    G30 during G28 issue
    My Duet controlled machine
    1.4k
    • Leonard03undefined
      Leonard03
      Hello everyone. I got a very strange problem with homing my printer that I observed only now.
      First of all, those are my macros:
      From config.g
      M950 S0 C"!exp.heater7"
      M558 P9 C"^zprobe.in" H4:2 F240:120 T9000 A20 S0.01
      G31 P500 X-27.4 Y-28.6 Z2.00
      M557 X8.0:285.0 Y21.6:279.4 P10
      M208 X4 Y-2 Z0 S1
      if global.MMUmode = true
      	M208 U0 V-1000 W0 S1
      M208 X315 Y308 Z400 S0
      	M208 U75 V1000 W225 S0
      Homeall.g
      G91
      G1 H2 Z5 F6000
      G1 H1 X-320 Y-306 F1800
      G1 X5 Y5 F6000
      G1 H1 X-320 Y-306 F240
      G1 H1 Z-405 F240
      G92 Z0
      G90
      G1 Z5
      G1 X{(310/2)-sensors.probes[0].offsets[0]} Y{(310/2)-sensors.probes[0].offsets[1]} F6000
      G30
      G1 X0 Y0
      	M98 P"0:/sys/MMU Control/homeMMU.g"
      Homex.g
      G91
      G1 H2 Z5 F6000
      G1 H1 X-320 F1800
      G1 X5 F6000
      G1 H1 X-320 F240
      G1 H2 Z-5 F6000
      G90
      homey.g
      G91
      G1 H2 Z5 F6000
      G1 H1 Y-306 F1800
      G1 Y5 F6000
      G1 H1 Y-306 F240
      G1 H2 Z-5 F6000
      G90
      The problem occurs in homeall.g. In this macro, using the G30 command is introducing an offset of about 10mm in homing position. This doesn't sound like much but during a M916 or if I rehome the X axis during a pause, a layer shift of about 10mm occures in the X- direction.
      In any case, on PanelDue or in DWC reported coordinates ar always correct. Only the physical position is wrong. Homing only X axis, is working as it should.
      In homeall.g, with G30 at line 12:
      and with G30 commented out:
      Both photos are taken after a G1 X0 Y0.
      Duet 2 WiFi running RRF 3.6.0-rc.3
      Any clues? 😕
      Phaedruxundefined dc42undefined 2 Replies Last reply Reply Quote 0
        Phaedrux Moderator @Leonard03
        @Leonard03 said in G30 during G28 issue:
        G1 H1 Z-405 F240
        G92 Z0
        You also have a z endstop?
        Please post your full config.g and the results of M122 and M98 P"config.g"
        Leonard03undefined 1 Reply Last reply Reply Quote 1
          Leonard03 @Phaedrux
          @Phaedrux Thank you for the replay
          @Phaedrux said in G30 during G28 issue:
          Yes, is there, so why not use it 😄 When homing Z I lower the gantry until that switch is triggered and then do a G30 in the center of the bed.
          This is my full config, but it uses some additional macros
          ; Configuration file for Duet WiFi (firmware version 3.5)
          ; generated by RepRapFirmware Configuration Tool v3.2.0 on Tue Dec 29 2020 16:23:44 GMT+0200 (Eastern European Standard Time)
          global MMUmode = true										; enable or disable Multi Material Unit
          	global spoolJoin = false								; enable or disable the SpoolJoin feature of the Multi Material Unit
          	global useCutter = true									; enable or disable the CUT feature of the Multi Material Unit
          	global statusBondtech = 0
          	global statusFinda = 0
          	global currentSlot = {null, null}						; [0]last loaded slot, [1]last tool temperature
          	global loadNext = false
          	global pause = false
          	global tcBlock = false
          	global counter = {0,0,0}								; [0]extruder count, [1]fails, [2]total attempts
          global errQueue = {null,null}								; first two elements are reserved
          G90															; send absolute coordinates...
