Can`t connect to Duet Web Control due to dynamic IP address
Hi, I
m using the Duet 6HC for a research project and the university network (eduroam) changed the IP. I was trying to connect the board via USB and use YAT to find out the new IP but I
m having trouble with the COM ports. Is there any way to discover the new IP attributed to it without using YAT? -
@jocanetto You could use a PanelDue or 12864 display to display it but it would be much easier to ask your admins for a static IP address and to configure that instead. I doubt mDNS is supported in your eduroam network but if it is, you could connect to it via http://duet3.local where duet3 should be replaced with the hostname of your machine.
@chrishamm thank you.
The mDNS option did not work.
I will try to talk to the network admins but, from what I see here, that is very unlikely to be done.
Meanwhile, any guesses as to why the YAT route is not working? -
@jocanetto Try a different cable. Some USB cables only provide power but no data lines. The port should show up in the device manager (right-click Windows Start -> Device Manager -> Ports (COM & LPT)) once you plugin in the Duet.
@chrishamm already tried 3 cables. They are the same cables I used to do the initial configurations months ago.
@jocanetto Well, what does the device manager say? The port should show up there, and you need to configure the same one in YAT.
@chrishamm so I finally solved the issue by opening the config file that is in the microSD and changing the definitions for a fixed IP—many thanks.
@jocanetto said in Can`t connect to Duet Web Control due to dynamic IP address:
Assigning a fixed IP on an open network like that may cause issues with an IP address conflict.
Perhaps a better option is using a direct connection between your control computer and the Duet?
@jocanetto
Can you setup your printer with SBC ? If so - you could run a script that reports (e.g. by email) changes to its IP address.
Just a thought … I’ve done it in the distant past … -
@jocanetto an important consideration is you have this on a university LAN so you are exposing an insecure control board to a large network with a range of curious students on it. (I once was one of those students...... )
I highly recommend not doing that. A direct ethernet cable or a Lab only LAN or similar is the way to go
