WiFi issues with 3.5.4
@fcwilt I don't know exactly what data is requested from the OM for DWC and PanelDue, I think only the changing data, so I doubt it will be affected by your use of data driven code. It's more the increase in the number of sensors and configured drives, whose positions are frequently updated, ie whatever is displayed in DWC and PanelDue. @dc42 and @chrishamm will know better than me, though.
That does make sense. Why would any thing other than my code need to know that values in the object model.
I made all the changes I could:
- Retry setting
- PanelDue firmware
- DuetWiFiServer firmware
The DWC reports the new version number. The PanelDue reports the new version number.
The WiFi still disconnects.
This is not good.
I suppose I could create a temp config.g file with a bare minimum of items just for testing.
Is is possible to revert firmware back to the previous versions?
Any other ideas?
@fcwilt Try it with the 3.6.0-beta.4. Or revert everything to 3.4.6.
@droftarts said in WiFi issues with 3.5.4:
I know how to upgrade.
How do I revert if that is what I have to do?
@fcwilt same way
@jay_s_uk said in WiFi issues with 3.5.4:
@fcwilt same way
So I upload the old version files and it will ask if I want to install?
@fcwilt Reverting is easier, because you just upload the 3.4.6 release zip file. But 3.6 isn't too far away from being released, and it would be good to get your feedback if anything is broken for you before we release!
And people that have had WiFi issues have found the latest 3.6 beta (along with the other suggestions) fixes them.
Glad to help.
In the past I have avoided the betas and rcs as I did not realize it was possible to go back to an older version.
Knowing that I will give the beta a go.
I went to the site to download the beta files but I don't see the ZIP file of all of the Duet 3 files I am used to using.
So I guess I need some of the files list.
Which ones?
@fcwilt assuming you’re running standalone, the ones whose name matches your board(s), so probably Duet3Firmware_Mini5plus.uf2, and DuetWebControl-SD.zip. Upload them as-is.
@fcwilt no, as that’s the version that’s distributed with 3.6.0-beta.4
Well I updated to 3.6.0 BETA 4 and the WiFi connection failed even sooner than it did under 3.5.4.
The features of 3.6 sound interesting but not at the expense of no WiFi connection.
I was able to revert to 3.4.6 so that is good for now.
@fcwilt it would be good to work out why it disconnects for you. I’ll ask @dc42 what information he needs to troubleshoot, if you’re willing to give it another go. Otherwise you’re going to be stuck on 3.4, because as far as we’re concerned, the issue is fixed.
I have a couple of other Duet 3 boards I could setup on the bench IF testing without actually being able to print would prove anything.
There could still be connected steppers, temp sensors, etc - just not assembled into a working printer.
I had a bit of time so I setup a Mini 5+ on my bench - updated to 3.5.4.
It has no other hardware - just a minimal config.g.
I also include creating all of the global variables I normal use to see if that was part of the problem.
So far it is staying connected without issues.
