to do with entering a password value but all i want is to set the hostname. Anyways if its important to know I'm running : Duet 2 WiFi 2WiFi 3.5.4 Duet WiFi Server n/a 1.27 Duet Web Control DWC 3.5.4
      Anyways can someone tell me how to set hostname please? Thanks
      gloomyandyundefined 1 Reply Last reply Reply Quote 0
      • gloomyandyundefined
        gloomyandy @Dave2025
        @Dave2025 See M550 in the Duet GCode documentation: https://docs.duet3d.com/User_manual/Reference/Gcodes#m550-set-name
        Dave2025undefined 1 Reply Last reply Reply Quote 0
        • Dave2025undefined
          Dave2025 @gloomyandy
          @gloomyandy Thanks but I think this only sets the printers name for the DWC's display name. I had also been looking at M550 in the config.g file and but it doesn't change the DHCP host name. When looking at the connected devices list in my router the Duet2 wifi board still has no host name only a IP address wether I change the M500 P or not
            @Dave2025 From the M550 documentation:
            The machine name is also used to allow local network discovery using mDNS local network discovery. Rather than
            remembering the ip address of the printer to connect to, or having to find it if assigned by DHCP (mDNS works both with fixed
            ip address and DHCP), you can use it's name. Using the example name above, in your browser connect to the DWC with
            http://Godzilla.local.
            In terms of DHCP you may need to reboot the board (or depending upon your router even wait for the DHCP lease to expire), but it should eventually show up. But really that does not matter if your network supports mDNS.
            • Dave2025undefined
              @gloomyandy said in Set hostname on Duet2 wifi:
              mDNS
              Alrite well Im not sure how to reset the lease and it says it expires in 11hrs so ill just wait because I need a break from all this anyways. I also tried to install a mDNS package on the router I have here but this is all new technology to me so I give up. Anyways thanks. Hopefully in 11 hours it will get a new IP and be using the hostname set with m550 as well
                @Dave2025 Did you try just connecting to <hostname>.local ? That will usually work on most networks without needing any router support. You may also want to upgrade your WiFi firmware, 2.2.0 is I think the current version for Duet boards.
                • Dave2025undefined
                  .local
                  Ok weird, I can connect to <hostname>.local and the DWC loads in the browser but when looking at the DHCP list in my router it does not show the host name. Ok thanks I guess this is working kinda. Also where do I find the 2.2.0 wifi firmware? Is it the DuetWiFiServer.bin from the 3.5.4 github release? Anyways thanks this is working
                    jay_s_uk @Dave2025
                    @Dave2025 yes, that's the correct file
                    • Dave2025undefined
                      Dave2025 @jay_s_uk
                      @jay_s_uk Hey sorry if im getting annoying but after updating with the DuetWiFiServer.bin from the 3.5.4 github release in YAT im getting there "Error: WiFi module reported: Didn't find access point" and then the Duet2 wifi is not connecting. If i then go and put the original old DuetWiFiServer.bin that I backed up back onto the SD card in the /sys dir and then with YAT run M997 S1 to reinstall the old wifi firmware and now I can connect again. Am I suppose to be upgrading the versions in order because I don't remember which one it was one before I've updated the DWC and firmware to 3.4.5? All I know is the current and working version I have installed is Duet WiFi Server 1.27
                        jay_s_uk @Dave2025
                        @Dave2025 that's the right file. You may want to try wiping the access point details and reloading them using M587. There's no set order to install stuff in
