    Extruder motor stops during print…
    11.2k
    • ofloveandhateundefined
      ofloveandhate
      @dc42 my pronouns are she/her/hers, please
      here is the current default config.g from https://github.com/UltiBots/D300VS/blob/master/Firmware/171016-D300VS-1.19.2.zip. please confirm it contains the same error. i believe it does.
      ; Configuration file for UltiBots D300VS Delta 3D Printer
      ; version 1.0 for RepRapFirmware version 1.19.2
      ; Communication and general
      M111 S0                             	; Debug off
      M550 PD300VS				; Machine name and Netbios name (can be anything you like)
      M551 XXXXX				; Machine password (used for FTP)
      ; *** If you have more than one Duet on your network, they must all have different MAC addresses, so change the last digits
      M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xEF 	; MAC Address
      ; Wifi Networking
      ; M552 S1					; Enable Wifi by default
      M555 P2                           	; Set output to look like Marlin
      ; *** Uncomment if you have the optional PanelDue display
      ;M575 P1 B57600 S1			; Communication parameters for the PanelDue
      G21                                 	; Work in millimeters
      G90                                	; Send absolute positional coordinates...
      M83                                 	; ...but relative extruder moves
      ; Axis and motor configuration
      M569 P0 S0				; Drive 0 goes forwards (X tower)
      M569 P1 S0				; Drive 1 goes forwards (Y tower)
      M569 P2 S0				; Drive 2 goes forwards (Z tower)
      M569 P3 S1				; Drive 3 goes forwards (extruder 1)
      M574 X2 Y2 Z2 S1			; Set endstop configuration (all endstops at high end, active high)
      ; *** The homed height is deliberately set too high in the following - these will be adjusted with delta auto-calibration
      M665 R211.75 L360.31 B140 H445.00 X0.0 Y0.0 Z0.0	; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X0.0 Y0.0 Z0.0			; Endstop offset adjustments, these will be adjusted with delta auto-calibration
      M350 X64 Y64 Z64 E16 I1			; Set microstepping to 32 for X, Y and Z and 16 for extruder stepper with interpolation
      M92 X800 Y800 Z800			; Set axis steps/mm
      M906 X1000 Y1000 Z1000 E500		; Set motor currents (mA)
      M201 X1000 Y1000 Z1000 E1000		; Accelerations (mm/s^2)
      M203 X20000 Y20000 Z20000 E3600		; Maximum speeds (mm/min)
      M566 X1200 Y1200 Z1200 E300		; Maximum instant speed changes mm/minute
      M106 P1 T50 S255 H1			; Set hotend heatsink FAN1 thermostatic control at 50°C
      ; Thermistors
      M305 P0 T100000 B3950 R4700 L54 H-97	; Kapton bed heater thermistor
      M305 P1 R4700 T100000 B4725 C7.06e-8	; E3D V6 Semitec GT-104 thermistor cartridge
      ; Heater configuration
      M307 H0 B1							; Heater 0 (bed) use bang-bang control
      M307 H1 A512.9 C267.0 D9.0 B0		; Heater 1 (hot end) use PID
      ; Tool definitions
      M563 P0 D0 H1                       	; Define tool 0, the extruder
      G10 P0 S0 R0                        	; Set tool 0 operating and standby temperatures
      M92 E780	                       	; Set extruder steps per mm
      ; Z probe and compensation definition
      ; Change "H25" to "H3" AFTER commissioning your printer
      M558 P4 X0 Y0 Z0 H25 I1 		; FSRs with JohnSL board Z probe behaves as a switch and is not used for homing any axes
      G31 X0 Y0 Z-0.25 P500			; MUST READ: http://www.sublimelayers.com/2017/05/fdffsd.html
      T0					; Select tool 0, the hot end
      M501					; Load config-override.g
        ofloveandhate
        upping the temp by 25° to 210 still yielded a failure last night.
        a big lingering question i have – if my browser disconnects from the printer while printing, is the gcode console still guaranteed to log correctly? that is, how do i know that i am not experiencing some other error, and simply not seeing it in the log the next time i connect?
          A delta with 16-tooth pulleys, GT2 belts, 0.9deg motors and x16 microstepping (like mine usually is) has 200 steps/mm. So if you set x64 microstepping in M350 and use M92 after that, 800 steps/mm would be correct.
            ofloveandhate
            i have stock motors on my d300vs, so should be 0.9. let's double-check the extruder motor (PG35L Micro Extruder Motor)
              ofloveandhate
              see this d300vs forum post
              http://forum.ultibots.com/viewtopic.php?f=49&t=358&p=2075&hilit=microstepping#p2075
              for a brief discussion of the stepping modes.
              • whosrdaddyundefined
                whosrdaddy
                @ofloveandhate, can you share the STL of the object you want to print, just want to try printing it (but I don't have a delta :))
                  ofloveandhate
                  link is already above (extracted the link from the folder just now). it's in 3mf format.
                  http://danibrake.org/gcode/failing
                  i use simplify3d for the manually-placed supports. my same slicer settings work fine for the same model, printing on my taz6 and rostock max v2. i only have problems with my duet-powered machine.
                    ofloveandhate
                    two outstanding questions:
                    1. in M350 X64 Y64 Z64 E16 I1, does this enable interpolation for all axes, or just the extruder?
