    Core XY high speed closed loop tuning
    279
    • Tech_Sam03undefined
      Tech_Sam03 @dc42
      Yes, i run them at 48V!
      This is X axis print speed:
      (X-Print)51_2025-03-18_13.50.50.csv
      Y axis print speed:
      (Y-Print)50_2025-03-18_13.51.00.csv
      X axis travel speed:
      (X-Travel)51_2025-03-18_13.51.10.csv
      Y axis travel speed:
      (Y-Travel)50_2025-03-18_13.51.14.csv
      This is in open loop:
      Tech_Sam03undefined 1 Reply Last reply Reply Quote 0
        Tech_Sam03 @Tech_Sam03
        I wanted to get in touch again. I've put the closed loop project on hold for a while and now I want to get back to it. My main problem is the big error when accelerating and decelerating.
          dc42 administrators @Tech_Sam03
          @Tech_Sam03 what amount of error are you are getting when accelerating and decelerating, and is it during printing moves, travel moves, or both?
            Tech_Sam03 @dc42
            About */-~1.5 Steps of error in the closed Loop Tuning Plugin. I have set my error boundary to E2:3. I don't get any messages while printing, but I do get them when traveling.
              @Tech_Sam03 thank you. Is this with the Pid A term optimised for travel moves or for printing moves? What acceleration are you using for travel moves?
              Tech_Sam03undefined 2 Replies Last reply Reply Quote 0
                Tech_Sam03 @dc42
                I use a travel acceleration of 40k mm/s. I tuned it between travel and printing Speed.
                  Tech_Sam03 @dc42
                  I did a quick, rough tuning to see if I was making any mistakes.
                  Step 1 Speed and Accels
                  Speed too low
                  Speed Ok
                  Step 2 A therm
                  A too low (A30.000)
                  A therm is ok(A40.000)
                  A too heigh odd spikes in P therm(A50.000)
                  Step 3 V therm
                  V too low(V300)
                  V ok(V400)
                  V too high(V500)
                  Step 4 D therm
                  D ok(D0.1)
                  D better but to loud(D0.2)
                  Step 5 I therm
                  P20 A40.000 V400 D0.1 I0 Current tune no steady error. Do i even need a I therm because i dont really have a steady-state error?
                  I500
                  I1000
                  I1500
                  System specs:
                  -Version 3.6.0-RC3
                  -LDO 42STH48-2504AC i pressed in a longer shaft in the rotor to fit an encoder to the back
                  -48V
                  -2500A for the motors
                  -AMT10E3 encoder 2000PPR
                    @Tech_Sam03 before you added the D term you had a lot of ringing in the P term. You would also have seen this in the Current Error had you plotted it. That's an indication that the P term is too large. A small amount of ringing can be countered by adding a small D term, but as you discovered, larger D terms make the motor noisier.
                      Tech_Sam03 @dc42
                      This is the plot befor adding the D therm
                      Should i use 30-50% off the current P therm and test again?
                        @Tech_Sam03 you may not need to reduce the P term by as much as that. Try 50 to 70% of the current value.
                          Tech_Sam03 @dc42
                          I tried a P therm of 15. But i get those high peaks (Error/PID) in the accelereation segments of the move.
                            @Tech_Sam03 that plot suggests that the A term was too low or the maximum motor current too low.
