    chamber sensor for temperature monitoring
    3D Printing General Chat
    87
    • Arminasundefined
      Arminas
      How do I configure a temperature sensor without heater for temp monitor? I have seen an old post about it but I think something might changed during these 5 years.
      I have Duet 3 mini, PT1000 sensor.
      I have tried to do this:
      ;Chamber
      M308 S2 P"temp1" Y"pt1000" A"Chamber"                  ; configure sensor 2 as thermistor on pin temp1
      M950 H2 C"out1" T3                                     ; create chamber heater output on out2 and map it to sensor 2
      M307 H2 B0 S1.00                                       ; disable bang-bang mode for the chamber heater and set PWM limit
      M141 H2                                                ; map chamber to heater 2
      M143 H2 S60                                            ; set temperature limit for heater 2 to 60C
      but it does not show temp as I want, it's in the "extra" tab on DWC.
      What am I missing?
        jay_s_uk @Arminas
        @Arminas your T value is wrong in the M950. It should be T2 not T3
        Arminasundefined 1 Reply Last reply Reply Quote 1
        • Arminasundefined
          Arminas @jay_s_uk
          @jay_s_uk Thanks. how do I remove one "chamber"?
            jay_s_uk @Arminas
            @Arminas it shouldn't be showing now its bound to a heater. have you done a full restart/refresh?
            what firmware version?
            Arminasundefined 1 Reply Last reply Reply Quote 0
            • Arminasundefined
              Arminas @jay_s_uk
              @jay_s_uk Yes I have fully restarted the printer.
                jay_s_uk @Arminas
                @Arminas can you post your whole config so we can check theres nothing else wrong?
                • Arminasundefined
                  Arminas @jay_s_uk
                  @jay_s_uk
                  G90                                                    ; send absolute coordinates...
                  M83                                                    ; ...but relative extruder moves
                  M550 P"V-Core - 1"                                     ; set printer name
                  M669 K1                                                ; CoreXY
                  G21                                                    ; Set Units to Millimeters
                  G4 S2                                                  ; wait for expansion boards to start
                  M552 S1                                                ; enable network and acquire dynamic address via DHCP
                  M586 P0 S1                                             ; enable HTTP
                  M586 P1 S0                                             ; disable FTP
                  M586 P2 S0                                             ; disable Telnet
                  M569 P0.0 S0 D3                                        ; physical Z1 drive 0 goes forwards
                  M569 P0.1 S0 D3                                        ; physical Z2 drive 1 goes forwards
                  M569 P0.2 S0 D3                                        ; physical Z3 drive 2 goes forwards
                  M569 P0.3 S1 D3                                        ; physical Y1 drive 3 goes backwards
                  M569 P0.4 S1 D3                                        ; physical X1 drive 4 goes backwards
                  M569 P121.0 S1 D3                                      ; physical E  drive 121.0 goes forwards
                  M584 X0.4 Y0.3 Z0.0:0.1:0.2 E121.0                     ; set drive mapping
                  M350 X16 Y16 Z16 E16 I1                                ; configure microstepping with interpolation
                  M92 X80.00 Y80.00 Z800.00 E690.00                      ; set steps per mm
                  M906 X1700 Y1700 Z1700 E850 I30                        ; set motor currents (mA) and motor idle factor in per cent
                  M84 S30                                                ; Set idle timeout
                  M205 X5.00 Y5.00 Z1.00 E5.00 P1                        ; set maximum instantaneous speed changes (mm/s)
                  M203 X30000.00 Y30000.00 Z3600.00 E7200.00             ; set maximum speeds (mm/min)
                  M201 X6000.00 Y6000.00 Z100.00 E3000.00                ; set maximum accelerations (mm/s^2)
                  M204 P2000 T6000                                       ; set printing and travel acceleration
                  M208 X0 Y0 Z-1 S1                                      ; set axis minima
                  M208 X413 Y405 Z405 S0                                 ; set axis maxima
                  M671 X0:203.5:408.7 Y0.5:409:0.5 S5                    ; define positions of Z leadscrews or bed levelling screws
                  M556 S100 X0.487                                       ; axis skew compensation
                  M574 X1 S1 P"121.io2.in"                               ; configure active low endstops
                  M574 Y2 S1 P"io0.in"                                   ; configure active high endstops
