    Duet wifi S3D
    50
    12.6k
    • Zesty_Lykleundefined
      Zesty_Lykle
      Interesting!
      Keep it up and perfect it. Wish I could do this stuff.
      (simple mechanical guy here)
      Lykle
      Design, make and enjoy life
      Co Creator of the Zesty Nimble
      • mattbenimbleundefined
        mattbenimble
        @X4TEC:
        I've just been experimenting with sending the S3D output to the Duet Web Control using the rr_upload api. Its a work in progress and what I'd love to be able to do is upload to job to the SDcard via DWC from S3D, then see the job in the live preview, but not sure it will work that way.
        I'm on windows so I installed CURL, then you added the following to the additional terminal post processing section of the S3D profile.
        curl -d "@[output_filepath]" -X POST http://xxx.xxx.xxx.xxx/rr_upload?name=gcodes\S3D
        I've just got it to work so may not be the final script. Ideally I'd like to store the upload with the model name, but I've not found the S3D attribute to send instead of "\S3D"
        i believe you can get the file name using:
        [output_filepath] = the full path to the file being saved, including extension
        [output_dir] = full path to the folder that you're saving the file in (excluding the actual file itself)
        [otuput_filename] = filename without extension or path
        • schneik80undefined
          schneik80
          here is a script that works for me:
          [[language]]
          path=[output_filepath]
          file=${path##*/}
          curl -# -d "@[output_filepath]" -X POST http://xxx.xxx.xxx.xxx/rr_upload?name=gcodes/$file
            schneik80
            On OSX i have a folder action using a bash script
            [[language]]
            for f in "$@"
            do
            	path="$f"
            	file=${path##*/}
            	curl -# -d "@$f" -X POST http://xxx.xxx.xxx.xxx/rr_upload?name=gcodes/$file
            done
            Any gcode file I save to this folder with the action gets uploaded. I like this better than the s3d terminal option because the upload happens on save, not preview on print. In this way i only upload once when i know the print looks right.
            • FrankNPrinterundefined
              FrankNPrinter
              Just my 2 cents and might be off topic but if using usb, you might want to modify a cable and cut out the 5V supply especially if you have a dedicated 5v in to the board already.
              • BrianHanifinundefined
                BrianHanifin
                Thank you for this. I have fine tuned the code for Simplify3D a little, and it works great! đŸ™‚
                curl -d "@[output_filepath]" -X POST http://hypercube.local/rr_upload?name=gcodes/[output_filename].gcode
                  BrianHanifin
                  OK. While the above code does upload a file to duet, it does something to the file that leaves it unprintable. I have experimented with it and discovered the following works. This may not be the optimal method still, but it does yield a printable GCode file.
                  curl  -F "file=@[output_filepath]" "http://hypercube.local/rr_upload?name=gcodes/[output_filename].gcode"
                  The reason I say it is not optimal is that is places some HTTP data at the top of the file. But, Duet appears to ignore this code and happily prints anyway. So, for now it will do.
                  --------------------------16eea21da68ae83e
                  Content-Disposition: form-data; name="file"; filename="curl_test.gcode"
                  Content-Type: application/octet-stream
                  • Alex9779undefined
                    Alex9779
                    This is great! thumbsup Thanks for sharing…
                    • sungod3kundefined
                      sungod3k
                      I used a similar command with Octoprint succesfully so I was quite happy when I found this thread.
                      The command Im using is
                      curl -# -d "@[output_filepath]" -X POST http://xxx.xxx.xxx.xxx/rr_upload?name=gcodes/[output_filename].gcode"
                      which uploads the code correctly, however when I want to print the autouploaded code, it starts the print, does nothing and then returns the message "print finished in 0h 1m".
                      The same code works normally when I upload it via the webinterface.
                      Whats the trick to get that working?
                      Cheers
                      http://www.42dimensions.de/
                      https://printnewworlds.blogspot.com/
                      • MoS-tekknixundefined
                        MoS-tekknix
                        Please download the "uploaded" GCode via WebInterface and take a look into the file. Maybe there it will be clearer what happens.
                        • sungod3kundefined
                          sungod3k
                          I ran the original and the autouploaded file through notepad++s compare tool and they matched 100%
                            MoS-tekknix
                            @sungod3k:
                            Uhm, thats interesting.
                            Can you try this one, i'm using and change the IP to your DuetWifi/Ethernet IP?
                            [[language]]
                            curl -F "file=@[output_filepath]" "http://192.168.178.144/rr_upload?name=gcodes/[output_filename].gcode"
                            That is working even if the Printer is currently busy.
                            Regards
                            MoS-tekknix
                            • sungod3kundefined
                              sungod3k
                              Great, that seems to work. Thanks
                                MoS-tekknix
                                @sungod3k:
                                You're welcome. That's what's a forum for đŸ˜‰
                                Regards
                                MoS-tekknix
                                • tychopundefined
                                  tychop
                                  @MoS-tekknix:
                                  @sungod3k:
                                  [[language]]
                                  Regards
                                  MoS-tekknix
                                  This script
                                  curl -F "file=@[output_filepath]" "http://192.168.x.x/rr_upload?name=gcodes/[output_filename].gcode"
                                  uploads the file correctly, but the print doesn't start…
                                  Am I missing something?
                                    You need to send a separate command to print the file.
                                    • tychopundefined
                                      tychop
                                      Yes, I figured that could be the issue, however, I couldn't find anything here https://github.com/chrishamm/DuetWebControl…
                                      Is there a command to print? Where can I look for it?
                                      I can see
                                      [[language]]
                                      function startUpload(type, files, fromCallback) {
                                      ```in the javascript, but am clueless how to specify 'print' as the type to upload gcode & start the print
                                        Use the rr_gcode command to send M32 "filename.gcode".
                                        • tychopundefined
                                          tychop
                                          Yep, Got it
                                          This works:
                                          curl -F "file=@[output_filepath]" "http://192.168.x.x/rr_upload?name=0%3A%2Fgcodes%2F[output_filename].gcode"
                                          curl "http://192.168.x.x/rr_gcode?gcode=M32 0%3A%2Fgcodes%2F[output_filename].gcode"
                                          Many thanks !!
                                            You will need to enclose the filename in double quotes when sending it if you want it to work on filenames with ( or ) or ; in the name.
