    Duet wifi S3D
    50
    12.5k
    • sungod3kundefined
      sungod3k
      I used a similar command with Octoprint succesfully so I was quite happy when I found this thread.
      The command Im using is
      curl -# -d "@[output_filepath]" -X POST http://xxx.xxx.xxx.xxx/rr_upload?name=gcodes/[output_filename].gcode"
      which uploads the code correctly, however when I want to print the autouploaded code, it starts the print, does nothing and then returns the message "print finished in 0h 1m".
      The same code works normally when I upload it via the webinterface.
      Whats the trick to get that working?
      Cheers
      http://www.42dimensions.de/
      https://printnewworlds.blogspot.com/
      • MoS-tekknixundefined
        MoS-tekknix
        Please download the "uploaded" GCode via WebInterface and take a look into the file. Maybe there it will be clearer what happens.
        • sungod3kundefined
          sungod3k
          I ran the original and the autouploaded file through notepad++s compare tool and they matched 100%
            MoS-tekknix
            @sungod3k:
            Uhm, thats interesting.
            Can you try this one, i'm using and change the IP to your DuetWifi/Ethernet IP?
            [[language]]
            curl -F "file=@[output_filepath]" "http://192.168.178.144/rr_upload?name=gcodes/[output_filename].gcode"
            That is working even if the Printer is currently busy.
            Regards
            MoS-tekknix
            • sungod3kundefined
              sungod3k
              Great, that seems to work. Thanks
                MoS-tekknix
                @sungod3k:
                You're welcome. That's what's a forum for 😉
                Regards
                MoS-tekknix
                • tychopundefined
                  tychop
                  @MoS-tekknix:
                  @sungod3k:
                  [[language]]
                  Regards
                  MoS-tekknix
                  This script
                  curl -F "file=@[output_filepath]" "http://192.168.x.x/rr_upload?name=gcodes/[output_filename].gcode"
                  uploads the file correctly, but the print doesn't start…
                  Am I missing something?
                    You need to send a separate command to print the file.
                    • tychopundefined
                      tychop
                      Yes, I figured that could be the issue, however, I couldn't find anything here https://github.com/chrishamm/DuetWebControl…
                      Is there a command to print? Where can I look for it?
                      I can see
                      [[language]]
                      function startUpload(type, files, fromCallback) {
                      ```in the javascript, but am clueless how to specify 'print' as the type to upload gcode & start the print
                        Use the rr_gcode command to send M32 "filename.gcode".
                        • tychopundefined
                          tychop
                          Yep, Got it
                          This works:
                          curl -F "file=@[output_filepath]" "http://192.168.x.x/rr_upload?name=0%3A%2Fgcodes%2F[output_filename].gcode"
                          curl "http://192.168.x.x/rr_gcode?gcode=M32 0%3A%2Fgcodes%2F[output_filename].gcode"
                          Many thanks !!
                            You will need to enclose the filename in double quotes when sending it if you want it to work on filenames with ( or ) or ; in the name.
                            • SEUTecundefined
                              SEUTec
                              Hi all:
                              curl –data-binary "@[output_filepath]" "http://192.168.x.x/rr_upload?name=gcodes/[output_filename].gcode"
                              –data-binary don't losse the NewLine or CarriageReturns as -d do.
                              and don't add extra data to the gcode file as -F do.
                              Regards.
                              • kuhnikuehnastundefined
                                kuhnikuehnast
                                The best that worked for me is:
                                curl --data-binary "@[output_filepath]" "http://192.168..XX.XX/rr_upload?name=gcodes%2F[output_filename].gcode"
                                curl "http://192.168.XX.XX/rr_gcode?gcode=M32 [output_filename].gcode"
                                But there are still some problems...
                                1. If you have a Space in the name, the file is only saved as the first part til the space (e.g. Test file.gcode is saved as Test.gcode)
                                2. Special Characters (e.g. äöü) aren't saved properly
                                3. Is there a possibility to delete the file on the local computer after uploading it to the duet? Couldn't find any solution...
                                greetings kuhni
                                • bellwetherundefined
                                  bellwether @dc42
                                  hmm, i guess this is a stupid question, but I am unclear
                                  1. where to put these lovely scripts to load the file.
                                  • mloidlundefined
                                    mloidl
                                    @brianhanifin said in Duet wifi S3D:
                                    --------------------------16eea21da68ae83e
                                    Content-Disposition: form-data; name="file"; filename="curl_test.gcode"
                                    Content-Type: application/octet-stream
                                    I'm currently implementing the G-Code upload for Slic3rPE and struggeling with the same problem mentioned by @BrianHanifin .
                                    Some parts of the HTTP-Header are saved in the G-Code after upload when uploading the G-Code using form_add of libcurl.
                                    Is it somehow possible to support forms in the firmware?
