    Gcode for test BlTouch
    13.8k
    • peirofundefined
      peirof
      Still no work….
      Why when send by console [c]G30 S-1[/c], and out and obstacle, paper, bltouch triger, and stops….
      But when send the [c]Calibrate by DWI[/c], dont stops????
      If when i send [c]G30 S-1[/c], the head stops…. must be a configuration issue?
      BlTouch its working well, no?
      • peirofundefined
        peirof
        Lets thinking….
        if it was working correctly, what should the printer do?
        1- Homing
        2- The Nozzle goes down to find the bed, at a speed T600 (in this case)
        3- When BlTouch touches the bed, the Nozzle stops going down, and goes up. How much does it rise?
        4- It moves horizontally to the next point defined in bed.g.
        5- Go back down, until the BlTouch plays ....
        and this process for all points in bed.g ....
        It would be like this?
        which can cause the head to NOT stop going down when the BlTouch is playing? Assuming it is working, since the G30 S-1 command works
        Is there any other way to prove that the BlTouch works?
        There was not a form of relative movement, which stopped when the BlTouch (ZProbe) was activated ???
        • Scachiundefined
          Scachi
          Maybe this helps you.
          This are my config.g lines for bltouch
          [[language]]
          M307 H7 A-1 C-1 D-1 ; disable heater7 free it up for pwm control for bltouch
          M558 P5 X0 Y0 Z1 H3 F100 T500; Set Z Probe to type Switch or Digital output where Z probe connector is used. Used for z only. ; bltouch
          G31 P25 X0 Y-15 Z1.00 ; Set Z probe trigger value, offset and trigger height - bltouch
          M557 X5:205 Y5:205 S20 ; Define mesh grid
          M376 H3.0 ; taper of height compensation above this mm value
          This is my home.z:
          [[language]]
          ; Lift Z relatively to current position
          G91
          G1 Z5 F1000
          ; Back to absolute positioning - mid of bed
          G90
          G1 X105 Y120 F3000
          ; Move Z down until the switch triggers
          G30
          ;G91
          G1 Z5 F100
          ;G90
          • peirofundefined
            peirof
            @Scachi:
            [[language]]
            This is my home.z:
            [[language]]
            G91
            G1 Z5 F1000
            G90
            G1 X105 Y120 F3000
            G30
            ;G91
            G1 Z5 F100
            ;G90
            Thanks, later try, now i am not in home, and give feedback
            • peirofundefined
              peirof
              Sachin, one question of your config…
              You have in config.g, this line
              [[language]]
              Z… Is the distance between, nozzle and Bltouch... When is deployed? No, in your config... You have Bltouch deployed under nozzle 1mm. No?
                In firmware 1.19 and earlier, Z1 in the M558 just means that the Z probe is used in lieu of a Z endstop switch. In firmware 1.20 and later it is ignored, because that option is set in M574 instead. But in fact it isn't necessary to tell the firmware to substitute the Z probe for the Z endstop switch at all, assuming you set up your homing files correctly to use G30 to do Z homing.
                The Z probe trigger height is set in the G31 command.
                • peirofundefined
                  peirof
                  I have installed firmware 1.20….
                  Whats the correct configuration.g?
                  Someone using Bltouch, and firmware 1.20, can post his working configuration?
                    The configuration that Scachi posted should work with 1.20 too.
                    • peirofundefined
                      peirof
                      I suspect that the problem may be in the file bed.g, which makes me think that:
                      A- The BlTouch sensor, now, seems to work correctly, when I turn on the printer it does the initial test
                      B- If you send the gcode G30 S-1 via a console, it seems to execute it well.
                      So….
                      When by DWI, you send the autocalibrate order ... it is supposed to make the orders contained in bed.g. Do not?
                      When you send the order to use the mesh compensation ... It does not depend on what you put in bed.g, but on order M557 in config.g. DO NOT?
                      Someone, that have a Delta and uses BlTouch, can post his [c]bed.g[/c]
                      • peirofundefined
                        peirof
                        News….
                        I try to make a [c]bedcompesation[/c], and partial works, with the next behavoir:
                        1- Nozzle go down, a bit slow, but go down….
                        2- With Nozzle is near bed, aprox 30 mm, slow, VERY SLOW.
                        3- With BlTouch, reach bed... MAGIC, WORKS. Retract, and Nozzle go up.
                        4- Go to the next point... and here start the problems, de BlTouch, NO re Deploy.
                        Why?
                        And why bed compenstation works, or semi works, and calibration NO works, nothing?
                        Ideas?
                        • peirofundefined
                          peirof
                          eeee…..
                          i think i have it.... not sure.
                          Dc42.... if someone, has put the files deployprobe.g and retractprobe.g.... in dir [c]\macro[/c]…. maybe.... and only maybe, can be the cause of behavoir descrived in previous post?
