    Error: Short-to-ground on drivers 1
    5.7k
    • equanimity8undefined
      equanimity8
      I looked at the wiring and nothing is wrong to the naked eye.
      I did some more tests moving different motors with different drivers. What I discovered is that Z driver moves the motors without issues but when I try to move Y stepper with X driver it displays short-to-ground on driver 1 - previously it was only when I moved Y driver. Now X driver behaves the same way Y driver did before failing. Also, currently X driver is connected to Y stepper with the wiring from X stepper, so the wiring itself shouldn't be the issue. Can the stepper itself cause that?
      Update
      I played some more with the setup and I made the following observations:
      1. After I power up it takes some time (a minute) to be able to move the motors properly, before that they try to move but appear to not have the torque to do so.
      2. Before the update I was thinking if a stepper motor might be screwing everything up but I checked both steppers more diligently and they appear to behave identically.
      3. When I have X driver connected to X motor and Y driver not connected at all, and I move the X axis via the interface it moves properly, but I can move the same (X) axis by the same value according to the web interface but a shorter distance by using the Y axis movement button from the interface.
      4. I received a Warning Vin under-voltage event (2.9V). Just by looking at it the interface reports a steady 12-12.1V. The power wires are properly secured in the screw-in terminals of both the board and the power supply. The power supply is indeed a chinese copy I had lying around. Additionally, I ran M122 and this was the output:
      M122
      Used output buffers: 3 of 32 (16 max)
      RepRapFirmware for Duet WiFi version 1.20 running on Duet WiFi 1.0
      Board ID: 08DGM-95BNL-MGPSN-6JTDJ-3SJ6T-12YHZ
      Static ram used: 15448
      Dynamic ram used: 98976
      Recycled dynamic ram: 264
      Stack ram used: 1392 current, 5936 maximum
      Never used ram: 10448
      Last reset 00:02:51 ago, cause: power up
      Last software reset at 2018-02-16 13:56, reason: User, spinning module GCodes, available RAM 7912 bytes (slot 0)
      Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0440f000, BFAR 0xe000ed38, SP 0xffffffff
      Error status: 0
      Free file entries: 10
      SD card longest block write time: 0.0ms
      MCU temperature: min 35.8, current 36.1, max 36.3
      Supply voltage: min 12.0, current 12.0, max 12.1, under voltage events: 0, over voltage events: 0
      Driver 1: short-to-ground, SG min/max not available
      Date/time: 2018-02-17 16:27:24
      Cache data hit count 634789147
      Slowest main loop (seconds): 0.155786; fastest: 0.000110
      MaxReps: 0, StepErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
      Scheduled moves: 4, completed moves: 4
      Bed compensation in use: none
      Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      Network state is running
      WiFi firmware version 1.20
      WiFi MAC address 2c:3a:e8:0a:ec:5d
      WiFi Vcc 3.42, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 16688
      WiFi IP address 192.168.137.28
      WiFi signal strength -53dBm, reconnections 0, sleep mode modem
      HTTP sessions: 1 of 8
      Socket states: 2 0 0 0 0 0 0 0
      Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
        Something isn't right with this:
        Driver 1 is the Y driver.
          equanimity8
          Negative, wording is correct despite being a bit ambiguous, I'll try to rephrase.
          As CoreXY doesn't have true X and Y axes it has alpha and beta motors working together, which I've seen being addressed as X (left) and Y (right) motors and I have adopted it. What you have quoted is to be read as follows - when I have Y stepper (right stepper/beta motor) connected to X driver on the Duet Wifi and I move the X axis via the web interface I get error short-to-ground on driver 1.
          See 3) of my update as I go into bit more detail there.
            If attempting to move the motor connected to the Y motor output causes that error message to appear, that indicates that driver 1 (Y driver) has a shorted mosfet or that there is a short in the external wiring. If it produces that message even with no motor connected to the Y motor output, then it's the driver that is faulty.
              equanimity8
              Thanks for your input!
              Currently, I have the Z and X motors connected to their respective drivers i.e. Y driver is free. When I move Z axis no error appears. When I move X axis the error in driver 1 appears. When I move Y axis the carriage does move although just a short distance and quite slowly. If I'm understanding correctly what you have written, driver 1 (Y) is faulty.
              That is unfortunate but I'd rather think forward. I was wondering how can I remap the driver from E1 (which is free since I'm using a single extruder) to move the Y axis. I'm looking at the gcode but I must say its harder for me than I thought.
                Yes, to can use M584 X0 Y4 Z2 E3 in config.g to do that. But you are entitled to have your Duet repaired or replaced under warranty, assuming you have had it for less than 6 months.
                  equanimity8
                  Thanks for spelling it out for me, I appreciate your time.
                  I only wanted to ask if I have to add some gcode to "deactivate" driver 1 (Y) or just add the remapping gcode, connect to the proper driver and go about my merry ways? Also, what should I make of the low voltage error I received earlier? I do have many more questions but I believe I should make use of the search feature.
                  Also, thank you for bringing that up. I'd rather have a properly functioning board but I wanted to continue with finalizing my config. I did contact RepRapWorld so we'll see that will happen but yes I've had it for less than six months.
                    The output MOSFETs won't be enabled on driver 1 if it is never used.
                    The M584 command must come earlier in config.g than the M906 command, also earlier than the M350 command if you have one.
                      equanimity8
                      Thanks for clarifying. I did add that in my ;Drives and I can move all axes without any errors.
                      I appreciate your help. I'm happy the support of the boards lives up to the expectations. Well done, to you, dc42, sir.
                        equanimity8
                        Now, as everything moves correctly I wanted to have my axes home in the correct direction. I flipped Z and it worked as expected. However, when I try to flip Y (drive 4) it goes south somewhere. I added M569 P4 S0 ; Drive 4 goes backwards but in that case when I move X from the interface Y moves in the wrong direction and when I move Y in the interface X moves in the right direction. If I add M569 P4 S1 the interface moves the correct axis and X moves in the right direction and Y moves in the wrong direction.
                        M584 X0 Y4 Z2 E3 ;remap drive Y to drive E1
                          It sounds to me that your printer currently has a left-hand coordinate system. To change it to a right-hand coordinate system, swap over the X and Y motor connections or swap X and Y in the M584 command, then use M569 to get the correct directions.
                            equanimity8
                            By a lucky mistake I just read that RRF uses a right-hand origin. Where can I get more info why this is the case and wouldn't it result in mirrored prints?
                              All 3D printing assumes a right-hand coordinate system - which means that looking from above, the +Y direction is rotated 90 degrees anticlockwise from the +X direction.
                              On a CoreXY printer, the usual choice is that looking at the front of the printer, +X is to the right and +Y is away from you.
                              Vladundefined 1 Reply Last reply Reply Quote 0
                                equanimity8
                                I think we both are talking about an origin of front/left like here - http://www.makerslide-machines.com/old-web-site/res/z-in-same-time.jpg, do correct me if that's not the case.
                                I had issues with it but after going out for a walk I now have it working properly with the following, if anybody ever needs it:
                                M584 X0 Y4 Z2 E3 ;remap driver Y to driver E1
                                M569 P2 S0 ; Drive 2 goes forwards
                                M569 P4 S1 ; Drive 3 goes forwards
                                • Vladundefined
                                  Vlad @dc42
                                  This post is deleted!