          M83															; ...but relative extruder moves
          if global.MMUmode = false
          	M550 P"Creality CR-10L"									; set printer name
          else
          	M550 P"Creality CR-10L+MMU3"
          M552 S1														; enable network
          M586 P0 S1													; enable HTTP
          M586 P1 S0													; enable FTP
          M586 P2 S0													; disable Telnet
          M569 P0 S1													; physical drive 0 goes forwards (X)
          M569 P1 S1													; physical drive 1 goes forwards (Y)
          M569 P2 S0													; physical drive 2 goes backwards (Z1)
          M569 P3 S0													; physical drive 3 goes forwards (E)
          M569 P4 S0													; physical drive 4 goes backwards (Z2)
          	M569 P5 S1												; physical drive 3 goes forwards (U)
          	M569 P6 S0												; physical drive 3 goes backwards (V)
          	M569 P7 S1												; physical drive 3 goes backwards (W)
          M584 X0														; set drive mapping for X axis
          M584 Y1														; set drive mapping for Y axis
          M584 Z2:4													; set drive mapping for Z axis (dual independent)
          	M584 E3:3:3:3:3											; set drive mapping for virtual extruders
          	M584 U5													; set drive mapping for U axis (MMU selector)
          	M584 V6													; set drive mapping for V axis (MMU pulley)
          	M584 W7 R1 S1											; set drive mapping for W axis (MMU idler)
          else
          	M584 E3													; set drive mapping for extruder
          M350 X16 Y16 Z16 E16 I1										; configure microstepping with interpolation
          	M350 U16 V16 W16 I1
          M92 X80.00 Y80.00 Z400.00 E415.00							; set steps per mm
          	M92 U400 V167.13 W8.89
          M566 X600.00 Y600.00 Z24.00 E3000.00						; set maximum instantaneous speed changes (mm/min)
          	M566 U60 V240 W6
          M203 X18000.00 Y18000.00 Z1200.00 E7200.00					; set maximum speeds (mm/min)
          	M203 U2700 V5700 W18000
          M201 X3000.00 Y3000.00 Z100.00 E3000.00						; set accelerations (mm/s^2)
          	M201 U200 V800 W1000
          M201.1 X500 Y500 Z50 E500									; set reduced acceleration for special move types (mm/s^2)
          	M201.1 U100 V400 W500
          M906 X1000 Y1000 Z800 E600 I40								; set motor currents (mA) and motor idle factor in per cent
          	M906 U700 V700 W700
          if global.MMUmode = true									; set idle timeout
          	M906 T60
          else
          	M906 T30
          M208 X4 Y-2 Z0 S1											; set axis minima
          M208 X315 Y308 Z400 S0										; set axis maxima
          M574 X1 S1 P"^xstop"										; configure active-high endstop for low end on X via pin xstop
          M574 Y1 S1 P"^ystop"										; configure active-high endstop for low end on Y via pin ystop
          M574 Z1 S1 P"^zstop"										; configure active-high endstop for low end on Z via pin zstop
          	M574 U2 S3
          	M574 V2 S3
          	M574 W1 S3
          M950 S0 C"!exp.heater7"										; create servo pin 0 for BLTouch
          M558 P9 C"^zprobe.in" H4:2 F240:120 T9000 A20 S0.01			; set Z probe type to bltouch and the dive height + speeds S0.005
          G31 P500 X-27.4 Y-28.6 Z2.00								; set Z probe trigger value, offset and trigger height
          M557 X8.0:285.0 Y21.6:279.4 P10								; define mesh grid
          M308 S0 P"bedtemp" Y"thermistor" T100000 B4092				; configure sensor 0 as thermistor on pin bedtemp
          M950 H0 C"bedheat" T0										; create bed heater output on bedheat and map it to sensor 0
          M307 H0 B1 S1.00											; enable bang-bang mode for the bed heater and set PWM limit
          M140 H0														; map heated bed to heater 0
          M143 H0 S110												; set temperature limit for heater 0 to 110C
          M308 S1 P"spi.cs1" Y"rtd-max31865"							; configure sensor 1 as thermocouple via CS pin spi.cs1
          ;M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.060000e-8	; E3D V6 thermistor (Semitec 104-GT2)
          M950 H1 C"e0heat" T1										; create nozzle heater output on e0heat and map it to sensor 1
