    smart effector
    Smart effector for delta printers
    614
      droftarts administrators @mickeey
      @mickeey
      good morning. I am having problems with my new smart effector that I installed and configured scrupulously following the reference guides but I basically have 2 problems that I am going to list:
      • the first is that the print cooling fan even though it is connected and configured correctly remains permanently on.
      • the second is that the probe does not work the green test LED does not light up. I tried the test with the G31 and the answer seems correct but when I go to test the G30 it does not work.
      everything else works correctly and before contacting you I asked 3 friends who have used several smart effectors to verify my work which was correct. I contacted the official dealer who advised me to expose my problem here on this forum in case someone could help me solve this problem. I know it is very unlikely but after 4 days of testing and having spoken on this forum of similar problems, I am led to think that the problem is attributable to the faulty smart effector.
      Please post your config.g and the response to M122. Please also post pictures of your wiring.
      mickeeyundefined 4 Replies Last reply Reply Quote 0
      • mickeeyundefined
        mickeey @droftarts
        spero di aver inviato nel modo corretto, nel frattempo ringrazio per l'interessamento
        @droftarts config.g console.txt
        • mickeeyundefined
          mickeey @droftarts
          @droftarts c3b80b45-397e-4ca6-bb5b-5068808bd0b9-console.txt
          • mickeeyundefined
            mickeey @droftarts
            @droftarts ed7ce806-cd54-42e6-89cf-8c9aab827a70-config.g
            • mickeeyundefined
              mickeey @droftarts
              @droftarts IMG-20250428-WA0006.jpg IMG-20250428-WA0003.jpg IMG-20250428-WA0002.jpg IMG-20250428-WA0001.jpg IMG-20250428-WA0007.jpg
                @mickeey I think you have wired the 4 wires from Duet 2 WiFi Z Probe pins to the Smart Effector incorrectly.
                3d6a0c08-6869-4159-824f-a87605771c96-image.png 418c51bb-f437-42fa-bee4-aa2b329c96c4-image.png
                On the Smart Effector, you have Black - 3.3V, Green - Z PROBE MOD, Blue - GND, Red - Z PROBE OUTPUT
                751937c2-ec79-47ce-b07e-30523f0c7cb3-image.png c628d2b5-5a51-49da-a936-9441278bb847-image.png
                On the Duet, you have Red - 3.3V, Blue - Z PROBE MOD, Green - GND, Black - Z PROBE IN.
                It should be easy to de-pin one end and put them back in the correct order.
                Also, your configuration is wrong. You have:
                M558 K0 P5 C"zprobe.in" H5 F120 T6000
                It should be
                M558 K0 P8 C"zprobe.in+zprobe.mod" R0.4 H5 F1200 T6000
                See https://docs.duet3d.com/Duet3D_hardware/Accessories/Smart_Effector#configuring-firmware
                mickeeyundefined 6 Replies Last reply Reply Quote 0
                • mickeeyundefined
                  mickeey @droftarts
                  This post is deleted!
                  • mickeeyundefined
                    mickeey @droftarts
                    • mickeeyundefined
                      mickeey @droftarts
                      • mickeeyundefined
                        mickeey @droftarts
                        @droftarts il mio schema pin è diverso dal tuo, ed anche il comando M558 che condividi l'ho già provato ma quando facco il il G30 la stampante sale invece di scendere. quello che ho messo mi è stato restituito dal configuratore rrf
                        • mickeeyundefined
                          mickeey @droftarts
                          @droftarts in effetti mi sono accorto che in rete ci sono schemi duet due wifi diversi. ho controllato sul sito duet ed effettivamente li è uguale al tuo. ora provo a cambiare l'ordine dei fili e scriverò qui il risultato. per ora grazie de prezioso aiuto
                          • mickeeyundefined
                            mickeey @droftarts
                            @droftarts hai ragione tu ho invertito i fili e la luce si accende. ora farò i test con G31 e poi con G30.
                            poi ho ancora il problema della ventola raffreddamento stampa che rimane sempre accesa
                            grazie del prezioso aiuto mi aggiornerò sui risultati
                              @mickeey
                              my pin scheme is different from yours, and I have already tried the M558 command that you share, but when I do the G30 the printer goes up instead of down. what I put in was returned to me by the rrf configurator
                              I noticed there was an error in the RRF configuration tool, it has been fixed so it gives the option of 'zprobe.mod' as the modulation pin for smart effector for Duet 2 WiFi.
