How can I stop Z moving if Z probe fails
dc42, I mean the Z endstop input.
I'm sure that is where I have it connected but I will need to check in the morning.
I use your mini Z probe to home Z and check the bed levelling.
So should the M581 line be E0 S1 T0 C0It should be: M581 Z S1 T0 C0
I think I know what's happening here.
Paul,
Did the M581 E2 S1 T0 C0 line come from the config.g that I sent you when you were trying to get XYUV working? I ask because it's identical to what I use. If so, then it'll only work if you have the switch wired the same as me and it will take the same action that I have my machine set up to do. If you have the switch wired to a different end stop, then you need to change the E0 to Z as David has said. You can't use E0 and E1 because these are now U and V endstops.
Also, the action that I take is to do an emergency stop when the switch triggers so if you want to run your trigger macro, then you have to change T0 to point to that macro. The Wiki explains is quite well https://duet3d.com/wiki/G-code#M581:_Configure_external_trigger
HTH
Thank you both.
I did have the end stop connected to Z and using T2 does reverse the Z by 5mm as indicated in the trigger macro, however, It does not stop the initial movement, the reversal only happens after the move has taken place. So in the case of a probe failure, Z just keeps moving until the hotend or bed has broken.
I have looked at all G and M codes and can not find any that will stop the current move, other than emergency stop, Is there a way to interrupt the current move and action the trigger macro? -
Thank you both.
ā¦.....................
I have looked at all G and M codes and can not find any that will stop the current move, other than emergency stop, Is there a way to interrupt the current move and action the trigger macro?Ahh, now that you mention it, that rings a bell somewhere at the back of my mind. I can't remember exactly but there was a reason why I abandoned using a macro and resorted to just doing an emergency stop. Maybe that was it. No doubt David will come along and put us both right shortly.
According to the wiki page, wouldn't using T1 cause the printer to pause? That's what you want to happen if the switch gets tripped. Have you tried that?
As I understand it, activating pause will run the pause macro but will not run the trigger macro, also, how would I recover from the pause, without the head moving to the original paused position?
Maybe I will just have to use the emergency stop T0 and wait for the firmware to reboot.
Yes, pause.g is just another macro so I'd have thought that if the machine waits for the move to complete before running a trigger macro, then you'd get the same behaviour running the pause.g macro. No doubt David will put us all right.
It's not a big deal to use that. Let's face it, with this "fall back switch" you'll only see this emergency stop if the Z probe fails so it won't be often - hopefully never.
Thank you both.
I have looked at all G and M codes and can not find any that will stop the current move, other than emergency stop, Is there a way to interrupt the current move and action the trigger macro?A move can only be terminated by a trigger from the Z probe during a probing move, or an endstop switch trigger during a G1 S1 move, or an emergency stop, or running out of power. If you use 1.20 series firmware then you could instead use M913 Z0 to set the Z motor current to zero when a trigger occurs. However, a normal trigger doesn't have the same priority as a T0 so there might still be a delay in some cases.
Thanks for all of the help.
I'll use T0 and forget the trigger file -
Thank you all, This has been a good learning post. I wonder if the pause is after the programmed move is finished or after the planner buffer(?) is empty? Meaning that it completes several moves before the pause takes place?
@appjaws,
Paul. Off topic I know but another tip in case you don't already do it, is to lower the motor currents at the start of homing. You'll need to play around to find the right value but you are looking to find the minimum that you can home reliably at. Then if the worse happens and every switch fails, a head crash won''t do too much damage. (Don't forget to put the motor currents back up again at the end of homing).
Also, I added extra micro switches to X and Y and Z axes maxima and wired them all in series with the Z min so if any one triggers, it'll initiate an emergency stop. This is just for when I'm playing around and attempt to move beyond the axes limits before I've homed the printer. Oh and finally, I added big red emergency stop button and wired that to another estop. It's not a true emergency stop because it doesn't cut power, so wouldn't be much use in the event of a fire. But have an RCD conveniently placed that I can easily trip in that eventuality.@timcurtis
Tim. I wasn't ignoring you - just don't know the answer to your question My guess would be just the current move buy David will confirm or otherwise. -
The trigger file starts running asynchronously with respect to commands already being executed, with a few caveats:
- If multiple trigger events other than T0 are pending, only one can be executed at a time. So you might have to wait until the previous trigger macro completes.
- There might be another process accessing the SD card at the time.
- If the trigger macro commands any movement or uses any command that affects movement (other than M906 and M913 in firmware 1.20 and later), all the moves already in the movement queue are completed first.
Thank you for the clarification David.
My goal is to rig up a simple filament out switch with the pause command. At least until the filament monitors are ready for sale. -
See the description of M591 in the GCode wiki.