          M307 H1 B0 S1.00											; disable bang-bang mode for heater and set PWM limit
          M143 H1 S400												; set temperature limit for heater 1 to 400C
          M950 F0 C"fan0" Q10000										; create fan 0 on pin fan0 and set its frequency
          M106 P0 S0 H-1 L0.3 C"Tool"									; set fan 0 value. Thermostatic control is turned off
          M950 F1 C"fan1+^exp.pb6" Q25000								; create fan 1 on pin fan1 and set its frequency
          M106 P1 S1 H1 T45 C"Heatsink"								; set fan 1 value. Thermostatic control is turned on
          	M563 P0 D0 H1 F0										; define tool 0
          	G10 P0 X0 Y0 Z0											; set tool 0 axis offsets
          	M568 P0 R0 S0 A0										; set initial tool 0 active and standby temperatures to 0C
          elif global.MMUmode = true
          	M563 P0 S"Slot 1" D0 H1 F0										; define tool 0
          	M563 P1 S"Slot 2" D1 H1 F0										; define tool 1
          	G10 P1 X0 Y0 Z0											; set tool 1 axis offsets
          	M568 P1 R0 S0 A0										; set initial tool 1 active and standby temperatures to 0C
          	M563 P2 S"Slot 3" D2 H1 F0										; define tool 2
          	G10 P2 X0 Y0 Z0											; set tool 2 axis offsets
          	M568 P2 R0 S0 A0										; set initial tool 2 active and standby temperatures to 0C
          	M563 P3 S"Slot 4" D3 H1 F0										; define tool 3
          	G10 P3 X0 Y0 Z0											; set tool 3 axis offsets
          	M568 P3 R0 S0 A0										; set initial tool 3 active and standby temperatures to 0C
          	M563 P4 S"Slot 5" D4 H1 F0										; define tool 4
          	G10 P4 X0 Y0 Z0											; set tool 4 axis offsets
          	M568 P4 R0 S0 A0										; set initial tool 4 active and standby temperatures to 0C
          ; Custom settings
          M81 C"pson"													; ATX in stadby mode at boot
          M308 S2 Y"mcu-temp" A"MCU"									; MCU temperature sensor (sensor 2)
          M912 P0 S-7.2												; set temperature monitor adjustment (MCU)
          M308 S3 Y"drivers" A"SD Duet"								; duet drivers temperature sensors (sensor 3)
          if global.MMUmode = true									; duet drivers temperature sensors, only when MMU is used (sensor 4)
          	M308 S4 Y"drivers-duex" A"SD DueX"
          M308 S5 P"e1temp" Y"thermistor" T100000 B4092 A"Ambient"	; Ambient teperature sensor (sensor 5)
          M307 H0 R0.135 C783.5 D0.39 S1.00 V12.2						; set the process parameters (bed 60degC)
          M307 H1 R1.757 K0.275:0.139 D6.31 E1.35 S1.00 B0 V12.2		; set the process parameters (hotend 210degC)
          M207 S0.8 F1800												; set retract length (PLA)
          M404 N1.75													; set filament width
          	M591 D0 P2 C"^e0stop" S0								; filament monitor connected to E0 endstop (Drive 0), not enabled
          M950 J1 C"^e1stop"											; Input 1 uses e2stop pin, pullup enabled (EmergencyStop button)
          M581 P1 T0 S1 R0											; external trigger 1, trigger occurs on the active-to-inactive edge, trigger at any time
          M950 J2 C"^duex.e3stop"										; Input 1 uses e2stop pin, pullup enabled (power feedback for UPS)
          M581 P2 T2 S1 R1											; external trigger 1, trigger occurs on the inactive-to-active edge, trigger at any time (UPS Backup power)
          M581 P2 T3 S0 R2											; external trigger 1, trigger occurs on the active-to-inactive edge, trigger only when not printing from SD card (AC back, resume prompt)
          M593 P"ZVD" F30.1 S0.05										; use MZV input shaping to cancel ringing at 26.35Hz, damping factor 0.1, minimum acceleration 20mm/s^2
          ;M204 P600 T800												; set printing and travel accelerations (mm/s^2) - original Creality CR-10S
          ;M204 P1000 T2000											; set printing and travel accelerations (mm/s^2) - Artillery SW-X2, https://github.com/MarlinFirmware/Configurations/tree/import-2.1.x/config/examples/Artillery/Sidewinder%20X2
          M204 P1250 T1250											; Prusa MK4
          ;M204 P1500 T2000
          M671 X-25:334 Y0:0 S2.5 F1.6								; adjusting screws at front left, back left, back right and front right. Thread pitch M4 corse: 0.7mm
          M556 S100 X0.69												; axis skew compensation, diagonal method
