    Duet wifi S3D
    50
    12.6k
    • BrianHanifinundefined
      BrianHanifin
      OK. While the above code does upload a file to duet, it does something to the file that leaves it unprintable. I have experimented with it and discovered the following works. This may not be the optimal method still, but it does yield a printable GCode file.
      curl  -F "file=@[output_filepath]" "http://hypercube.local/rr_upload?name=gcodes/[output_filename].gcode"
      The reason I say it is not optimal is that is places some HTTP data at the top of the file. But, Duet appears to ignore this code and happily prints anyway. So, for now it will do.
      --------------------------16eea21da68ae83e
      Content-Disposition: form-data; name="file"; filename="curl_test.gcode"
      Content-Type: application/octet-stream
      • Alex9779undefined
        Alex9779
        This is great! thumbsup Thanks for sharing…
        • sungod3kundefined
          sungod3k
          I used a similar command with Octoprint succesfully so I was quite happy when I found this thread.
          The command Im using is
          curl -# -d "@[output_filepath]" -X POST http://xxx.xxx.xxx.xxx/rr_upload?name=gcodes/[output_filename].gcode"
          which uploads the code correctly, however when I want to print the autouploaded code, it starts the print, does nothing and then returns the message "print finished in 0h 1m".
          The same code works normally when I upload it via the webinterface.
          Whats the trick to get that working?
          Cheers
          http://www.42dimensions.de/
          https://printnewworlds.blogspot.com/
          • MoS-tekknixundefined
            MoS-tekknix
            Please download the "uploaded" GCode via WebInterface and take a look into the file. Maybe there it will be clearer what happens.
            • sungod3kundefined
              sungod3k
              I ran the original and the autouploaded file through notepad++s compare tool and they matched 100%
                MoS-tekknix
                @sungod3k:
                Uhm, thats interesting.
                Can you try this one, i'm using and change the IP to your DuetWifi/Ethernet IP?
                [[language]]
                curl -F "file=@[output_filepath]" "http://192.168.178.144/rr_upload?name=gcodes/[output_filename].gcode"
                That is working even if the Printer is currently busy.
                Regards
                MoS-tekknix
                • sungod3kundefined
                  sungod3k
                  Great, that seems to work. Thanks
                    MoS-tekknix
                    @sungod3k:
                    You're welcome. That's what's a forum for đŸ˜‰
                    Regards
                    MoS-tekknix
                    • tychopundefined
                      tychop
                      @MoS-tekknix:
                      @sungod3k:
                      [[language]]
                      Regards
                      MoS-tekknix
                      This script
                      curl -F "file=@[output_filepath]" "http://192.168.x.x/rr_upload?name=gcodes/[output_filename].gcode"
                      uploads the file correctly, but the print doesn't start…
                      Am I missing something?
                        You need to send a separate command to print the file.
                        • tychopundefined
                          tychop
                          Yes, I figured that could be the issue, however, I couldn't find anything here https://github.com/chrishamm/DuetWebControl…
                          Is there a command to print? Where can I look for it?
                          I can see
                          [[language]]
                          function startUpload(type, files, fromCallback) {
                          ```in the javascript, but am clueless how to specify 'print' as the type to upload gcode & start the print
                            Use the rr_gcode command to send M32 "filename.gcode".
                            • tychopundefined
                              tychop
                              Yep, Got it
                              This works:
                              curl -F "file=@[output_filepath]" "http://192.168.x.x/rr_upload?name=0%3A%2Fgcodes%2F[output_filename].gcode"
                              curl "http://192.168.x.x/rr_gcode?gcode=M32 0%3A%2Fgcodes%2F[output_filename].gcode"
                              Many thanks !!
                                You will need to enclose the filename in double quotes when sending it if you want it to work on filenames with ( or ) or ; in the name.
                                • SEUTecundefined
                                  SEUTec
                                  Hi all:
                                  curl –data-binary "@[output_filepath]" "http://192.168.x.x/rr_upload?name=gcodes/[output_filename].gcode"
                                  –data-binary don't losse the NewLine or CarriageReturns as -d do.
                                  and don't add extra data to the gcode file as -F do.
                                  Regards.
                                  • kuhnikuehnastundefined
                                    kuhnikuehnast
                                    The best that worked for me is:
                                    curl --data-binary "@[output_filepath]" "http://192.168..XX.XX/rr_upload?name=gcodes%2F[output_filename].gcode"
                                    curl "http://192.168.XX.XX/rr_gcode?gcode=M32 [output_filename].gcode"
                                    But there are still some problems...
                                    1. If you have a Space in the name, the file is only saved as the first part til the space (e.g. Test file.gcode is saved as Test.gcode)
                                    2. Special Characters (e.g. Ă¤Ă¶Ă¼) aren't saved properly
                                    3. Is there a possibility to delete the file on the local computer after uploading it to the duet? Couldn't find any solution...
                                    greetings kuhni
                                    • bellwetherundefined
                                      bellwether @dc42
                                      hmm, i guess this is a stupid question, but I am unclear
                                      1. where to put these lovely scripts to load the file.
                                      • mloidlundefined
                                        mloidl
                                        @brianhanifin said in Duet wifi S3D:
                                        I'm currently implementing the G-Code upload for Slic3rPE and struggeling with the same problem mentioned by @BrianHanifin .
                                        Some parts of the HTTP-Header are saved in the G-Code after upload when uploading the G-Code using form_add of libcurl.
                                        Is it somehow possible to support forms in the firmware?
                                        Thanks,
                                        Best regards
                                        Martin
                                        • Johhnyalterundefined
                                          Johhnyalter
                                          HI,
                                          I have just installed a Duet Wifi and running well...However, I cant work out how to get the slicer to control bed temp. Simplify3D wants tools and laser to be indicated as T0 to T5, and Duet indicates bed as 'B' .... Yes, I can and do control bed temp manually prior to printing, but I want it auto controlled by g-code.
                                          Could the gurus here help please ?
                                          Thanks
                                          • OBELIKSundefined
                                            OBELIKS
                                            I think you are overthinking it. Do you have multiple beds?
                                            If not, default setting in S3D is OK, it will output M140 S70 to set bed temperature to 70°C, and that works with Duet
                                            P3Steel Toolson mk2 - Duet 2 WiFi --> RatRig V-Core with Duet WiFi 1.03
                                            Original Prusa i3 MK3S