                  M574 Z1 S2                                             ; configure Z-probe endstop for low end on Z
                  M308 S0 P"temp0" Y"thermistor" T100000 B3950 A"Bed"    ; configure sensor 0 as thermistor on pin temp0
                  M950 H0 C"out0" T0 Q50                                 ; create bed heater output on out0 and map it to sensor 0
                  M307 H0 R0.519 K0.357:0.000 D2.77 E1.35 S1.00 B0       ; disable bang-bang mode for the bed heater and set PWM limit
                  M140 H0                                                ; map heated bed to heater 0
                  M143 H0 S110                                           ; set temperature limit for heater 0 to 110C
                  ;Chamber
                  M950 H2 C"out1" T2                                     ; create chamber heater output on out2 and map it to sensor 2
                  M563 P0 D0 H1 F1                                       ; define tool 0
                  G10 P0 X0 Y0 Z0                                        ; set tool 0 axis offsets
                  G10 P0 R0 S0                                           ; set initial tool 0 active and standby temperatures to 0C
                  M308 S1 P"121.temp1" Y"PT1000" A"Hotend"
                  M950 H1 C"121.out0" T1                                 ; create nozzle heater output on out0 and map it to sensor 1
                  M307 H1 R6.849 K1.009:0.000 D0.86 E1.35 S1.00 B0 V23.7 ; disable bang-bang mode for heater and set PWM limit
                  M143 H1 S350                                           ; set the maximum temperature in C for heater
                  M950 F0 C"!121.out1+out1.tach" Q500                    ; create fan 1 on pin out4 and set its frequency
                  M106 P0 C"Layer Fan" S0 H-1                            ; set fan 1 name and value. Thermostatic control is turned off
                  M950 F1 C"121.out2" Q500                               ; create fan 0 on pin out3 and set its frequency
                  M106 P1 C"Hotend Fan" S1 H1 T45                        ; set fan 0 name and value. Thermostatic control turned on for Hotend
                  M950 F2 C"out6" Q500                                   ; create fan 2 on pin out6 and set its frequency
                  M106 P2 C"Duet fan" S1 H-1                             ; set fan 2 value. Thermostatic control is turned off
                  ; BLTouch
                  M950 S0 C"121.^io0.out"                                ; Create a servo pin on 121.io0
                  M558 P9 C"121.^io0.in" H5 F240 T10800 A5               ; set Z probe type to unmodulated and the dive height + speeds
                  G31 P25 X-30 Y-14.50 Z2.55                             ; set Z probe trigger value, offset and trigger height, more Z means closer to the bed
                  ; Accelerometer LIS3DH and Input shaping
                  M955 P121.0 I10                                        ; specify orientation of accelerometer on Toolboard 1LC with CAN address 121
                  M593 P"mzv" F35
                  M404 N1.75 D0.4                                        ; Filament width and nozzle diameter
                  T0
                  M572 D0 S0.05
                  jay_s_ukundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                    jay_s_uk @Arminas
                    @Arminas nothing jumps out at me so its one for @chrishamm to comment why there is a second sensor showing up on the extras tab for the chamber
                      droftarts administrators @Arminas
                      @Arminas I can provoke this, in DWC/RRF 3.6.0-rc.3. From a normal startup, with no chamber defined in config.g, If I send the following in the console:
                      • M308 S2 P"temp1" Y"pt1000" A"Chamber" - creates a "Chamber" entry in the Extras part of "Tools + Extras", appears on graph
                      • M950 H2 C"out1" T2 - creates a second "Chamber" in the graph, removes the Chamber entry in "Extras", but as it's not defined as a hotend, bed or chamber, it doesn't show under "Tools"
                      • M141 H2 - "Chamber" appears under "Tools". Still two Chamber lines on the graph, no entry on "Extras".
                      If I restart the Duet, so no chamber is configured, the "Tools" list gets updated, but the graph still shows two "Chamber" lines (though no line is visible now).
                      However, reloading/refreshing the DWC page in the browser removes any "Chamber" entries, and shows correctly what is configured. So it seems it is an issue of persistence of the settings in the temperature graph DWC, even after the board reboots, until the page is refreshed.
                      I'll check with @chrishamm if this can be fixed.
                      • Arminasundefined
                        Arminas @droftarts
                        @droftarts after a few reboots it's okay now
                          @Arminas Like I said, it's a browser-side issue, so refreshing the DWC browser page should fix it.
                          • Arminasundefined Arminas marked this topic as a question
                          • Arminasundefined Arminas has marked this topic as solved