          	M98 P"0:/sys/MMU Control/settingsPrinter.g"
          	M98 P"0:/sys/MMU Control/settingsDefaultFilament.g"
          	M98 P"0:/sys/MMU Control/currentSlot.g"
          	M98 P"0:/sys/MMU Control/currentSlotReset.g"
          M575 P1 S1 B115200											; enable support for PanelDue
          M501														; load saved parameters from non-volatile memory
          This is the full SD card: https://drive.google.com/drive/folders/1OcTPiUw0RlYuLT-Skopb6It37nG4u9Io?usp=drive_link
          M98 P"config.g"
          This is failing short because of global variables defined at startup..
          M98 P"config.g"
          Error: in file macro line 6 column 17: meta command: variable 'MMUmode' already exists
          davidjryanundefined fcwiltundefined droftartsundefined 3 Replies Last reply Reply Quote 0
          • davidjryanundefined
            davidjryan @Leonard03
            @Leonard03
            I don't have an answer for your original issue, but...
            If you want to get your config.g to run with M98 without the error after startup, you can use the exists() function to check if the global already exists and use the result to skip defining the globals again.
            https://docs.duet3d.com/User_manual/Reference/Gcode_meta_commands
            So this,
            becomes this,
            if !exists(global.MMUmode)
            if !exists(global.errQueue)
            Then just change the true to false on line 2 to achieve the mode your desire between reboots.
            You only need to check MMUmode because if MMUmode doesn't exist, then none of the globals can exist because MMUmode is used to create all of the other globals.
              Leonard03 @davidjryan
              @davidjryan Thank you for the suggestion. I might modify all the startup in the near future. I'm still thinking about M505 to split my printer in two separate configurations. Anyway, you gave me a very good idea. Is way easy at least for now to comment out all global variables and macros that create them. So, the response is this:
              @Phaedrux
              M98 P"config.g"
              HTTP is enabled on port 80
              FTP is disabled
              TELNET is disabled
              • fcwiltundefined
                fcwilt @Leonard03
                Using it makes perfect sense.
                What is odd, at least to me, is that your homing code is written as if there is not a Z end-stop. Those G1 H2 Z# commands are not needed if you simply home Z first and leave it at a safe position for then homing X and Y.
                Now is is just my personal preference but I forgo the minor optimizations that can be done in homeALL.g by just invoking the individual homing routines:
                M98 P"homeZ.G"
                M98 P"homeX.G"
                M98 P"homeY.G"
                One other minor difference is that I don't set the Z=0 Datum during homing but only:
                • when creating a height map
                • when loading a height map
                • when starting a print
                Doing this ensures that any possible variations due to thermal changes are taken into account.
                As to the original issue I am still stumped - something is being overlooked I imageine.
                • fcwiltundefined
                  fcwilt @Leonard03
                  @Leonard03
                  One thing to remember is the some errors in config.g can cause the processing of config.g to be cut short.
                  I dealt with this by tracing the processing of config.g to make sure that it ran to completion:
                  At the start of config.g I have this local variable declared:
                  var trace = "config_trace.txt"
                  Then I create the first line of the file:
                  echo >{var.trace} "trace begun"
                  Then I add additional lines as seem appropriate at appropriate locations:
                  echo >>{var.trace} "network config"
                  echo >>{var.trace} "motor config"
                  Finally at the end of config.g I have this:
                  echo >>{var.trace} "trace done"
                  It's not much work and can save time in the long run.
