M950 to add servo control
@moth4017 Ok, when does the fan turn on/off? Is that a separate command or just when the "composite fan" is set above 0?
@T3P3Tony
cpap/fan , controlled via A fan output,
servo Controlled via A fan output
Flap homing via digital inputrequired 2 fan outputs and 1 input in total
@moth4017 ok, but what would the configuration command look like and the control.command?
Presumably M106 for control?
@T3P3Tony I would suggest M106 for control, with M950 being able to set a minimum and maximum servo angle for 0 and 100%
@jay_s_uk
so M950 set min & max angel
and
M106 still be 0 to 100% -
@moth4017 yea exactly, so M106 is able to extrapolate an angle for an M106 percentage based on the min and max in M950
@T3P3Tony yes, something like that. maybe with the ability to set the % for the fan you want to use.
e.g.
M950 S0 "servo+fan" K10:90 U90
where K is the min/max angle and U is the fan percentage
Its a bit tight on what letters are available on M950 so I had to reuse a couple -
@T3P3Tony none that come to mind that I've seen
@jay_s_uk was hoping for some nice generalisation of the concept. Oh well.
@T3P3Tony maybe its a bit like "if you build it they will come"
I don't keep track of most of the cooling options though TBH as I'm mostly CPAP now -
@moth4017 that feels like something that can be done with metagcode already (,the chamber venting if the chamber sensor is below a certain temperature)
@T3P3Tony i still need to control a vent/solenoid / servo as my chamber is sealed , i just thought it would be away to kill 2 birds one stone
@moth4017 This is logged in GitHub now:
https://github.com/Duet3D/RepRapFirmware/issues/1092 -
@T3P3Tony thank you