                                    Thanks,
                                    Best regards
                                    Martin
                                    • Johhnyalterundefined
                                      Johhnyalter
                                      HI,
                                      I have just installed a Duet Wifi and running well...However, I cant work out how to get the slicer to control bed temp. Simplify3D wants tools and laser to be indicated as T0 to T5, and Duet indicates bed as 'B' .... Yes, I can and do control bed temp manually prior to printing, but I want it auto controlled by g-code.
                                      Could the gurus here help please ?
                                      Thanks
                                      • OBELIKSundefined
                                        OBELIKS
                                        I think you are overthinking it. Do you have multiple beds?
                                        If not, default setting in S3D is OK, it will output M140 S70 to set bed temperature to 70°C, and that works with Duet
                                        P3Steel Toolson mk2 - Duet 2 WiFi --> RatRig V-Core with Duet WiFi 1.03
                                        Original Prusa i3 MK3S
                                        • gtj0undefined
                                          gtj0
                                          In case anyone's interested... here's how I print from Linux...
                                          #!/usr/bin/env bash
                                          echo "$(date) $@" >> /var/log/pp.log
                                          printit() {
                                             set +xe
                                             op="$1"
                                             of=$(basename "$op")
                                             ncftpput -t 5 duet0 /gcodes/ "$op" || ncftpput -t 5 -v duet0 /gcodes/ "$op"
                                          #  I do the ncftpput again if the first one fails as it does sometimes.
                                             fn=$(python -c "import urllib ; print(urllib.urlencode({'gcode': 'M32 \"$of\"'}))")
                                             echo $fn
                                             curl "http://duet0/rr_gcode?$fn"
                                             echo "Done"
                                          printit "$@" 2>&1 >> /var/log/pp.log
                                          save that someplace and make it executable. You do need ncftpput (part of ncftp package), curl and python (both of which are standard). There are no issues with spaces in the filename BTW.
                                          In Simplify3D Process, Scripts, Post Processing put something like...
                                          /bin/bash /data1/3d/duet/pp.sh "[output_filepath]"
                                          substituting "/data1/3d/duet/pp.sh" with wherever you put the script.
                                          All you have to do now is 'Save Toolpaths To Disk" and the file should transfer and start printing after the save is complete.
                                          I have also had good luck printing directly from Simplify3D.
                                          Like others have said, you need to set "M555 P2" at the end of your config.g to turn on Marlin emulation and you also have to set "Hardware Flow Control" in the firmware Communications settings.
                                          If I didn't have the PanelDue 7i, I'd print directly. I'm not overly fond of having to switch desktop windows around to start the print.
                                          • Tanneundefined
                                            Tanne
                                            I've cobbled up a quick powershell script for the purpose when I got my Duet. It watches a folder for new/changed .gcode files and offers to upload them.
                                            # adjust these to your values
                                            $folder = "e:\3dprint\gcodes"
                                            $filter = "*.gcode"
                                            $Global:baseUri = "http://duet3d.local/rr_upload?name=gcodes/"
                                            Add-Type -AssemblyName PresentationCore,PresentationFramework
                                            $Global:lastPath = ''
                                            $Global:lastTime = Get-Date
                                            $Watcher = New-Object IO.FileSystemWatcher $folder, $filter -Property @{
                                                IncludeSubdirectories = $false
                                                NotifyFilter = [IO.NotifyFilters]'FileName, LastWrite'
                                            $changeAction = [scriptblock]::Create('
                                                $path = $Event.SourceEventArgs.FullPath
                                                $name = $Event.SourceEventArgs.Name
                                                $timeGenerated = $Event.TimeGenerated
                                                # usually multile change events are triggered when a file is written, no need to spam those
                                                if ($Global:lastPath -ne $path -or ($Global:lastTime - $timeGenerated).TotalSeconds -lt -10) {
                                                    $Global:lastPath = $path;
                                                    $Global:lastTime = $timeGenerated
                                                    $msgBoxResult =  [System.Windows.MessageBox]::Show(("Upload `"{0}`" to the printer?" -f $Event.SourceEventArgs.Name),"GCode Upload","YesNo","Question")
                                                    switch  ($msgBoxResult) {
                                                        "Yes" {
                                                            try {
        Invoke-WebRequest -Uri ("{0}{1}" -f $baseUri, $name) -Method Post -InFile $path
                                                            } catch {
                                                        "No" {
                                            $onChanged = Register-ObjectEvent $Watcher Changed -SourceIdentifier FileChanged -Action $changeAction
                                            # prevent the console from closing
                                            while (1) {
                                                sleep 2
                                            Save somewhere with .ps1 extension and edit line 2-4 to match your settings. To run it rightclick the file -> "Run with PowerShell" and leave the powershell window open. To trigger the upload question just save your gcode file into the folder you specified in line 2.
