Scara manual control
@droftarts said in Scara manual control:
Looking at your config.g, you seem to have your machine limits set to allow the Scara arm to go anywhere in a donut shape around the centre. Your M208 XY limits are +/- 1200mm, which is roughly the length of your proximal (765mm) and distal (475mm) arms, with a central no-go area of 450mm radius (ie 900mm diameter). Is this correct?
Regarding the M208 limits, everything is fine; when it reaches -1200/1200, it doesn't allow further movement.
However, there is an issue with the R value. I even increased it to R500, but it exceeds this value and continues until it reaches the limit defined by the distal angle, which is 150(endstop). If it continues to be commanded in that direction, it moves in the opposite direction and stops at the -151 distal angle.
It seems to me that the situation starts with it ignoring the value set in R.@droftarts said in Scara manual control:
If you command it to go into any area within the 900mm diameter central area, I would think it should stop at the point it gets within 450mm of X0 Y0. If it continues to attempt to get there, I think that sounds like a bug. Can you confirm that's what you see?
No.Only stop when reach the 150 distal angle(420mm of X0 Y0 approximate).
@Fuzionline said in Scara manual control:
I think that's the default. From 'Serial SCARA' tab of M669 https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m669-set-kinematics-type-and-kinematics-parameters
Rnnn (optional, RRF 2.03 and later only) Minimum permitted printing radius from the proximal axis. If not specified, it will be calculated to be slightly larger than the distance between nozzle and proximal axis when the distal axis is homed.
So it does look like R is being ignored. I'll report it to @dc42 and see what he says.
@droftarts
tks for your help -
@Fuzionline I've raised this as an issue on Github: https://github.com/Duet3D/RepRapFirmware/issues/1045
@droftarts
Tks -
@Fuzionline
hello
Do you have news
tks -
@Fuzionline did you test this with 3.6beta2 to see if its resolved or not?
I updated to version 3.6.0 Release Candidate 1, but the M571 command doesn't work. I reverted to Release 3.5.4, and it's working. Thank you.
I have a Duet 2 wifi. -
@Fuzionline
I haven't had the opportunity to test 3.6 beta 2 yet to see if it resolved the issue with M669 R. -
I have a Duet 2 wifi.Confirmed, M571 doesn't work in 3.6.0-rc.1 and 3.6 beta versions. It will be fixed in rc2.
