Are Z Motors slipping or are motors worthless?
1.7k
    Martin_S
    Maybe you are trying to move them too fast?
    David provided a spreadsheet to work out the speed at which torque starts to drop off:
    https://www.dropbox.com/s/5z66rgjc8gptn5o/StepperMotor.ods?dl=1
    EDIT: It was found here: https://duet3d.com/wiki/Choosing_stepper_motors
    If it ain't broke, fix it till it is =)
      Yes, you probably have the acceleration or max speed set too high. My Ormerod has 4000 Z steps/mm and I have these settings:
      M201 X1200 Y1200 Z20 E1000 ; set accelerations
      M203 X12000 Y12000 Z250 E3600 ; set XYZ and extruder speeds
      M566 X1800 Y1800 Z40 E300 ; Maximum instantaneous speed changes mm/minute
        deckingman
        Are your lead screws single start? The pitch is meaningless, it's the lead that is important. It just happens that with single start threads the lead happens to be the same as the pitch so many people use the term pitch for lead. So for example if the screws were two start 1.5mm pitch, then the lead would be 3mm, for 4 start it's 6mm etc.
        Assuming they are single start screws, with 1.5mm lead then for a 1.8 degree motor (200 steps per rev) the steps per mm at 16X micro stepping would be 200/1.5*16 = 2133.333. As you are using 4266.667 then that would indicate that you are using 0.9 degree motors (400 steps per mm) and 16X micro stepping and that your screws are single start 1.5mm lead. Is that correct?
          Synapsis
          Thanks for the info will check as soon as I get home from work.
          Ian will let you know specifics for the lead screws. I got them on motedis and yes I 'm using 0.9 degree motors.
          If i rememer correctly the screws are 8 mm and the pitch is 1.5 mm.
          If if can get thinks all set and my last piece arrives I will do a test print this weekend.
            deckingman
            It's a bit unusual to find multi start screws in 8mm diameter so they are most likely to be single start and in that case 1.5mm lead. Generally, if a only a pitch is specified but no "lead" then it's usually a sign that they are single start and the lead is the same as the pitch (although it remains a pet hate of mine that "pitch" is used when referring to lead screws). The important thing to know is how far a nut would travel along the screw in one revolution - that is the lead. The pitch is merely the distance from one thread peak to another.
              If you are using 0.9deg motors on the Z axis then the speed may be voltage-limited, especially if you are using 12V power. See the link that Martin_S posted earlier.
                Synapsis
                Hi and thanks to all for your help,
                the settings were way out of tune slowed down using david's setting and now it does not slip or lose torque
                I also put back in the 4266.667 setting for the Z motors.
                here is the lead screw I am using right now
                Ian from your calculations does that mean the setting is correct? So if i set movi 1 mm its moves one mm.
                Will do some test to see.
                Motors are
                rated current 2.4
                phase resistance 1
                phase inductance 1.8
                holding torque gcm 4200
                lead wires 4
                rotoe inertia 68
                detent torque 220
                usings Martin_S's link i get this
                Motor characteristics Notes
                Motor full step angle (degrees) 0,9 Normally 1.8 or 0.9
                Phase inductance (mH) 1,8
                Phase resistance (ohms) 1
                Rated current (A) 2,4
                Holding torque at rated current (N.cm) 42 To convert Kg.cm to N.cm, multiply by 9.8
                How you are using them
                Steps/mm @ 16x microstepping 160 Specify this at x16 microstepping even if you are using a different microstepping
                Factor for printer geometry 1,7 1 for Cartesian, 1.414 for CoreXY, approx. 1.7 for delta
                Actual current (peak per phase) 1 Usually 60% to 85% of rated current
                Number of motors connected in series 1
                Driver supply voltage 12 Usually 12 or 24
                Driver voltage drop 1 Usually about 1V
                Results
                Speed at which torque starts to drop (mm/sec), low slip angle 143.2 These are for the worst case moves (diagonal move for CoreXY, radial move opposite a tower for a delta)
                Step pulse frequency at this speed and x16 microstepping 39,0
                Speed at which torque starts to drop (mm/sec), high slip angle 189.7
                Step pulse frequency at this speed and x16 microstepping 51,6
                  deckingman
                  @Synapsis:
                  ….............I also put back in the 4266.667 setting for the Z motors.
                  '''''''''''''''Ian from your calculations does that mean the setting is correct? So if i set movi 1 mm its moves one mm.
                  Short answer - Yes.
                  Long answer - the drawing is a bit naff but as there is no information as to the number of thread starts (1,2 or 4 being the most common in that order) then it's probably safe to assume that it's single start. If it was 2 start, then you'd get twice the amount of movement for the steps per mm that you have, but it would also require twice the torque, which in a long rambling way, brings me back to the reason I asked in the first place. i.e. a course lead screw requires more torque to move it than a fine lead screw.
                  BTW. With that lead, and those motors 400 full steps gives you 1.5 mm of movement. So 1mm would take 266.666 recurring full steps and 0.1 mm would take 26.666 recurring full steps. It's generally not a good idea to rely on micro-stepping for positional accuracy so I suggest you use layer heights that can be achieved using full steps. Use multiple of 0.03 mm because 0.03 mm would use 8 full steps. So 0.09 is good as it uses 24 full steps, but 0.1 is not so good as it uses 26.666 recurring. 0.2mm layer height uses 53.3333 full steps but 0.18 or 0.21 are both good as they use even multiples, and what is probably the most common layer height of 0.3mm is also good.
                  HTH
                    Synapsis
                    Great thanks for all the help, just tell me when you say use layer heights like 0.3mm are you talking about the slicer?
                    also what is the best all around slicer?
                      Rgconner
                      @Synapsis:
                      Not 0.3.
                      0.03
                        Rgconner
                        @deckingman:
                        8mm 4 start leadscrews are pretty much the defacto standard for Prusa and it's clones.
                        https://www.google.com/search?q=t8+lead+screw+8mm&ie=utf-8&oe=utf-8&client=firefox-b-1
                          Synapsis
                          Sorry my bad, 0.03 it is. 🙂
                            deckingman
                            @Synapsis:
                            Multiples of 0.03 for your lead screws.
                            You wouldn't want to print with a layer height of 0.03 mm as it is much too small unless you have a really tiny nozzle diameter like 0.1mm. As a rule of thumb, selecting a layer height that is about 70% of the nozzle diameter will give the best compromise between quality and speed. As the most common nozzle sizes are 0.4mm and 0.5mm, then most people choose a layer height of 0.3mm which will work fine for you. However, for more detailed parts people often reduce the layer height to 0.2 or even 0.1 mm. These values wouldn't be ideal for you, as you would then be relying on micro stepping for positional accuracy. So instead of 0.1mm choose either 0.09 or 0.12 and instead of 0.2m choose either 0.18 or 0.21mm.
                            HTH
                              deckingman
                              @Rgconner:
                              Really? Sorry my bad - I didn't know that. I'd have thought that Prusa would have had more sense. (for the reasons set out in my blog here https://somei3deas.wordpress.com/2017/01/31/z-axis-lead-screws/))
                                Synapsis
                                Thanks Ian for the additional info, also read your blog. Well written asnd I liked it.
                                11 out of 16
