    Why don't you use Cura slicer?
    173
    32.7k
    • burtoogleundefined
      burtoogle
      I used to use slic3r but have forgotten about it now(!) so please provide a description of the speed reduction on small perimeters so I can understand the request.
      I know that printing curves on the first layer reliably requires a slow down because my personal version of Cura has separate speeds for the first layer walls and everything else. What I do is print the walls on the first layer real slow and then print the skin quite a bit faster. I find this works really well, I get perfect walls and don't have to wait forever for the skin to be printed. I did offer the Cura people the code to do this but they rejected it saying that they wanted to achieve the same thing a different way (this was some time ago). They haven't done anything about it so I will try again.
        burtoogle
        BTW, have you noticed the duplicate posts on the forum? When I posted that last reply I got an error page so I posted it again.
          T3P3Tony administrators
          Yeah I think I know the cause…. Roll on new forum software when I can!
          • fmaundefined
            fma
            @burtoogle:
            Well, Slic3r has a specific speed param for small perimeters, that's all. You usually set it with a slower speed than normal perimeters. This speed is also scaled down by the first layer reducing speed factor.
            But I don't know what is considered as a small perimeter (the length is hard coded). All I know is it works fine.
            The problem is if you reduce the speed of all perimeters to handle small ones, it can takes hours when you have large external perimeters, mostly straight lines, where you can print much faster than small inner holes perimeters.
            Frédéric
              Where the "small perimeters" speed reduction factor in slic3r is especially useful is when I am printing parts with M3 clearance holes aligned with the Z axis. The perimeters for such holes need to be printed very slowly to ensure good bed adhesion and to stop the filament cutting corners.
                deckingman
                @fma:
                @burtoogle:
                If you hover over the small perimeters box, you get a pop up, and in that it says that it applies to perimeters having a radius <= 6.5mm. At least that's what happens with Slic3R PE 1.37.1. I have no idea why that number was chosen or why it's hard coded.
                • fmaundefined
                  fma
                  I didn't notice that. Thanks!
                  Frédéric
                    burtoogle
                    OK, thanks for the description of the slic3r small perimeters setting. If you use that, you'll be looking forward to exploring M592 so that your first layer walls will have uniform width (just kidding, of course!)
                    • Billhc83undefined
                      Billhc83
                      @T3P3Tony:
                      One point to add is that you can really improve the usability of cura with big/lots of models if you turn off the auto slicing of models. that way you can sort out the build plate move things, rotate etc and then slice the model.
                      Thanks for the info. I will have to revisit a newer version again and try this.
                      • Danalundefined
                        Danal
                        Opinions only:
                        I use Cura. I did at one point license S3D and kept going back to Cura, so when C3 came out, I sold my S3D license
                        Cura V3.x has MUCH better defaults around supports. Still not enough manual control… but... so far, I've not needed manual control if I just take the defaults.
                        In fact, there is a theme here: I am a person who immediately puts software in "expert mode" and tweaks every setting. I've discovered that with Cura 3, I'm getting fantastic results just using the "recommended" mode of the GUI, which really only takes about four or five settings and leaving the rest of the hundreds of settings alone. This is hard for me… I want to be a control freak... but it seems to work very well. This is the main reason I've come to chose Cura: I want results, not eternal tweaking.
                        Yes, IMHO, the very first thing you do to Cura is turn off auto slicing.
                        Cura V2 and/or V3 GUI is VERY SLOW on my machine. The slice engine is fine. I have been working with Cura support on this issue and I believe they've found the root cause, literally in just the last few days. It seems that custom defined printers always have 8 extruders (and maybe 8 of other things) internally. The error checking around the fact that 7 of those 8 don't really exist is what is slowing down the GUI. I'm hoping for a patch soon, and/or I may manually edit the (somewhat byzantine) raw configuration files.
                        I really, really, really, like the Cura > Octopi plugin. So much that I'm attempting to code a Cura > Duet3D plugin.
                        So, why Cura? Despite the GUI slowness?
                        I like open source. I'm getting excellent print results. As a disclaimer, I do not typically print extremely high poly count STLs… and that may change, soon. So we'll see if I still like Cura when I start printing higher and higher count models.
                        Why NOT ideamaker? Doesn't support round beds, and I'm a delta/kossel fanatic. Otherwise, I'd be giving it a really solid try. Why not Slic3r? Harder to answer. There is something about it that just seems awkward. Personal taste. Also, I can't remember if it supports round beds or not. Why not S3D? While I like generally like OSS, I will happily pay for commercial software if it has value. To me, S3D is absolutely NOT $150 'better' than Ideamaker/Slic3r/Cura. Not even close. YMMV.
                        Anyway, that's it for now, from someone who's the opposite of the very original question... "Why don't"... well, I DO! For the above reasons.
                          @Danal:
                          Have a look here:
                          https://github.com/Kriechi/Cura-DuetRRFPlugin
                          A Cura plugin for controlling a Duet with RepRapFirmware.
