Extruder skips mid print randomly/Infill pattern problem
53
7.4k
    Saltlife716
    So I've been working on these problems for about a week now.
    Problem 1:
    Finally got the first layer to lay down decently, but randomly throughout the entire print the extruder will quickly jerk back like 5-10mm filament, and as you can see, ruins the print.
    Test Cube1.1 by Sammy Saltalamacchia, on Flickr
    Problem two:
    This infill is set to Full Honeycomb using S3D, and it looks like fast honeycomb starting in different directions.
    Test Cube1 by Sammy Saltalamacchia, on Flickr
    config.g:
    ; Configuration file for Duet WiFi (firmware version 1.20 or newer)
    ; generated by RepRapFirmware Configuration Tool on Mon Jan 01 2018 09:06:20 GMT-0500 (Eastern Standard Time)
    M111 S0 ; Debugging off
    G21 ; Work in millimetres
    G90 ; Send absolute coordinates…
    M555 P1 ; Set firmware compatibility to look like RepRapFirmare
    M665 R252.412 L450 B145 H407.9 ; Set delta radius, diagonal rod length, printable radius and homed height ;was R252.412 L450 B145 H407.9
    M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them ;was X0 Y0 Z0
    M208 Z0 S1 ; Set minimum Z
    M574 X2 Y2 Z2 S1 ; Set active high endstops
    M558 P4 X0 Y0 Z0 F2400 I0 T6000 ; Set Z probe type to switch and the dive height + speeds; removed H15
    G31 P200 Z-0.811 ; Set Z probe trigger value, offset and trigger height
    M557 R150 S20 ; Define mesh grid
    M569 P0 S0 ; Drive 0 goes backwards
    M569 P1 S0 ; Drive 1 goes backwards
    M569 P3 S1 ; Drive 3 goes backwards
    M92 X80 Y80 Z80 E92.5 ; Set steps per mm
    M566 X1200 Y1200 Z1200 E1200 ; Set maximum instantaneous speed changes (mm/min)
    M203 X18000 Y18000 Z18000 E1200 ; Set maximum speeds (mm/min)
    M201 X5000 Y5000 Z5000 E1000 ; Set accelerations (mm/s^2)
    M906 X1000 Y1000 Z1000 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M305 P1 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 1
    M563 P0 D0 H1 ; Define tool 0
    M550 PMy Guys v1.0 ; Set machine name
    M552 S1 ; Enable network
    M587 S"The Salt's-2G" P"TheGoodLife!0716!" ; Configure access point. You can delete this line once connected
    M586 P0 S1 ; Enable HTTP
    M586 P1 S0 ; Disable FTP
    M586 P2 S0 ; Disable Telnet
    M106 P0 S0.3 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
    M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
    M106 P2 S1 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
    M501 ;Use config-override.g
    BI v2\. 5 Heavily modded
    Duet Wifi
    E3D v6 0.20mm
    FSR autoleveling
      Saltlife716
      Update: Changed to a .4 nozzle and having same issue, as well as the corners.
      I have a video of the extruder kinda like twitching backwards for a second. Just not sure how to post it in here. Here's the video i uploaded.
      https://flic.kr/p/FkbTVq
      Test Cube2 by Sammy Saltalamacchia, on Flickr
      Test Cube 2.1 by Sammy Saltalamacchia, on Flickr
      Duet Wifi
      E3D v6 0.20mm
      FSR autoleveling
        Saltlife716
        Update: Doing an extrusion width test. Strange enough, the filament is not skipping when only walls are printed.
        Duet Wifi
        E3D v6 0.20mm
        FSR autoleveling
          burtoogle
          What temps and speeds are you using? Perhaps you're asking the extruder for more than it can deliver?
            Saltlife716
            Update:
            Verified first layer height is correct at 0.20mm +/-.01.
            Changed extrusion width to 0.88. Extrusion now set correctly.
            Re-added top/bottom layers and infill. Still skipping.
            Duet Wifi
            E3D v6 0.20mm
            FSR autoleveling
              Saltlife716
              @burtoogle:
              Bed is 60, I was running temp at 190, then bumped it up to 200, just just weird. Yea it's just weird to me how the motor itself is jerking back the filament.
              I've changed default speed from 3600mm/min all the way down to 1500mm/min, still does it abut the same amount through out the print
              Duet Wifi
              E3D v6 0.20mm
              FSR autoleveling
                Saltlife716
                0.40mm nozzle, extrusion multiplier is at 0.88mm, extrusion width is at 0.48mm, layer is at 0.20mm
                Duet Wifi
                E3D v6 0.20mm
                FSR autoleveling
                  okercho
                  Have you calibrated your extruder steps? Maybe you're extruding more than expected, or maybe the current is not enough.
                  Are you sure mechanics is OK? I had that kind of extruder problems in the past due to several causes:
                  • Extruder not perfectly aligned with the extruder support (causes friction, so is harder to push)
                  • Bowden tube dirty (Not sure if you use bowden)
                  • Bad quality filament (bigger than expected, more friction inside Bowden tube… I've struggled a lot with this... spending a lot of time trying to print something, and then, change to another filament and printing it first try without issues...)
