[3.6.0-beta.3] Duet 2 issues, lost communication
New results. With beta.3 I can get results from M115 but M122 just hangs for maybe 15 seconds then the Duet reboots. I did have a recent Duet2_SDiap32_WiFiEth.bin but I noticed that the 3.54 release area had a few hours old version so I put it on the SD card. No change. I'm hardwired so no wifi in use. I'm back to beta.2 via bossa and M122 works fine.
Are there known instances of stand alone duet2 boards working with this release?
@DaveA
Yes. I have two printers running Duet2 boards stand alone. The latest release is working very well.I have not come across any issues as yet. Just make sure you use the latest version.
@DaveA please provide your config.g file, then I can try it here and see whether it works for me.
@DaveA said in [3.6.0-beta.3] Duet 2 issues, lost communication:
So this is an Duet 2 Ethernet? Please post your M122 as well.
@droftarts
I'd like to include the M122 output but I can't. When I issue M122 I get no text on TeraTerm for about 15 seconds then the board reboots.
If I issue M115 I immediately get the board name and firmware version.
So something is running. -
@DaveA It doesn't have to be from beta.3, do it from beta.2 if it works there.
@droftarts
Here is the beta 2 M122
Beta2M122.txt -
@DaveA I've reproduced a fault, it appears to be a networking issue in 3.6beta3 on Duet 3 Ethernet. I am investigating it.
@DaveA please try the 3.6.0-beta.3+1 build at https://www.dropbox.com/scl/fo/bx70c7u0bshq79ez83mnn/AKMj4UCEimtQuGYxRj_d0ew?rlkey=7yiq3x5fcae3v2ogslfocx1op&dl=0.
Bingo! DWC comm is back. I had to pull the printer apart to get to the Duet so I can't try a print for a while. Thank you for the quick response. -
undefined dc42 marked this topic as a question
undefined dc42 has marked this topic as solved
undefined DaveA referenced this topic
Hi, I have the same problem. I'm trying to update through paneldue console, I send M997 S0, it says firmware updating, connection is lost, I reset the board but firmware file is not changed, is it possible to do it this way or only through USB?
@3DOeste please try by USB
@T3P3Tony Ok, It seems to be working fine with 3.6beta3+1, no delays I could notice.
@3DOeste thanks for confirming!
