    Bluetooth PanelDue, less com issues
    PanelDue
    441
    • jackantubisundefined
      jackantubis
      I made my PanelDue wireless to keep it close to me and removing the regular and unknow com error in the web interface.
      • magnetic mount on the printer + soon charging with contact pins on the back instead of the usb connector.
        You can't use the SD embeded port wireless (bad idea anyway).
        Sorry for non official screen 😓 probably working as good on official.
      Notepadundefined 1 Reply Last reply Reply Quote 6
      • Notepadundefined
        Notepad @jackantubis
        @jackantubis I love it! super cool.
        was there any specific process to pair up the transmitters? Either way that is a very nice minimal way to get a mobile screen!
        The real bamboo printer manufacturer
        jackantubisundefined 1 Reply Last reply Reply Quote 0
          jackantubis @Notepad
          @Notepad yes you need to pair them Master and slave with right speed and right wiring, if you have 2 HC05 and a USB to TTL you can build a minimal setup with a power bank to supply the micro usb.
            Link to the hardware used?
              jackantubis @Phaedrux
              @Phaedrux
              Hc05: https://a.aliexpress.com/_EGOKr6V
              5V UPS: I just found this on AliExpress:
              1,47€ | Mini 5V 1A UPS Uninterrupted Output Module 2 in 1 Charge Discharge 3.7V 3.8V 4.2V Li-Ion Li-Polymer 18650 Battery Charger Board
              https://a.aliexpress.com/_EIco57n
              1x 18650 li-ion battery or other flat li-ion battery.
              1 switch from the shelve.
              My design for the case.
                jackantubis
                First revision of the tutorial for the bluetooth PanelDue
                HC-05 Panel DUE V1.pdf
                jackantubisundefined apakundefined 2 Replies Last reply Reply Quote 5
                  jackantubis @jackantubis
                  I'll appreciate some feedback on the tutorial 😁. Thanks for the brave who are trying the Bluetooth COM 👍
                  • apakundefined
                    apak @jackantubis
                    @jackantubis nice, thanks for sharing, I am rebuilding a Tevo Little monster for a total of 1000mm Z size, so I love the wireless solution for the paneldue
