    Problem with LED STRIP APA102 on DUET 6HC
    296
      jay_s_uk @Makoaaaa
      @Makoaaaa update to 3.5.4. this was fixed in 3.5.2
      Makoaaaaundefined 1 Reply Last reply Reply Quote 0
      • Makoaaaaundefined
        Makoaaaa @jay_s_uk
        @jay_s_uk Thanks, I will try tomorow.
        • Makoaaaaundefined
          Makoaaaa @Makoaaaa
          @jay_s_uk I've tried, but it doesn't work. I don't understand why, can I try with other pins to find out if the problem is with the duet motherboard or the led strip?
            jay_s_uk @Makoaaaa
            @Makoaaaa ok, looking at this again your config is wrong
            M950 E0 C"led" T1 Q3000000
            T1 is incorrect for a dotstar strip, it should be T0. See here https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m950-create-heater-fan-spindle-led-strip-or-gpioservo-pin
            Makoaaaaundefined 2 Replies Last reply Reply Quote 1
            • Makoaaaaundefined
              Makoaaaa @jay_s_uk
              @jay_s_uk oh yes thank you, i will try this.
              • Makoaaaaundefined
                Makoaaaa @jay_s_uk
                @jay_s_uk I'm reaching out to you again because I've tried many things, but I still can't get this LED strip to work.
                First, I replaced T1 with T0, but it made no difference. Then, I tried powering the 5V only from the Duet and later tried connecting GND only to the Duet and then only to the 5V power supply.
                I also tried swapping the Data and Clock connections, and finally, I repeated all these tests on the other end of the LED strip.
                Additionally, I made sure my board is properly updated to firmware version 3.5.4 using the M115 command.
                At this point, I don’t know what else to try. Any help would be greatly appreciated.
                Thanks in advance!
                jay_s_ukundefined dc42undefined 2 Replies Last reply Reply Quote 0
                  jay_s_uk @Makoaaaa
                  @Makoaaaa I don't have a dotstar to try this with.
                  Can you post your latest config again?
                  then we can ask one of the duet team to take a look
                    dc42 administrators @Makoaaaa
                    @Makoaaaa for testing you can power the LED strip from the Duet, but don't turn on more than about 10 LEDs at once. That's probably easiest to start with, then you can switch to external PSU when you have it working.
                    If you use an external PSU for the LEDs then you need to connect the grounds (i.e. negative output terminals) of both the Duet PSU and the LED PSU together. To avoid ground noise caused by the stepper motors, best to do this by connecting GND on the LED output to both your LED strip and the negative output terminal of the LED PSU.
                    Please post photos showing how you have connected the LED strip to the DS connector, and post your current config.g file.
                    • Makoaaaaundefined
                      Makoaaaa @dc42
                      @dc42 @jay_s_uk Thank you for your messages.
                      I modified my firmware to light up only the first five LEDs, but unfortunately, it still doesn’t work. I tried this setup both using only the Duet and with the 5V power supply, but neither worked.
                      I am attaching my full machine configuration file, as well as some pictures of the setup, both with only the Duet and with the external 5V power supply.
                      Thanks in advance!
                      • Makoaaaaundefined
                        Makoaaaa
                        config.g IMG_20250219_183559.jpg IMG_20250219_183246.jpg IMG_20250219_183608.jpg
                          @Makoaaaa I think the arrows on the LED strip point from the first LED in the chain to the last one. In which case, you are driving the wrong end of the strip.
                          • Dad003undefined
                            Dad003
                            Other option is to wire these directly to the psu . Personally I use similar led strip but I wired mine directly to the psu .
                            • Makoaaaaundefined
                              Makoaaaa @dc42
                              @dc42 I tried with the 2 parts of the LED strip
                              • Makoaaaaundefined
                                Makoaaaa @Dad003
                                thanks, but this LED needs data and clock to start. So I can power the LED with the power supply but I also need the clock and data with the duet