                  • Bad bed calibration (if the nozzle is closer to the bed than it should, motor struggle to push, it jumps, and there you have the several lines failure)
                  • E3d fan not working (yup, it happened to me... I need to disable it for bed levelling to avoid noise, and I've forgot to enable it again... now I'm using a macro to avoid those silly mistakes xD), this causes clogs in the hotend due to excessive heat in the heatbreak
                  • Clogged or partially clogged nozzle
                  I know how frustrating this can be... I had tons of weird issues =_=...
                  Cheers!
                  Okercho
                  Custom Prusa i3 Hephestos with Duet Wi-Fi
                  E3d V6 with Bondtech BMG DirectDrive and PrecisionPiezo Sensor
                  Rebuilding Hypercube Evolution
                    Saltlife716
                    @okercho:
                    Cheers!
                    -Yes extruder has been calibrated, is pushing exactly 100mm when i push 100mm through.
                    -Bowden tube is brand new.
                    -It's brand new Hatchbox PLA 1.75mm (measuring at an average between 10 at 1.71mm
                    -Bed is completely level, as far as the middle part where i'm printing. getting a solid 0.20 first layer.
                    -The E3D fan is definitely working
                    -The 0.25mm nozzle I was using was brand new, and swapped it out for another brand new 0.25mm nozzle, then just recently swithed to a brand new 0.4mm nozzle.
                    -Extrusion multiplier is 100% correct. I calibrated 3 times in a row this morning
                    Yea I mean this isn't my first printer or first Delta printer. I know quite a bit, but i'm far from an expert. And i've literally changed everything that I know how to that would have something to do with it. I'm just stumped.
                    Duet Wifi
                    E3D v6 0.20mm
                    FSR autoleveling
                      Does the problem occur at the same point each time you print the same GCode file, or at different points?
                      How have you connected to the printer: via networking, USB, or both?
                      What type of extruder are you using?
                        Saltlife716
                        The problem occurs at random times, more frequently during the first and/or second solid layer and infill.
                        I have connected both ways, but never at the same time. Mainly through the network.
                        I am using the SeeMeCNC EZ Struder.
                        Duet Wifi
                        E3D v6 0.20mm
                        FSR autoleveling
                          Saltlife716
                          Here's a print I just did, it's all kinds of crazy
                          Test Cube3 by Sammy Saltalamacchia, on Flickr
                          Duet Wifi
                          E3D v6 0.20mm
                          FSR autoleveling
                            Saltlife716
                            Extruder tab by Sammy Saltalamacchia, on Flickr
                            Layer tab by Sammy Saltalamacchia, on Flickr
                            Infill tab by Sammy Saltalamacchia, on Flickr
                            G-code tab by Sammy Saltalamacchia, on Flickr
                            config.g:
                            M665 R252.412 L450 B145 H416.55 ; Set delta radius, diagonal rod length, printable radius and homed height ;was R252.412 L450 B145 H416.55
                            Duet Wifi
                            E3D v6 0.20mm
                            FSR autoleveling
                              It's probably not related to your problem, but for RRF we recommend you check "Relative extrusion distances", un-check "Allow zeroing of extrusion distances", and include M83 in your slicer start GCode script.
                                Saltlife716
                                @dc42:
                                As you said it doesn't seem to be related to the issue, but I did make the suggested changes. Thanks.
                                Duet Wifi
                                E3D v6 0.20mm
                                FSR autoleveling
                                  Saltlife716
                                  Another print.
                                  Test Cube4 by Sammy Saltalamacchia, on Flickr
                                  Duet Wifi
                                  E3D v6 0.20mm
                                  FSR autoleveling
                                    Saltlife716
                                    I managed to get the print better, but the skipping that is happening is still ruining the prints. Any ideas?
                                    Duet Wifi
                                    E3D v6 0.20mm
                                    FSR autoleveling
                                      BDubs
                                      @Saltlife716:
                                      Check your extruder stepper wires. It is possible you're only running on one coil because one wire is off , broken or otherwise disconnected. Also check you've got your current for that motor high enough.
                                        deckingman
                                        I just had a look at the video and it looks a bit to me like the extruder does a retract but it's not followed by an unretract. Very odd behaviour…...
                                        Check through the gcode file and see if you can spot any negative extruder moves that are not immediately followed by a positive extruder move. It looks like you are using 8mm retraction (which is a bit high) so you'll be looking for something like G1 E-8 followed by G1 E8.
                                        Thinking about it a bit more, another possibility is that you are suffering from heat creep, causing the filament to swell in the area of the heat break. So when you do a (8mm) retract, it pulls some of the molten filament up beyond the heat break where it partially solidifies, binds, and prevents the extruder from pushing the filament back down during what should be the unretract move. A quick test would be to set retraction to zero (ooze control), slice it like that and see if things improve.
                                        HTH
                                          Ian's post alerted me to the fact that you posted a video, which I hadn't noticed before. I'm fairly sure that your extruder drive is skipping steps because it isn't producing enough drive force. That's why it doesn't skip on the outlines, because they are printed more slowly so less force is needed.
                                          You are using an ungeared extruder, so this is not unusual. What model of stepper motor are you using to drive it? I see that you have the extruder motor current set to 800mA. If that's less than 85% of the stepper motor rated current, try increasing it.
                                          3 out of 53
