    Suitable webcams for displaying progress in the webui?
    43
    7.2k
    • martinsundefined
      martins
      another solution here is Raspberry Pi zerow or rpi3 or any (zerow+cam = cheapest option)
      all you need is to install motioneyeos https://github.com/ccrisan/motioneyeos/wiki/Supported-Devices
      after you connect to you network with it , just open IP asigned by dhcp for you
      log in username admin password empty
      few steps to setup fast network cam
      after set fast network cam hit Apply button
      copy url displayed in step 5
      fill in DWC
      and you get at the end
      hope this helps someone 🙂
      • fmaundefined
        fma
        I'm using this solution too!
        Frédéric
        • webdadundefined
          webdad
          I've got the Zerow and the camera, just haven't had the time to start working on it. What case(s) are you using?
          • fmaundefined
            fma
            This one:
            https://www.thingiverse.com/thing:2300226
            Frédéric
            • webdadundefined
              webdad
              Oh I am so printing that. Thanks!
              • fmaundefined
                fma
                Be aware that the nut trap seems to be made for 1/8" or 3/8" (photo standard), and not M8… But you can use M6 (you will have to maintain the nut while screwing).
                Frédéric
                • Scott_Hundefined
                  Scott_H
                  I'm using the Sannce ip camera mentioned on the wiki - $40 delivered to Australia, so cheaper than the pi+camera.
                  I was using the snapshot cgi method, but changed to using http://192.168.1.6:16325/videostream.cgi?loginuse=MyUserName&loginpas=MyPassword, and ticking the embed webcam stream under DWC settings.
                  Can confirm that this method works perfectly under chrome on windows.
                  If it doesn't work for you, changing the webcam update interval to, ie, 0.1 seconds may be a workaround.
                  I couldn't find the ip camera page on the new wiki, so am posting here.
                  • JuJuDeltaundefined
                    JuJuDelta
                    I have found my RPi Zero W solution to be quite prone to uSD card corruption with power on/off.
                    I will try the Sannce Wireless IP camera.
                    Found it here £25 UK free delivery.
                    https://www.manomano.co.uk/cctv-camera/sannce-720p-smart-wireless-ip-camera-remote-access-4134074
                    T3DP3D Kossel XL+, Duet2Wifi, PanelDue 7i, RRF V3.2, Fl3xdrive, SmartEffector, Berd Air annulus, Cura 4.x, PrusaSlicer, RPi WiFi Camera, Heated Chamber
                      We missed the webcam page when we migrated the wiki, but it's now at https://duet3d.dozuki.com/Wiki/How_to_include_a_web_camera_image_in_Duet_Web_Control.
                      • Scott_Hundefined
                        Scott_H
                        Ah thanks! Have added that information to the wiki. I attempted to follow the document formatting, though I am a wiki novice so…
                        • webdadundefined
                          webdad
                          @Martins and @fma - Got my Pi Zero W / V2 Camera all set up and it is showing up on DWC. Are you doing anything to control when the camera is on or off? starts / stops recording?
                          • fmaundefined
                            fma
                            For now, my picam is powered with a AC-to-USB converter, and all is switched-on switched-off at the same time with the main switch.
                            I didn't check yet how to start a timelapse or a video. I will ask MotioneyeOS dev if it is possible through a GPIO input.
                            Frédéric
                              @martins:
                              http://www.bbmail.co/duet/dwcam/1.png
                              http://www.bbmail.co/duet/dwcam/2.png
                              http://www.bbmail.co/duet/dwcam/3.png
                              fill in DWC
                              http://www.bbmail.co/duet/dwcam/4.png
                              http://www.bbmail.co/duet/dwcam/5.png
                              This worked like a charm. Thanks.
