    Duet Wifi Webserver not responding
    80
    10.5k
      Thanks, I suspected that these problems might be caused by a lack of sockets. Which version of DuetWiFiServer are you using?
      • Nuvagundefined
        Nuvag
        Firmware Name:
        RepRapFirmware for Duet WiFi
        Firmware Electronics:
        Duet WiFi 1.0
        Firmware Version:
        1.20 (2017-12-23)
        WiFi Server Version:
        1.21RC1
        Web Interface Version:
        1.20
        • parovoZZundefined
          parovoZZ
          Hi!
          Is it possible to make a program reset of the Wi-Fi module on an external button? For example, execute a script:
          M552 S-1;
          M552 S1;
            Yes, if you set up a trigger using M581.
              T3P3Tony administrators
              if you do that I think you will need a pause in between the M552 S-1 and M552 S1 commands (I tried to make a macro for this but the S1 was executed too soon after the disable (while the wifi was still changing state) so it did not work.
              • parovoZZundefined
                parovoZZ
                And then what to do?
                Now I connect a USB cable during printing…...brrrrrr))))
                  You can insert a pause between the two M552 commands using G4.
                  • parovoZZundefined
                    parovoZZ
                    G4 is bad. Stops printing ….
                    Is there a NOP command?
                      Good point, if a print is running then G4 will wait for everything to stop. Try this:
                      M552 S0 ; disconnect and shutdown wifi services
                      M587 ; list access points, with luck this will wait for the shutdown to complete
                      M552 S-1
                      M552 S1
                      • Danalundefined
                        Danal
                        Another data point:
                        I lost connection to a DuetWifi during a long print. About six hours in. M582 (via PanelDue) stop/start did not fix. M552 stop/start and connectivity was fine.
                        Firmware Name: RepRapFirmware for Duet WiFi
                        Firmware Electronics: Duet WiFi 1.0
                        Firmware Version: 1.20 (2017-12-23)
                        WiFi Server Version: 1.20
                        Web Interface Version: 1.20
                        Wireless router is a Google WiFi mesh. It is about 15 feet from the printer. It is also true that my Desktop PC is cabled to that same Google node that serves the printer, and the wireless mesh from that node is the only connectivity available to my PC. Meaning that I'd know it instantly if the router mesh node itself dropped.
                        As mentioned, just another data point. No explicit reply needed. 🙂
                        • Nuvagundefined
                          Nuvag
                          As im a software developer myself i know such bugs can be hard to track down.
                          Some minor information which may or may not help:
                          • wifi may fail even when the printer is not printing (turn printer on, connect webinterface, wait some time, connection lost)
                          • wifi may fail within a few seconds after restart. Looks realy random, sometimes hours, and today it failed after <10 seconds
                          Its a really annoying problem, probably will finally add my PanelDue which i bought with the printer but never bothered to mount it as the wifi interface did not leave anything to be desired.
                          • madeinta1wanundefined
                            madeinta1wan
                            I too have lost connection. I've got long prints running (4-5 days) and am currently 'printing blind'
                            Is connecting through a USB a bad idea while a print is running? Is it possible to reset the wifi connection from the duet board to the router while a print is running?
                            Thanks,
                            Nate
                              Connecting USB while the print is running is OK if you are careful, see https://duet3d.dozuki.com/Wiki/USB_ground_loops. Yes you can reset the network interface during a print.
                              Have you checked the points at https://duet3d.dozuki.com/Wiki/WiFi_disconnections_and_AJAX_timeout_errors ?
                              • EasyTargetundefined
                                EasyTarget
                                You should be fine with a laptop and a USB cable; You'd almost certainly be OK even if you put it on charge (laptops typically stay isolated behind their powerbrick).
                                Once connected You can send [c]M552 S0[/c] then [c]M552 S1[/c] to turn off/on the wifi and it /should/ reconnect to the AP, Use [c]M122[/c] to see how that works out.
                                I have a RasPI with a USB link to my Duet, and have had to do this several times when the Webcontrol stopped responding during a print, and it was successful each time.
                                Disaster? The original Printeye is dying with RRF 3.5 (M208 depreciated).
                                PrintPy2024 to the rescue!
                                MicroPython based; with simple wiring and and no custom PCB.
                                  madeinta1wan
                                  That's great, thanks dc42 and EasyTarget . All sorted.
                                  RasPi as terminal server?
                                  Only 121hrs to go…
                                  • Nuvagundefined
                                    Nuvag
                                    Is there an fix in the works?
                                    I'm starting to consider downgrading as in earlier versions the wifi was unstable too, but a simple refresh of the webpage reconnected the webinterface compared to restarting the wifi module via USB now.
                                    Yesterday i noticed i can no longer view my Gcode Files in the webinterface as this causes an Request timeout and disconnects the webinterface (but can be reconnected without restarting the wifi)
                                    In earlier versions this did not happen but the list of files was not always complete.
                                      @Nuvag:
                                      There is a separate thread on this. That problem has been seen recently when you have very large GCode files on the SD card. The workaround is:
                                      • Format the SD card to use 64K clusters, which is the largest cluster size possible
                                      • If the SD card is heavily fragmented, defragment it, or get a new card
                                      • Use a fast SD card. I get excellent results using a Sandisk 16Gb Class 4 card formatted to 64K clusters.
                                      • deadwood83undefined
                                        deadwood83
                                        Another user with frequent timeouts. Firmware 1.2.0 WebServer 1.2.1RC4 and WebServer 1.2.0
                                        WAP: Avaya WAP9122
                                        Router: Mikrotik CCR1009
                                        Switch: Avaya VSP4850GTX+
                                        No real way to connect the PC to the device for debugging sadly. Not without a 150ft USB.
                                        7:36:58 PM
                                        Disconnected.
                                        7:33:07 PM
                                        Connection established!
                                        7:28:48 PM
                                        Disconnected.
                                        7:23:46 PM
                                        7:21:48 PM
                                        Disconnected.
                                        7:19:39 PM
                                        7:19:39 PM
                                        Page Load complete!
                                        Other devices (ecobee, phones, etc) are rock solid for months on end.
                                        ETA: M122 Output
                                        WiFi firmware version 1.21RC3(28b1)
                                        WiFi MAC address 2c:3a:e8:0a:fe:52
                                        WiFi Vcc 3.39, reset reason Turned on by main processor
                                        WiFi flash size 4194304, free heap 13000
                                        WiFi IP address 10.10.30.86
                                        WiFi signal strength -46dBm, reconnections 0, sleep mode modem
                                        HTTP sessions: 1 of 8
                                        Socket states: 2 0 0 0 0 0 0 0
                                        Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                                        DIsconnections are equally bad when printing and when idle. The disconnects above are when idle.
                                          Then WiFi signal strength looks ok, but have you worked through the rest of https://duet3d.dozuki.com/Wiki/WiFi_disconnections_and_AJAX_timeout_errors ?
                                            deadwood83
                                            Yes sir, Ajax set to 5 in Settings / General. No microwaves running, no cordless phones.
                                            Every Sunday the WAP does a channel congestion scan and auto-selects the least-congested channels.
                                            Currently one 3x3 is on channel 6 for gn and the other 3x3 radio is on channel 132 for anac.
                                            No logs of disconnects from the router side unless I reset the duet.
                                            Just to be thorough I turned off mobile data on my phone to check (4g LTE in the US can interfere with cable modem bonding so why not?) and no difference.
                                            Edit: first channel has B mode rejection. Changed bgn to gn.