                          Thanks to resam for this, thread is here:
                          https://www.duet3d.com/forum/thread.php?pid=27676#p27676
                          • Danalundefined
                            Danal
                            @T3P3Tony:
                            @Danal:
                            Have a look here:
                            FANTASTIC! I will take a look.
                            • Danalundefined
                              Danal
                              Got that plugin, downloaded and installed, and played a bit.
                              That is EXACTLY what I wanted. Thanks, thanks, thanks. Saves me a ton of work.
                              • David Jundefined
                                David J
                                I seem to be in the minority - but I prefer Cura. It just seems to produce a nicer end product. It's not perfect, as sometimes it doesn't provide support where i'd expect it to, but generally it's my preferred slicer.
                                One of these days I'll go mad and pay for a slicer… but I haven't felt the need yet.
                                • David Jundefined
                                  David J
                                  @T3P3Tony:
                                  I tried installing that, but I couldn't get it to appear in the plugins/extensions list. I recently updated Cura to 3.1.0, so maybe this hasn't caught up?
                                  • resamundefined
                                    resam
                                    Danal:
                                    Glad you liked it! Saves me a ton of time and clicks every day!
                                    DavidJ:
                                    I haven't played with Cura 3.1 yet - because their issue tracker is just filled with bugs in the latest release cycle…
                                    Maybe I find some time in the next days to test & maybe update it.
                                    Feel free to open a bug report on the github repo page: https://github.com/Kriechi/Cura-DuetRRFPlugin
                                      burtoogle
                                      And now 3.2beta is available so the issue tracker is going to get more work.
                                      It's great to get new features but if it comes at the expense of stability and compatibility with older versions then something is wrong. I have had my little rant over on the Cura forum suggesting they use a different release strategy with support for long term releases but it made no difference.
                                      • EasyTargetundefined
                                        EasyTarget
                                        I've only used Cura 3.1, (appimage on Linux) and it's a relatively sane UI, for importing, scaling, positioning etc.
                                        But the interlocking mess of Options, visible options, hidden options, Options that come and go according to other options (but only if you have also made them visible in a pop up modal dialog that hides the options list you are manipulating). There are options changed by changing printer, Options changed by filament settings, lists of proprietary filaments that I will never use but are forced into the UI. Then add in little icons to show which setting you have changed, which are shared. Throw in some help popups that dont always explain things well to a novice,and the somewhat confusing 'keep/drop' settings dialogs as you change profiles, and it's a a bit of a 'mare.
                                        I live on tenderhooks when slicing in Cura and moving between printers and materials, I waste lots of time simply going through the slicing options making sure everything is what I expect it to be and nothing has accidentally changed. I have found myself making whole long lists of options visible just to check that Cura has made sane choices.
                                        For my new printer I have started working by taking my standard calibration model and refining it in Cura till it printed perfectly in PLA+, then saving that as a .3mf, I then repeated for PLA, some high printing temp PLA and PETG.
                                        • I load the CaliCat project for the material, clear the buildplate, import whatever I want to print, then maybe adjust layer height and speed. I find this much more predictable than hoping my profile selections will magically generate the right settings.
                                        There are still some frustrations with my 4K'ish screen; scaling is good, but selection boxes on screen elements are tiny, it is particularly hard to select the layer view slider, for instance. The GUI also bogs down on the layer view for big models, further complicating navigation, but that's not too surprising given my gpu/screen combo, this is no gaming rig.
                                        Finally; I was having wall holes appear in some 0% infill (low poly) models when sliced, clearly visible in the layer view. None of the mesh options, or any others would resolve it; and with my enthusiasm for mesh editing at an all-time low I simply resorted to Slic3r as a workaround. It sliced the same (mildly defective, I'm sure) STL's fine, and gave me the gcode I needed.
                                        • Slic3r's options might be another dogs-dinner of tabs, dropdowns and scrollbars, but at least I can see them all at a glance.
                                        • That was a couple of weeks ago, and since then I've found myself using slic3r more; the advantage Cura has over it for me seems to be 'undo', speed for some models, and the Vase mode (which Slic3r doesn't really understand how to do properly)
                                        I seem to have rambled there.. sorry for that.
                                        Disaster? The original Printeye is dying with RRF 3.5 (M208 depreciated).
                                        PrintPy2024 to the rescue!
                                        MicroPython based; with simple wiring and and no custom PCB.
                                          EasyTarget
                                          @burtoogle:
                                          … because my personal version of Cura has separate speeds for the first layer walls and everything else.
                                          There is an option to slow down the whole first layer, I use it a lot, are you talking about just slowing down the first walls, but leaving the fill of the base printing fast?
                                          • Danalundefined
                                            Danal
                                            @David:
                                            @T3P3Tony:
                                            I have noticed that slightly different versions of Cura seem to put the plugins in slightly different places. I don't have a good map. If you install any plugin and it does not appear, check if there are plugins in the "local" vs "roaming" user\appdata directories. Or vice versa.
                                            Also look for 3.0, 3.1, etc. as directory names. You get the idea…
