    Gcode for test BlTouch
    13.8k
    • peirofundefined
      peirof
      While Mini Ir arrives, i am testing BlTouch, that i have discarted….
      In this moment i have wired.... following the guide, i have found in facebook group, and seems works of all test...
      The only issue, that i do not know its is normal, when i haved instaled Mini IR, in Duet Web Control, start page, z.probe, indicates a numeric valor if zprobe was triggered.
      With BlTouch the field Z-probe, ever show 0....
      i have made a macro for test probe, this:
      [[language]]
      G91
      G0 X-50 Y-50 Z-50 F500 S1
      G90
      I am not sure if the flag S1, stop movement when BlTouch its triggered.
      What would be the order to move the head, and stop the movement if the zprobe is triggered?
      Thanks
      • Scachiundefined
        Scachi
        The BlTouch signal on triggering is very fast/short so you won't see a value in the web control.
        To run a single height test I do
        [[gcode]]
        G30 S-1
        ```that tests/reports the trigger height for the current x/y position.
        To test if it works use your hand or an object somewhere above your plate so you have time to switch of the power or hit the emergency stop button before it drives hard into the plate
        As I have to Z axis motors, I use this macro to test if the bed is level:
        [[gcode]]
        G1 Z10 X5 Y105
        M401
        G30 S-1
        M402
        G1 Z10 X205 Y105
        M401
        G30 S-1
        M402
        • peirofundefined
          peirof
          works… a half, why?
          1- Power on printer
          2- Home all
          3- Send the gcode: G30 S-1 --> and put some obstacle for test, nozzle downs slow, and when BlTouch reach obstacle, retracts, and stop down.... PEFERCT.
          4- In Web Interface, order to "AUTO DELTA CALIBRATION".... and the problems, nozzle start to down fast, and when reach bed...HEAD CRASH, and power off.
          I dont know for what, i think it's because of the speed, but I'm not sure.
          ¿Ideas?
          ¿Can change the speed nozzle displaces when i order "AUTO DELTA CALIBRATION"? How? Where?
            You probably have an inaccurate H (homed height) or R (delta radius) parameter in your M665 command. Until you have accurate values, try increasing the dive height, which is the H parameter in the M558 command. For example, a value of 40 will stat to probe from 40mm above where the firmware thinks the bed is.
            Once you have established your M665 parameters and written them into config.g, you can reduce the M558 H parameter again to speed up bed probing. The default is 5mm.
            • peirofundefined
              peirof
              Later try….
              Another question, when send calibrate order by Duet Web Interface... Nozzle go to the bed, I seems very fast. There is some kind of dorm to reduce this speed?
              Until I haven't adjusted probe, I am interested in Duet do the calibration process slow..
              • peirofundefined
                peirof
                In forum, I have read this
                The M558 F parameter controls the speed of probing, and the T parameter controls the speed of travel moves between probe points.
                This can solve my issue?
                Its for calibration or/and compensation?
                • peirofundefined
                  peirof
                  Regards,
                  I expose here my reasoning about configuring Zprobre BlTouch in Duet, so you can tell me which ones are wrong …
                  Starting points
                  1- My BlTouch, is the v2, Smart version, and I have cut back to transform it 3.3V
                  2- I made the connections between BlTouch and Duet Wifi, according to the scheme, which I attach.
                  3- The BlTouch sensor I think works correctly, because when I send the code "G30 S-1" by console, the head starts to descend, until I put an obstacle
                  4- Accustomed to in DUET WEB INTEFACE, see the value of ZProbe when it was close to an object. I find it strange not to read any value. This is normal?
                  Things that DO NOT work.
                  A- When I give the order, by DUET WEB INTERFACE, of autocalibracion. The head drops very fast, I think too much, and hits the bed. (Luckily I put a metal plate …)
                     B- At that moment I cut the current, I do not trust to continue with the autocalibration. But it seems to me like I'm going to look for another point.
                  Theory of why they can be:
                  A- David, tells me that it may be that he misses the values of M665, where is the geometric configuration of the printer, I doubt that is that, since, although it may have inaccuracies, are taken from the group of Facebook, Tevo Little Monster Duet
                     B- To reduce the speed, I think excessive, with which the head low to start calibrating. Would it be sufficient to include parameter F500 on line M558, of config.g?
                     C- There is a parameter, on line M558, of config.g, which may also have the key:
                           1- The parameter H, which defines where the firmare thinks the bed is, according to David I have to upload it to about 40mm to start, then reduce it.
                  D- If I adjust G31 Z (Distance between nozzle tip and extended BlTouch)
                  Please, comments
                  • peirofundefined
                    peirof
                    I update with new tests….
                    I have edited M558 line:
                    [[language]]
                    M558 P5 X0 Y0 Z0 H22 F120 T600
                    ```A- The speed T600 much, much better
                    B- I have raised H until H40, and test calibrate, nozzle down (slow T600) and when isfar from bed, stops to go down, and go, to, suppose first point of calibration, after second, and so on…. But how ir far from bed.... nothing
                    C- I have go down H, in steps, until BlTouch, arrives to bed... but when BlTouch arrives to bed, nozzle dont Stops, and head crass.