                    2. if my browser disconnects from the printer while printing (this happens all the time), is the gcode console in the web interface still guaranteed to log correctly? that is, how do i know that i am not experiencing some logged error, and simply not seeing it in the log the next time i connect because it was missed due to not being connected?
                      whosrdaddy
                      1. as David pointed out above, only the extruder will have interpolation
                      2. I don't think so (but I could be wrong). If I were you, I would enable event logging
                        -> add M929 P"eventlog.txt" S1 to your config.g, this way everything will be logged onto the SD card (and maybe the problem you are having 🙂 )
                        ofloveandhate
                        thanks
                        1. was that information in "The I1 parameter on the M350 command will work for the E drives because they are set to x16 microstepping."? because that's a compound statement, and i didn't want to assume. so, am i correct in understanding that interpolation applies to all extruders listed in the M350 command, but only if the stepping mode is 1/16? where is this documented? i am happy to refer to documentation.
                        2. i enabled logging to a file. is there a way to write the current date or time into the filename, to prevent overwriting the old ones, or can i make it append? does it append by default?
                          whosrdaddy
                          here is the documentation for M350:
                          https://duet3d.dozuki.com/Wiki/Gcode#Section_M350_Set_microstepping_mode
                          Excerpt from doc (emphasis mine) :
                          Parameters
                          Not all parameters need to be used, but at least ''one'' should be used. As with other commands, RepRapFirmware reports the current settings if no parameters are used.
                          Xnn Set stepping mode for the X axis
                          Ynn Set stepping mode for the Y axis
                          Znn Set stepping mode for the Z axis
                          Enn Set stepping mode for Extruder 0 (use Enn:nn:nn etc. for multiple extruders)
                          Inn Enable (nn=1) or disable (nn=0) microstep interpolation mode for the specified drivers, if they support it. The Duet WiFi and Duet Ethernet support interpolation (to x256 microstepping) only when configured for x16 microstepping.
                            whosrdaddy
                            Concerning the log file:
                            Date and time (if available) are logged and events are appended to this file.
                            I believe that the duet will get the correct time if you connect via a browser (I don't know about paneldue)
                            Its all explained in the documentation: https://duet3d.dozuki.com/Wiki/Gcode#Section_M929_Start_stop_event_logging_to_SD_card
                              ofloveandhate
                              thankyou
                                ofloveandhate
                                i re-ran my failing gcode (tobel60) with logging on. no information logged, despite a failure.
                                power up + 00:45:06 Event logging started
                                power up + 14:22:41 Finished printing file tobel_small_60_norobust.gcode, print time was 14h 20m
                                power up + 19:26:53 HTTP client 10.0.1.4 login succeeded
                                2018-02-28 08:34:28 Date and time set at power up + 19:26:53
                                this time, i printed with interpolation off, to see what would happen. no difference.
                                  Which firmware version are you using? Logging was introduced in firmware 1.19 and extended in firmware 1.20.
                                    ofloveandhate
                                      ofloveandhate
                                      what effect will changing this line have?
                                      M111 S0                             	; Debug off
                                      answer, kinda:
                                      M111 S1 P15
                                      Debugging enabled for modules:
                                      Debugging disabled for modules: Platform(0) Network(1) Webserver(2) GCodes(3) Move(4) Heat(5) DDA(6) Roland(7) Scanner(8) PrintMonitor(9) Storage(10) PortControl(11) DuetExpansion(12) FilamentSensors(13) WiFi(14)
                                        ofloveandhate
                                        the Aprinter firmware claims to work on a duet. see http://reprap.org/wiki/List_of_Firmware
                                        know anyone running it? this would be a good way for me to rule out a firmware bug.
                                        • Dougal1957undefined
                                          Dougal1957
                                          @ofloveandhate:
                                          Looking at that link and the online configurator from it it looks like only the 0.6 board is selectable so the wifi/ethernet boards are unlikely to run with it.
                                            I really don't think it is a firmware issue. Nobody else has reported a similar problem. So I think we are looking at one of the following:
                                            1. Trying to extrude with no tool selected, or with the heater not up to temperature. If this is the case, there will be error messages on the GCode Console page of DWC.
                                            2. Faulty stepper motor, or (more likely) a faulty cable or crimp connection at the end of the cable.
                                            3. Stepper driver overheating, due to a faulty stepper driver or running it at maximum current (2.4A) with inadequate cooling. If you are running firmware 1.20 or later then there would be an error message on the GCode Console page again.
                                            4. Faulty stepper driver chip, or faulty soldering of the stepper driver chip. To rule that out, try using the E1 motor output instead of the E0 output. But I think you already tried that.
                                            5. A good old fashioned hot end jam. Are you able to extrude immediately after cancelling the print? If you run the print with no filament in the extruder, does the motor continue turning right up to the end of the print?
                                            6. Bad GCode causing M906 or M913 being executed to reduce the motor current. Run M906 and M913 without parameters after the fault has occurred and check the reported values.
                                            HTH David
