[3.6.0-beta.3] Duet 2 issues, lost communication
@droftarts
I'd like to include the M122 output but I can't. When I issue M122 I get no text on TeraTerm for about 15 seconds then the board reboots.
If I issue M115 I immediately get the board name and firmware version.
So something is running. -
@DaveA It doesn't have to be from beta.3, do it from beta.2 if it works there.
@droftarts
Here is the beta 2 M122
Beta2M122.txt -
@DaveA I've reproduced a fault, it appears to be a networking issue in 3.6beta3 on Duet 3 Ethernet. I am investigating it.
@DaveA please try the 3.6.0-beta.3+1 build at https://www.dropbox.com/scl/fo/bx70c7u0bshq79ez83mnn/AKMj4UCEimtQuGYxRj_d0ew?rlkey=7yiq3x5fcae3v2ogslfocx1op&dl=0.
Bingo! DWC comm is back. I had to pull the printer apart to get to the Duet so I can't try a print for a while. Thank you for the quick response. -
Hi, I have the same problem. I'm trying to update through paneldue console, I send M997 S0, it says firmware updating, connection is lost, I reset the board but firmware file is not changed, is it possible to do it this way or only through USB?
@3DOeste please try by USB
@T3P3Tony Ok, It seems to be working fine with 3.6beta3+1, no delays I could notice.
@3DOeste thanks for confirming!