                  Leonard03undefined 1 Reply Last reply Reply Quote 0
                    dc42 administrators @Leonard03
                    @Leonard03 did you ever test this system using RRF 3.6.0-rc.2; and if so, did that have the same issue?
                    I made a change to the way G30 probe coordinates are calculated between rc.2 and rc.3. It's possible that this change may have introduced a fault that is specific to Duet 2 boards.
                      Leonard03 @fcwilt
                      @fcwilt Thank you for the extensive response. I will try to answer your ideas an questions in order 😄 so:
                      @fcwilt said in G30 during G28 issue:
                      Homez.g I tried to keep it as simple as possible. Most of the time I don't use individual homing files, and every time I home XY and after Z and if MMU is enabled W V and U in that order.
                      I use the H2 parameter in home X and Y only because it allow movement of Z.
                      I use this approach only for the MMU part (UV and W) The only reason I don't use this for main axis is because I like the motion of both X and Y during homing, in tandem 😄 Running both as separate M98 calls will separate that motion, that I don't like. Aesthetics, only reason :)) Ah, and I set the Z offset only during a print using G28 because the homez.g I can use it for another thing: rough leveling the bed after disassembly. After that I use the BL touch for more accurate Z0.
                      Before any print and before bed tramming (G32) and mesh (G29) yes, i use the sensor. for anything else, the switch is good enough (another example is NonLinear Extrusion calibration. Extruding in mid air)
                      I am pretty sure that is the case..😵
                      Very good point! And I have a dumb answer to this :)) Apart of the last command regarding the config-override.g.. If my config.g gets in trouble, I know it because the PanelDue will remain not connected :)) So.. if PanelDue is is not connecting, I know that I messed something up in the config 😄
                      @dc42 said in G30 during G28 issue:
                      Thank you for your replay. I tried rc.2 now with the same result... Sadly I don't know when this behavior started. I will try with rc.1 as well and report back
                      • fcwiltundefined
                        fcwilt @Leonard03
                        @Leonard03
                        Thanks for the reply.
                        Since you have a Z end-stop homing Z first means you have no need to use G1 H2 commands.
                        Why not use the simplest code possible?
                        I understand it may be satisfying in some sense to optimize homing by coding homeALL.g discretely but that again makes the code more complicated. Also it means if you find a flaw in homing X or Y you have to makes changes in multiple places.
                        In any case it's your printer to configure as you please, just offering advice based on many years of programming experience and several years for using Duet hardware.
                        Now back to the original issue.
                        If you don't set the Z=0 Datum in the homing code, it all homes correctly?
                        When you set the Z=0 Datum in some separate code is the X position the same before and after executing the code?
                          Leonard03 @dc42
                          @dc42 Found when! Tried now old binaries that I have saved.
                          This particular issue occurred between 3.6.0-beta.2+4 (2024-12-01 18:14:39) and 3.6.0-beta.2+5 (2025-01-04 14:18:24).
                          In +4 version the X axis homes in the same location regardless of the G30. In the +5 version.. well.. is the present topic. I also have the .map files for them if they help you in any way 🙂
                            Leonard03 @fcwilt
                            @fcwilt Now, back on the 3.6.0-rc.3 😄
                            You pointed out some very interesting things, I admit!
                            Now looking at that particular macro.. I wonder the same.. Why?
                            For those two points, I don't have an answer, just an excuse :)) This macro most likely is the original generated by the RRF configurator for the version 3.2. So is quite old. But if it is not broken, don't fix it 😄 This is the excuse. But now I'm releasing that it makes no sense now.
                            This part, done. Removed the line that contained the G1 H2 command from homez.g.
                            Thank you very much for this, I really appreciate this ^_^
                            Let me see if I understand the question correctly:
                            You are referring to the G92 Z0 command, right?
                            I use it in both homez and homeall.
