    Precision Piezo z probes guide for duet users reference
    Third-party add-ons
    39
    145
    40.8k
      It sounds to me that you have a short in the cable or the sensor between the +3.3V and ground pins.
      • DjDemonDundefined
        DjDemonD
        Can you measure the resistance between 3.3v and GND on your duet board (is there a nominal value? I'd measure mine but I'm away from home). If its happening with ir sensor and piezo sensor it's not likely to be the sensors that are both shorted.
        www.precisionpiezo.co.uk
        • tekkydaveundefined
          tekkydave
          On my Duet WiFi I get about 5.2K between 3.3v and Gnd at the Probe Connector. Hope that helps.
          BTW that's with the probe unplugged. Its about 3.9K with a Piezo20 plugged in.
          ~ tekkydave ~
          D-Bot: 300x300mm | Duet WiFi + Duex2 | 3 independent z motors | X,Y & Z linear rails | E3D Titan Aero + V6 | Precision Piezo z-probe
          FreeCAD, PrusaSlicer
          • rmrigginundefined
            rmriggin
            @DjDemonD:
            I get a steady 3.3v when checked with my meter on all of the 3.3v pins. I get no resistance reading between ground and the 3.3v pins however.
            • DjDemonDundefined
              DjDemonD
              I still haven't measured mine yet. Life is just too busy right now. However if you get nothing and tekkydave gets resistance then either you are not each measuring in the same way, or with the same power conditions, or same things attached, or something is amiss with one (or both boards).
              You might consider powering the piezo pcb from a 3.3v source independently (or using a usb charger - I think the Z_probe IN pin is 5v tolerant). And just attach the TRG from piezo pcb to z_probe_in on Duet.
              Please wait before using a USB charger 5v, for David/Duet3D to confirm if the z_probe_in is 5v tolerant. If not you could use a usb charger but run the TRG through a 3.3v regulator and then to the Z_probe_in, or a suitable resistor.
              • DjDemonDundefined
                DjDemonD
                We got in 3ders!
                https://www.3ders.org/articles/20180206-fdm-3d-printer-bed-leveling-with-cheap-piezoelectric-elements.html
                • Lakkoundefined
                  Lakko
                  So if i understand, if i have
                  M558 P5 I0 R0.4 F330
                  G31 X0 Y0 Z-0.1 P100
                  and i have always to do -0.15 babystep i have to change config.g into:
                  G31 X0 Y0 Z0.05 P100
                  right?
                  • whosrdaddyundefined
                    whosrdaddy
                    yes that is correct.
                    If you have a recent firmware, you can use P8 instead of P5 (unfiltered vs filtered input)
                    • Lakkoundefined
                      Lakko
                      @whosrdaddy:
                      is this also valid for piezo20? firmware 1.20
                        whosrdaddy
                        Yes, and your firmware supports this mode 😉
                        • LumberjackEngineeringundefined
                          Silly question, but why is the red power LED so incredibly bright? I'm running a Duet, so Vin is 3.3V. It's nearly impossible to see the blue trigger LED without covering the always-on power LED!
                          • DjDemonDundefined
                            DjDemonD
                            Well look into that it might be a batch of leds of different output to spec.
                            • Lakkoundefined
                              Lakko
                              @Lakko:
                              right?
                              i noticed in my config.g file in the epilogue section a [c]M208 S1 Z-0.2 ;set minimum Z[/c]
                              this can afflict the z height?
                              so removing the M208 I can go back and insert again this?
                              • DjDemonDundefined
                                DjDemonD
                                No I just recommend setting z min to just below the bed so you can probe points that are below the nozzle when it thinks it's at z=0.
                                But you are right to change your G31 as you state in the first example to 0.05mm.
                                • rmrigginundefined
                                  rmriggin
                                  @dc42:
                                  Of all things it ended up being the 5V/INPUT VOLTAGE jumper not being seated/making connection
                                  Sensor works now but the only issue I am having is that there is no LED whatsoever. In the web control I can see the z probe change values when probing but the LED indicator on the piezo board does not illuminate whatsoever. I have attempted to provide 5v and ground to the LED pins on the board to no avail.
                                  • DjDemonDundefined
                                    DjDemonD
                                    The piezo board LEDs should illuminate if you just supply +5v and GND directly to it. If nothing happens then they may have failed. If the board works despite this it's up to you if you want to proceed, otherwise please contact us via our website (in my signature) we can arrange to replace it.
                                    • Agniusmundefined
                                      Agniusm
                                      Ordered the module with 2 discs to test. I have E3D titan aero but its mounted on aluminium bracket and then bolted to rail which is vertical. Its very rigid.
                                      What needs to be implemented for this to work? Is it deformation of the disc? Which disc is more sensitive, 27 or 20mm?
                                      • DjDemonDundefined
                                        DjDemonD
                                        There not much in it in terms of sensitivity. Deformation, compression or if mechanically feasible just vibration can generate enough signal to trigger the circuit.
                                        Some sort of plate between the two with the piezo embedded in it can work well. Try compression first if that doesn't work support a disc on one side on its periphery and push into the centre on the other side with something narrower.
                                        This is a working prototype https://www.thingiverse.com/thing:2526978
                                        • Agniusmundefined
                                          Agniusm
                                          I wander if i could mill out my bracket to acomodate piezo disc and if so how deep do i need it to be?
                                          • DjDemonDundefined
                                            DjDemonD
                                            They are very inconsistent especially bought from ebay. The most consistent ones we use are Murata 7bb series either 27mm or 20mm. Try rs components or mouser for a datasheet. The brass disc is very consistent, the ceramic is usually slightly off centre and the solder for the wires can be fairly variable. From memory the 20mm one is 0.4mm thick and the solder is 1mm thick. You need to allow generous relief for the solder especially if its going to be in a metal bracket, maybe even some kapton tape over it. You need to allow your bracket to move by about 0.1mm when the nozzle hits the bed, but this amount of vertical compliance does not affect print quality.