                    And another one:
                    Yesterday, the gcode G30 S-1, works, after these changes, i recive this message.... [c]Error: Z probe already triggered at start of probing move, and probe its not triggered, and pin is downs.
                    [/c]
                    Think i am close….but....not in place...
                    Tips please
                      @peirof:
                      [[language]]
                      And another one:
                      [/c]
                      Tips please
                      In the Z probe reading box in Duet Web Control, are you getting a reading of 1000 all the time? If so then the BLTouch black and white wires are not connected to the Z probe connector correctly.
                      • peirofundefined
                        peirof
                        I am not In home now, later try.
                        These can explain that gcode [c]G30 s-1[/c] works and calibration for web interface fault?
                        • peirofundefined
                          peirof
                          What are the numbers I have to see in DUET WEB CONTROL/Zprobe, when:
                          • Bltouch is triggered
                            Or
                          • Bltouch is released
                          In this moment, I can read 1000 when is triggered, with Grey background
                            The value when not triggered should be 0 if it is connected correctly. You definitely do not need I1 in the M558 command for bltouch. The bltouch produces only a short pulse when it triggers, so you probably won't see a different value when it triggers. If you are lucky, you might see it rise above zero sometimes when it triggers.
                            • peirofundefined
                              peirof
                              Still no work….
                              Why when send by console [c]G30 S-1[/c], and out and obstacle, paper, bltouch triger, and stops….
                              But when send the [c]Calibrate by DWI[/c], dont stops????
                              If when i send [c]G30 S-1[/c], the head stops…. must be a configuration issue?
                              BlTouch its working well, no?
                              • peirofundefined
                                peirof
                                Lets thinking….
                                if it was working correctly, what should the printer do?
                                1- Homing
                                2- The Nozzle goes down to find the bed, at a speed T600 (in this case)
                                3- When BlTouch touches the bed, the Nozzle stops going down, and goes up. How much does it rise?
                                4- It moves horizontally to the next point defined in bed.g.
                                5- Go back down, until the BlTouch plays ....
                                and this process for all points in bed.g ....
                                It would be like this?
                                which can cause the head to NOT stop going down when the BlTouch is playing? Assuming it is working, since the G30 S-1 command works
                                Is there any other way to prove that the BlTouch works?
                                There was not a form of relative movement, which stopped when the BlTouch (ZProbe) was activated ???
                                • Scachiundefined
                                  Scachi
                                  Maybe this helps you.
                                  This are my config.g lines for bltouch
                                  [[language]]
                                  M307 H7 A-1 C-1 D-1 ; disable heater7 free it up for pwm control for bltouch
                                  M558 P5 X0 Y0 Z1 H3 F100 T500; Set Z Probe to type Switch or Digital output where Z probe connector is used. Used for z only. ; bltouch
                                  G31 P25 X0 Y-15 Z1.00 ; Set Z probe trigger value, offset and trigger height - bltouch
                                  M557 X5:205 Y5:205 S20 ; Define mesh grid
                                  M376 H3.0 ; taper of height compensation above this mm value
                                  This is my home.z:
                                  [[language]]
                                  ; Lift Z relatively to current position
                                  G91
                                  G1 Z5 F1000
                                  ; Back to absolute positioning - mid of bed
                                  G90
                                  G1 X105 Y120 F3000
                                  ; Move Z down until the switch triggers
                                  G30
                                  ;G91
                                  G1 Z5 F100
                                  ;G90
                                  • peirofundefined
                                    peirof
                                    @Scachi:
                                    [[language]]
                                    This is my home.z:
                                    [[language]]
                                    G91
                                    G1 Z5 F1000
                                    G90
                                    G1 X105 Y120 F3000
                                    G30
                                    ;G91
                                    G1 Z5 F100
                                    ;G90
                                    Thanks, later try, now i am not in home, and give feedback
                                    • peirofundefined
                                      peirof
                                      Sachin, one question of your config…
                                      You have in config.g, this line
                                      [[language]]
                                      Z… Is the distance between, nozzle and Bltouch... When is deployed? No, in your config... You have Bltouch deployed under nozzle 1mm. No?
                                        In firmware 1.19 and earlier, Z1 in the M558 just means that the Z probe is used in lieu of a Z endstop switch. In firmware 1.20 and later it is ignored, because that option is set in M574 instead. But in fact it isn't necessary to tell the firmware to substitute the Z probe for the Z endstop switch at all, assuming you set up your homing files correctly to use G30 to do Z homing.
                                        The Z probe trigger height is set in the G31 command.
                                        • peirofundefined
                                          peirof
                                          I have installed firmware 1.20….
                                          Whats the correct configuration.g?
                                          Someone using Bltouch, and firmware 1.20, can post his working configuration?
                                            The configuration that Scachi posted should work with 1.20 too.
