    Suitable webcams for displaying progress in the webui?
    43
    7.2k
    • Mikeundefined
      Mike
      You can also get one of those ELP 1280 * 720p IP cameras. Fairly cheap, decent resolution and works reasonably well with DWC. Configuring it was a bit of a pain in the neck though…
      • ect2undefined
        ect2
        Mike, how do you hook up and configure the ELP 1280? This is exactly what I've been looking for as I do not want to use WiFi.
        • Mikeundefined
          Mike
          Took me a while to figure that one out. First, you'll need to connect to it - by default (for some reason) it has a fixed IP 192.168.1.10. So if your router assigns IPs in that range, make sure that it's not taken, otherwise just connect directly to the PC. After that you should log into the machine, but you'll need a browser with ActiveX support. In my case, I ended up installing old Internet Explorer just for that. Further setup is fairly trivial - you can switch the language to English, enable the DHCP support (seriously, why isn't it on by default…) and toy with the settings. The static jpeg image would be available at "http://your camera's IP/webcapture.jpg/command=snap&channel=0" and you should also check "Do not append extra HTTP qualifier".
          • ect2undefined
            ect2
            Thank Mike. Something like this?
            https://www.aliexpress.com/item/Audio-Mini-Type-HD-1280-x-720P-1-0MP-IP-Camera-Metal-Indoor-Security-Camera-ONVIF/32822170249.html?spm=2114.search0104.3.79.49f5ffacQ7JAJ3&ws_ab_test=searchweb0_0,searchweb201602_4_10065_10344_10130_10068_10342_10547_10343_10340_10548_10341_10084_10083_10618_10615_10307_10131_10132_10133_10313_10059_10534_100031_10103_441_10624_442_10623_10622_10621_10620_10142,searchweb201603_2,ppcSwitch_3&algo_expid=9f721937-67e2-4d39-8fdc-480a18e0d51a-12&algo_pvid=9f721937-67e2-4d39-8fdc-480a18e0d51a&priceBeautifyAB=3
            • ect2undefined
              ect2
              This one is probably more suitable:
              https://www.aliexpress.com/item/1280-720P-1-0MP-mini-IP-Camera-ONVIF-2-8-12mm-manual-varifocal-zoom-lens-P2P/32684641752.html
              What focal length do you use for sharpest image?
              • Mikeundefined
                Mike
                Got something similar to the 1st one, although I've got mine from Amazon. Can't say anything on the focal length - I ended up just adjusting the lens manually until my printbed was in focus.
                • ect2undefined
                  ect2
                  Thanks Mike
                  • Danalundefined
                    Danal
                    maybe I'm just not searching correctly, but I'm having a heck of a time finding a camera that is suitable, and:
                    1. On Amazon (USA)
                    2. Wireless
                    All the ones I find are "too smart".
                    • martinsundefined
                      martins
                      another solution here is Raspberry Pi zerow or rpi3 or any (zerow+cam = cheapest option)
                      all you need is to install motioneyeos https://github.com/ccrisan/motioneyeos/wiki/Supported-Devices
                      after you connect to you network with it , just open IP asigned by dhcp for you
                      log in username admin password empty
                      few steps to setup fast network cam
                      after set fast network cam hit Apply button
                      copy url displayed in step 5
                      fill in DWC
                      and you get at the end
                      hope this helps someone 🙂
                      • fmaundefined
                        fma
                        I'm using this solution too!
                        Frédéric
                        • webdadundefined
                          webdad
                          I've got the Zerow and the camera, just haven't had the time to start working on it. What case(s) are you using?
                          • fmaundefined
                            fma
                            This one:
                            https://www.thingiverse.com/thing:2300226
                            Frédéric
                            • webdadundefined
                              webdad
                              Oh I am so printing that. Thanks!
                              • fmaundefined
                                fma
                                Be aware that the nut trap seems to be made for 1/8" or 3/8" (photo standard), and not M8… But you can use M6 (you will have to maintain the nut while screwing).
                                Frédéric
                                • Scott_Hundefined
                                  Scott_H
                                  I'm using the Sannce ip camera mentioned on the wiki - $40 delivered to Australia, so cheaper than the pi+camera.
                                  I was using the snapshot cgi method, but changed to using http://192.168.1.6:16325/videostream.cgi?loginuse=MyUserName&loginpas=MyPassword, and ticking the embed webcam stream under DWC settings.
                                  Can confirm that this method works perfectly under chrome on windows.
                                  If it doesn't work for you, changing the webcam update interval to, ie, 0.1 seconds may be a workaround.
                                  I couldn't find the ip camera page on the new wiki, so am posting here.
                                  • JuJuDeltaundefined
                                    JuJuDelta
                                    I have found my RPi Zero W solution to be quite prone to uSD card corruption with power on/off.
                                    I will try the Sannce Wireless IP camera.
                                    Found it here £25 UK free delivery.
                                    https://www.manomano.co.uk/cctv-camera/sannce-720p-smart-wireless-ip-camera-remote-access-4134074
                                    T3DP3D Kossel XL+, Duet2Wifi, PanelDue 7i, RRF V3.2, Fl3xdrive, SmartEffector, Berd Air annulus, Cura 4.x, PrusaSlicer, RPi WiFi Camera, Heated Chamber
                                      We missed the webcam page when we migrated the wiki, but it's now at https://duet3d.dozuki.com/Wiki/How_to_include_a_web_camera_image_in_Duet_Web_Control.
                                      • Scott_Hundefined
                                        Scott_H
                                        Ah thanks! Have added that information to the wiki. I attempted to follow the document formatting, though I am a wiki novice so…
                                        • webdadundefined
                                          webdad
                                          @Martins and @fma - Got my Pi Zero W / V2 Camera all set up and it is showing up on DWC. Are you doing anything to control when the camera is on or off? starts / stops recording?
                                          • fmaundefined
                                            fma
                                            For now, my picam is powered with a AC-to-USB converter, and all is switched-on switched-off at the same time with the main switch.
                                            I didn't check yet how to start a timelapse or a video. I will ask MotioneyeOS dev if it is possible through a GPIO input.
                                            Frédéric
