When homing Z motors the hotend and heatbed lose temp
Hello again,
I have a Duet 3 6HC first version and I'm using all steppers drivers included on it... 4 for the Z axis (I have 4 steppers) and the other 2 for X and Y.
When Z is homming the temperature of hotend and heatbed starts going low until it stops... I alredy put a new power supply with a lot of more amperes but problem persists... so I really don't know if it's something that board can't manage or other thing.
Thank you for your help
Check the options in your M558 command, there is a parameter (B) to pause heaters during the probing move. This is due to the potential for magnetic fields that may affect certain probes.
https://docs.duet3d.com/User_manual/Reference/Gcodes#m558-set-z-probe-type
Bn If 1, turn off all heaters while probing, default (B0) leaves heaters on.
@Phaedrux Tottaly right, thank you! I think I my partner did that for the heatbed mesh calibration and didn't told me.
undefined droftarts marked this topic as a question
undefined droftarts has marked this topic as solved