                              in fact I noticed that there are two different wifi duet schemes on the network. I checked on the duet site and indeed it is the same as yours. now I will try to change the order of the wires and I will write the result here. for now thanks for the precious help
                              You should be using this wiring diagram: https://docs.duet3d.com/Duet3D_hardware/Duet_2_family/Duet_2_WiFi_Ethernet_Hardware_Overview#wiring-diagram
                              The only other Duet 2 WiFi wiring diagram is for prototype boards (which have a white PCB), which you don't have. It says this very clearly on that wiring diagram. We deliberately made that wiring diagram difficult to find! Yes, the probe header is wired the other way around on that one, but it was changed in 2016!
                              @droftarts you are right, I reversed the wires and the light turns on. now I will do the tests with G31 and then with G30.
                              then I still have the problem of the print cooling fan that always remains on
                              thanks for the precious help I will update on the results
                              Good, that is progress.
                              Please can you show how you have wired the cooling fan, on the Duet and on the SmartEffector. In your config.g, you have configured it to be connected to the fan0 on the Duet:
                              M950 F0 C"fan0" ; create fan #0
                              M106 P0 S0 L0 X1 B0.1 ; configure fan #0
                              Make sure the wires are plugged into fan0 on the Duet, which is the middle one of the five fan outputs:
                              fan0 on the Duet should be wired to the PF+ and PF- pins on the 2 x 3 pin black Molex Microfit 3 connector on the top of the SmartEffector. The fan should be plugged in on the bottom of the SmartEffector, to the print cooling fan header.
                              Make sure that the wires are correctly orientated for V+ and GND in each connector. Reversing the fan may cause the MOSFET that controls it to fail.
                              • mickeeyundefined
                                mickeey @droftarts
                                @droftarts 2025-04-30 ore 20.40.27_4866c4f5.jpg 2025-04-30 ore 20.40.26_bdd42128.jpg
                                • mickeeyundefined
                                  mickeey @droftarts
                                  @droftarts ho riacceso la stampante ora e la fan 0 ora rimane spenta. sembra tutto ok. un sincero grazie di cuore per l'aiuto, senza non ne sarei mai uscito.
                                  • mickeeyundefined
                                    mickeey @droftarts
                                    @droftarts said in smart effector:
                                    Ho notato che c'era un errore nello strumento di configurazione RRF, è stato risolto in modo da dare l'opzione di 'zprobe.mod' come pin di modulazione per l'effettore intelligente per Duet 2 WiFi.
                                    devo ricaricare il mio firmware sul configuratore e modificare il parametro "porta di modulazione" da nessuno a "zprobe.mod"?
                                      @mickeey
                                      do i need to reload my firmware on the configurator and change the "modulation port" parameter from none to "zprobe.mod"?
                                      You can, but unless you are going to output the set of configuration files again, you don't need to. Make sure to backup the configuration files from the Duet SD card occasionally, especially as you tune the speeds and accelerations.
                                      mickeeyundefined 1 Reply Last reply Reply Quote 0
                                      • mickeeyundefined
                                        mickeey @droftarts
                                        @droftarts non capisco il perchè ma ho acceso oggi la stampante ed il problema della ventola è ritornato
                                        • mickeeyundefined
                                          mickeey @droftarts
                                          @droftarts ho controllato e ricontrollato i cablaggi ma la ventola fan0 rimane sempre accesa. Ho comunque provato ad invertire i fili e la ventola non parte più nemmeno quando richiesto
                                            @mickeey
                                            I don't understand why but I turned on the printer today and the fan problem returned
                                            I checked and rechecked the wiring but the fan0 fan always stays on. However I tried to reverse the wires and the fan no longer starts even when requested
                                            Unfortunately, wiring a fan backwards is bad. See https://docs.duet3d.com/User_manual/Connecting_hardware/Fans_connecting#connecting-fans
                                            CAUTION!
                                            Fans are polarised. When connecting a fan to a fan connector, the fan's positive wire (usually red) must be connected to the positive pin of that connector, usually marked V_OUT+ or V_FAN+. The fan's negative wire (normally black) must be connected to the negative pin if it is a PWM controlled fan connector, usually marked out[n]- or FAN[N]-, or the GND pin if it is an always-on fan connector.
                                            If you connect the fan the wrong way round, you may damage the fan, the Duet, or both.
                                            It's possible just the MOSFET has failed. Maybe it wasn't working properly anyway. You have a spare connector (FAN2), so you could plug the fan into that, the correct way around, and change your config.g to use that pin.
                                            However, I notice your Duet 2 board has a black PCB. This is a clone board, not produced by Duet3D. We don't support that.
                                            mickeeyundefined 2 Replies Last reply Reply Quote 0