                            • Removing it from homez.g: no change, so another line deleted
                            • Removing it from homeall.g: no change, so another line deleted as well 😄
                              The original issue is still present, sadly..
                              As for this
                            I don't understand your question, I apologize. Plese give me a little more details so I can try out 🙂
                            • fcwiltundefined
                              fcwilt @Leonard03
                              Let's assume the current Machine Position is X=20 Y=20.
                              To verify this you will need to check in the Object Model as the DWC user interface shows User Position, not Machine Position.
                              Then execute the G30 at that position.
                              Then check the Machine Position to see if it has changed.
                                Leonard03 @fcwilt
                                @fcwilt Right, got the point!
                                I've made this little macro:
                                ; printer is homed using G28 X Y Z prior to executing this macro
                                G90
                                G1 Z10 F600 ; space for the BLTouch pin to extend
                                echo "User " ^ move.axes[0].letter ^ " position is: ", move.axes[0].userPosition
                                echo "Machine " ^ move.axes[0].letter ^ " position is: ", move.axes[0].machinePosition
                                echo "User " ^ move.axes[1].letter ^ " position is: ", move.axes[1].userPosition
                                echo "Machine " ^ move.axes[1].letter ^ " position is: ", move.axes[1].machinePosition
                                This is the result after G28 X Y Z:
                                User X position is:  4.739
                                Machine X position is:  4.739
                                User Y position is:  -2.000
                                Machine Y position is:  -2.000
                                Now, moving the nozzle 100mm in X and Y, so, G1 X100 Y100 F2400
                                User X position is:  100.000
                                Machine X position is:  99.997
                                User Y position is:  100.000
                                Machine Y position is:  100.000
                                G30 and the result:
                                User X position is:  99.285
                                Machine X position is:  99.285
                                Not exactly, but they seems to be pretty close. The physical position is way bigger
                                • fcwiltundefined
                                  fcwilt @Leonard03
                                  @Leonard03
                                  Good job.
                                  Very strange.
                                  I'm wondering at this point if there is a problem in the firmware.
                                  If I was using RC firmware (which I never do) I would resort to the last stable version prior to the RC version and see if the problem goes away.
                                    Leonard03 @fcwilt
                                    @fcwilt Thank you ^_^
                                    Digging deeper, I got something:
                                    I feel really sorry... Looking at commits on GitHub between those dates, there were many and substantial changes in RRF.. I feel sorry because only now I came across this bug (?) after so much time 😞
                                    fcwiltundefined dc42undefined 2 Replies Last reply Reply Quote 0
                                    • fcwiltundefined
                                      fcwilt @Leonard03
                                      There was a time when I would install beta or rc firmware - but no longer - I have things to print.
                                      So I am still using 3.5.4.
                                        Thanks for pinning this down to that version increment. I will review the commit history and work out the cause. It may be specific to Duet 2.
                                          @Leonard03 are you able to reproduce this issue other than in the homing file?
                                          For example: suppose you home the printer, then send G1 X150 Y150. Ignore any error that this point. Then send G30 zero or more times; then send G1 X160 Y160. Does the head position at this point (relative to where the head was after the G1 X150 Y150) depend on how many times you sent G30?
                                          PS - one more test please: if you temporarily set the probe X and Y offsets to 0 in your G31 command, does the issue still occur?
                                          PPS - created https://github.com/Duet3D/RepRapFirmware/issues/1116
                                          dc42 created this issue in Duet3D/RepRapFirmware
                                          closed G30 changing X coordinate #1116
                                            Leonard03
                                            I'm glad I can help 🙂
                                            @fcwilt @davidjryan Sorry for the delay.. Thank you guys for your help. I managed to modify my configuration, cleaned up some macros, renamed some others to make them easy to follow so now I can use the command M98 P"config.g" and you both were right. Is way better now, thank you again ^_^
                                            So far, no. Is only related to homing, with or without a probe.
                                            I will use every time the individual homing files, do some G30s at some points (I think they will change) and report back. I will use the macro above to keep track of the coordinates
