    Error: M584: Invalid number of visible axes
    • ToWi1989undefined
      ToWi1989
      I'm running a core XY machine with 3 individually driven Z-axis. Sometimes I wish to take manual control over each individual Z-drive, for example when the bed becomes so tilted that autoleveling would result in a crash. I was using a macro to switch between showing the combined Z-azis and individual (UVW) axis control. However, since upgrading the firmware (now running 3.5.4) this macro is giving an error:
      This is my drive mapping:
      M569 P0.0 S1							; physical drive 0.0 Z1 goes forwards
      M569 P0.1 S1							; physical drive 0.1 Z2 goes forwards
      M569 P0.2 S1							; physical drive 0.2 Z3 goes forwards
      M569 P0.3 S1							; physical drive 0.3 X goes forwards
      M569 P0.4 S1							; physical drive 0.4 Y goes forwards
      M569 P121.0 S0							; drive 121.0 goes backwards
      M584 X0.3 Y0.4 Z0.0:0.1:0.2 E121.0				; set drive mapping
      M671 X24:333:178.5 Y-33.5:-33.5:275.5 S50		        ; set lead screw position for auto bed leveling
      The macros for switching between showing/hiding the UWV axis is a simple:
      Hide UVW:
      M584 P3 ; Show only first 3 assigned axis
      Show UVW:
      M584 P6 ; Show all 6 assigned axis
      I've tried changing M584 X0.3 Y0.4 Z0.0:0.1:0.2 E121.0 to M584 X0.3 Y0.4 Z0.0:0.1:0.2 U0.0 V0.1 W0.2 E121.0 P3
      This causes some very weird behaviour. Moving the Z-axis works as expected, but moving the individual U V W axis results in a small amount of movement, and the drive is turned off after a couple of seconds.
      Does anyone have any clue how to get this to work again / what changed in the firmware?
        jay_s_uk @ToWi1989
        @ToWi1989 what firmware were you running before?
        You can't show an axis if it hasn't been configured so using M584 to map the same drivers to U V and W is correct.
        How are you setting them as homed for that axis?
        What board are you running?
        Best post your full macro you are using
        ToWi1989undefined 1 Reply Last reply Reply Quote 1
        • ToWi1989undefined
          ToWi1989 @jay_s_uk
          @jay_s_uk I have no idea what the old firmware was. I've upgraded some months ago, but only sporadically use the UVW controls. As far as I can tell I've made no changes to the config file myself, but it's very well possible some trial and error was involved after the upgrade that I can't recall. Homing/leveling the bed is done via G32, but if the bed is tilted too much it will crash with the print head. I'm disabling the axis limits to move the UVW axis independantly, but only when needed (I had 1 stepper loose connection to the B-coil during a print last night which resulted in a prety catastrophic failure).
          I've added the UVW assignments back in the M584 comand, but missed that I need to configure all the other parameters (motor current, accell, steps/mm, ...) for the UVW axis as well. This also explains the weird behavior that I saw. This is now corrected and working again!
          I was thinking that setting these parameters once per physical drive would be sufficient, but I've proven myself wrong 😄
          jay_s_ukundefined 1 Reply Last reply Reply Quote 2
            jay_s_uk @ToWi1989
            @ToWi1989 glad you got it sorted
