    Creality CR-10 upgrade
    252
    53.8k
    • Agniusmundefined
      Agniusm
      Tried 0.5 and 0.7 made it better. I found my problem. Skipping gear on e3d.
      Don't know why its happening so will contact their support
      • Agniusmundefined
        Agniusm
        What should i put in starting Gcode for mech bed compensation?
        is it only the M28 command or should i erase previous probing?
        Here is what i have at the moment (mainly modified from prusa mk2 πŸ™‚ 😞
        M83 ; extruder relative mode
        M104 S[first_layer_temperature] ; set extruder temp
        M140 S[first_layer_bed_temperature] ; set bed temp
        M190 S[first_layer_bed_temperature] ; wait for bed temp
        M109 S[first_layer_temperature] ; wait for extruder temp
        G28 ; home all without mesh bed level
        G32 ; mesh bed leveling
        G1 Y20 X10 Z0.30 F7000.0 ; go outside printing area
        G1 E10 F100
        G1 X100.0 E9.0 F1000 ; intro line
        G1 X180.0 E12.5 F1000 ; intro line
        So instead of 5 point probing G32 i have, should i change to:
        G29 S0 (or S1 if i want to use previous data from last measurement)?
        • Agniusmundefined
          Agniusm
          So my titan aero is clicking and e3d sent a new motor only larger which does not fit my design. Are you David use titan aero and if so any issues ? I found this motor and i dont know if the data is correct and if it would work: https://www.omc-stepperonline.com/hybrid-stepper-motor/nema-17-bipolar-18deg-18ncm-255ozin-07a-29v-42x42x25mm-4-wires-17hs10-0704s.html
            I don't use a Titan Aero, I use a regular Titan. The motor I use is this https://www.omc-stepperonline.com/hybrid-stepper-motor/nema-17-bipolar-18deg-22ncm-31ozin-133a-28v-42x42x34mm-4-wires-17hs13-1334s.html.
            • Agniusmundefined
              Agniusm
              Changed my bed for precision plate now battling IR probe as endstop. I cant seem to grasp the concept here. I lover the nozzle to where it touches the piece of paper then G92 Z0 and when i home it does not go back to that height. Tried G31 P500 X5 Y14.5 Z-5.5 ; with no success.
              Whats the proper procedure setting Z probe height?
              I am looking at these :
              https://duet3d.com/wiki/Setting_up_automatic_probing_of_the_print_bed
              https://duet3d.com/wiki/Using_mesh_bed_compensation
                The G31 Z parameter should be positive for sensors that trigger before the nozzle touches the bed. For the IR sensor is should be no higher than about 3mm.
                If you are restarting the Duet between attempts, also check that you don't also have a G31 command in config-override.g.
                • Agniusmundefined
                  Agniusm
                  I dont have that file. So G31 is the offset of the Z probe depending how its mounted?
                  So then i would go:
                  M208 S1 Z-3
                  Lower the nozzle to where it touches say piece of paper.
                  G92 Z0 to store that
                  But where is that offset, do i need to read it from web interface and then enter it to config.g's G31? Is there a step by step somewhere?
                    I suggest you read the commissioning instructions in the fitting instructions page, at https://miscsolutions.wordpress.com/mini-height-sensor-board/.
                    • Agniusmundefined
                      Agniusm
                      Thank you. I think i have the idea now. Here is the map:
                      Is this any good or my bed is bad?
                      I have bought new 8mm precision plate but it does not look that precise.
                      Before i had Chaina heatbed out of 3mm aluminium and got this:
                      Can you help interpret the results?
                      P.S. I have 5V LED bar. Draws little over 1 A
                      Can i connect it to unused expansion header pins and control it with a macro? Cant seem to find header ratings
                        Your first height map looks OK, but the second (mostly red one) looks poor.
                        If you have a spare controlled fan output on the Duet, you can connect your lighting between +5V on the expansion header and FAN- on your chosen controlled fan output. The control it using M106. Or, if uou are not using the E1 heater output, you can connect the lighting between +5V on the expansion header and E1- on the E1 heater terminal block. Caution! Some versions of the Duet PCB have the E1- and VIN legends for the terminal block the wrong way round. E1- is the end farthest from the corner of the board.
                        • Agniusmundefined
                          Agniusm
                          Great. Thanks.
                          • tychopundefined
                            tychop
                            Agniusm,
                            I'm about to start my adventure to replace the cr-10 board with the DuetWiFi..
                            The steppermotor connectors are slightly different, but it's possible to plug it in…
                            Question:
                            Are the steppermotor connectors of the CR-10 pin-compatible with the connectors of the Duet board?
                            Can I plug them in the Duet board or do I have to rewire ??
                            If so, which way should the connector be orientated?
                            • Agniusmundefined
                              Agniusm
                              I think you will need to rewire. I swapped my cables and built them from scratch so i don't really know.
                              • tychopundefined
                                tychop
                                @Agniusm:
                                Not wat I was hoping for, but thanks for letting me know..
                                I'll go and hunt down the wiring of the cr-10 connectors.
                                  You can test whether the connectors need to be rewired in either of two ways:
                                  1. Use a multimeter to measure the resistance between pins. If the wiring is correct for the Duet, you should get a few ohms resistance between pins 1 and 2, and a few ohms between pins 3 and 4. There should be no continuity between 1 or 2 and 3 or 4.
                                  2. If you don't have a multimeter, then you can try shorting pins together to see if it makes the motor harder to turn. If it is wired correctly, then if you short pins 1 and 2 together, or pins 3 and 4 together, it will be harder to spin the spindle with your fingers.
                                  • Agniusmundefined
                                    Agniusm
                                    @tychop:
                                    @Agniusm:
                                    Rewiring is basically swapping pins. There is not much to it. Like DC42 said or you can simply plug generic LED and spin the motor by hand. If it lights up, you got a pair.
                                    On cr10 i think pairs are layed out as follows on motor connector: 1 and 4 one pair, 3 and 6 the other one. On duet you have 1b1a and 2a2b.
                                    Now just connect you wires so 1 goes to 1a 4 to 1b 3 to 2a 6 to 2b and if its reversed, reverse it back in firmware. It is different for y axis only.
                                    • Agniusmundefined
                                      Agniusm
                                      The AJAX error still does my head in. I pulled out old router to test, where all AP's are stored so i could edit the list? I have ordered new AP so i can dedicate it to the printer
                                        The latest (1.20) version of DWC gives a more precise error message instead of "AJAX error".
                                        • Agniusmundefined
                                          Agniusm
                                          Is there a way to set baby stepping on LCD to be something else than 0.05 or is it precompiled in LCD firmware?
                                          • Michel000undefined
                                            Michel000
                                            I do not think that these AJAX errors are caused by your wifi connection but by the firmware (Firmware 1.9 and up)
                                            I had them all the time after upgrading, im back to the old firmware and dont have them anymore
                                            see also my tread :
                                            https://www.duet3d.com/forum/thread.php?id=3831
                                            i hope this will be fixed
