    Temperature controlled always on fan
    444
    • Aurimasundefined
      Aurimas @o_lampe
      @o_lampe ok so I think I got some idea how it works.
      just need a bit of huidance
      2 issues:
      can't this to work
      while get boards[0].state = "running"
      what am doing wrong.
      as a test i got this, but the fan runs 100% all the time 😞
      white state.status = "idle"
      if sensors.analog[4].lastReading<65
      M106 P5 S0.2
      else
      M106 P5 S1
      the result is that P5 is 100% all the time
      OwenDundefined 1 Reply Last reply Reply Quote 0
      • OwenDundefined
        OwenD @Aurimas
        @Aurimas said in Temperature controlled always on fan:
        2 issues:
        can't this to work
        Which board are you running?
        On my Duet 2, this is showing as "unknown" so I suspect it's not supported on all boards.
        It may even only be for toolboards. @DC42 may confirm
        M106 P5 S0.2
        else
        M106 P5 S1
        Apart from the type on "while" , I'm not sure your indenting is correct for the else.
        while state.status = "idle"
              M106 P5 S0.2
           else
              M106 P5 S1
        Should work if in fact the board is in the idle state.
        If you're doing this in daemon.g then it would be better to not enter such a closed loop
        By default daemon.g runs every 10 seconds. If that is often enough for your purposes then simply do your check.
           M106 P5 S0.2
        else
           M106 P5 S1
        If you want it to run more often the use a while loop, but make sure you add a G4 command so that control is returned to the main process regularly.
        while true
              M106 P5 S0.2
           else
              M106 P5 S1
           G4 S2
        If you want to have it happen only when idle, or any other state then you can use that as well, but still use a delay in your loop.
        Aurimasundefined 1 Reply Last reply Reply Quote 1
          dc42 administrators @Aurimas
          I want to have temperature controlled fan that is always at minimum 20% speed.
          What's the reason for wanting 20% minimum speed, instead of Off when the temperature is low enough?
          The solution proposed by @o_lampe looks good to me, in principle.
          Aurimasundefined 1 Reply Last reply Reply Quote 0
          • Aurimasundefined
            Aurimas @dc42
            @dc42 I have a fan on the enclosure - I want it to suck the air out of enclosure and through the HEPA filter. that would create slight negative pressure in the enclosure.
            then I want the fan to flip to full power if the enclosure gets over certain temp so that it cools down and prevents overheating.
            • Aurimasundefined
              Aurimas @OwenD
              @OwenD thank you. I am just learning these things and the syntax is a bit of a mystery for me 😞
              like your statement: "while true" - where do i find this info?
              • OwenDundefined
                OwenD @Aurimas
                Information on meta commands can be found here
                while creates a loop that is typically limited by a boolean expression
                while iterations < 10 or as you had while state.status = "idle"
                while true will always resolve to true in a similar way to using while 1=1 would, so it creates an endless loop
                When you do so, you have to ensure that you hand control back to the CPU (G4) or have a mechanism to break out or the machine will be unresponsive.
                • Aurimasundefined
                  Aurimas @OwenD
                  @OwenD thank you
                  • CaiJonasundefined
                    CaiJonas
                    Hello everyone,
                    I think I have the same wish.
                    I would like to connect three 4 pin pwm fans to fan output 4.
                    It is an always running fan for my water cooling system.
                    That means it has to run when the nozzle is around 45C. This is already working. But the fans are too loud and too strong. I would therefore like to reduce the fan speed to 30%.
                    The fans are connected via a 3-way splitter and this is important for me to have some kind of redundancy if one is faling.
                    How can I achieve this? @dc42
                    Best Regards
                    Cai
                    dc42undefined Aurimasundefined 2 Replies Last reply Reply Quote 0
                      dc42 administrators @CaiJonas
                      @CaiJonas you can connect multiple PWM fans to the same 4-pin output, provided you don't exceed the total current limit. The fans should all be of the same type so that they run at the same speed. Connect the positive, negative and PWM wires of all 3 fans to the corresponding pins on the Duet. I suggest you connect just one of the fan tacho wires to the tacho input on the Duet 4-pin connector.
                      You can use the X parameter in the M106 command to set the maximum PWM.
                      CaiJonasundefined 1 Reply Last reply Reply Quote 0
                      • Aurimasundefined
                        Aurimas @CaiJonas
                        This post is deleted!
                        • CaiJonasundefined
                          CaiJonas @dc42
                          @dc42 thanks, that was the thing I was looking for
