    Extruder motor stops during print…
    10.9k
    • whosrdaddyundefined
      whosrdaddy
      1. as David pointed out above, only the extruder will have interpolation
      2. I don't think so (but I could be wrong). If I were you, I would enable event logging
        -> add M929 P"eventlog.txt" S1 to your config.g, this way everything will be logged onto the SD card (and maybe the problem you are having 🙂 )
      • ofloveandhateundefined
        ofloveandhate
        thanks
        1. was that information in "The I1 parameter on the M350 command will work for the E drives because they are set to x16 microstepping."? because that's a compound statement, and i didn't want to assume. so, am i correct in understanding that interpolation applies to all extruders listed in the M350 command, but only if the stepping mode is 1/16? where is this documented? i am happy to refer to documentation.
        2. i enabled logging to a file. is there a way to write the current date or time into the filename, to prevent overwriting the old ones, or can i make it append? does it append by default?
          whosrdaddy
          here is the documentation for M350:
          https://duet3d.dozuki.com/Wiki/Gcode#Section_M350_Set_microstepping_mode
          Excerpt from doc (emphasis mine) :
          Parameters
          Not all parameters need to be used, but at least ''one'' should be used. As with other commands, RepRapFirmware reports the current settings if no parameters are used.
          Xnn Set stepping mode for the X axis
          Ynn Set stepping mode for the Y axis
          Znn Set stepping mode for the Z axis
          Enn Set stepping mode for Extruder 0 (use Enn:nn:nn etc. for multiple extruders)
          Inn Enable (nn=1) or disable (nn=0) microstep interpolation mode for the specified drivers, if they support it. The Duet WiFi and Duet Ethernet support interpolation (to x256 microstepping) only when configured for x16 microstepping.
            whosrdaddy
            Concerning the log file:
            Date and time (if available) are logged and events are appended to this file.
            I believe that the duet will get the correct time if you connect via a browser (I don't know about paneldue)
            Its all explained in the documentation: https://duet3d.dozuki.com/Wiki/Gcode#Section_M929_Start_stop_event_logging_to_SD_card
              ofloveandhate
              thankyou
                ofloveandhate
                i re-ran my failing gcode (tobel60) with logging on. no information logged, despite a failure.
                power up + 00:45:06 Event logging started
                power up + 14:22:41 Finished printing file tobel_small_60_norobust.gcode, print time was 14h 20m
                power up + 19:26:53 HTTP client 10.0.1.4 login succeeded
                2018-02-28 08:34:28 Date and time set at power up + 19:26:53
                this time, i printed with interpolation off, to see what would happen. no difference.
                  Which firmware version are you using? Logging was introduced in firmware 1.19 and extended in firmware 1.20.
                    ofloveandhate
                      ofloveandhate
                      what effect will changing this line have?
                      M111 S0                             	; Debug off
                      answer, kinda:
                      M111 S1 P15
                      Debugging enabled for modules:
                      Debugging disabled for modules: Platform(0) Network(1) Webserver(2) GCodes(3) Move(4) Heat(5) DDA(6) Roland(7) Scanner(8) PrintMonitor(9) Storage(10) PortControl(11) DuetExpansion(12) FilamentSensors(13) WiFi(14)
                        ofloveandhate
                        the Aprinter firmware claims to work on a duet. see http://reprap.org/wiki/List_of_Firmware
                        know anyone running it? this would be a good way for me to rule out a firmware bug.
                        • Dougal1957undefined
                          Dougal1957
                          @ofloveandhate:
                          Looking at that link and the online configurator from it it looks like only the 0.6 board is selectable so the wifi/ethernet boards are unlikely to run with it.
                            I really don't think it is a firmware issue. Nobody else has reported a similar problem. So I think we are looking at one of the following:
                            1. Trying to extrude with no tool selected, or with the heater not up to temperature. If this is the case, there will be error messages on the GCode Console page of DWC.
                            2. Faulty stepper motor, or (more likely) a faulty cable or crimp connection at the end of the cable.
                            3. Stepper driver overheating, due to a faulty stepper driver or running it at maximum current (2.4A) with inadequate cooling. If you are running firmware 1.20 or later then there would be an error message on the GCode Console page again.
                            4. Faulty stepper driver chip, or faulty soldering of the stepper driver chip. To rule that out, try using the E1 motor output instead of the E0 output. But I think you already tried that.
                            5. A good old fashioned hot end jam. Are you able to extrude immediately after cancelling the print? If you run the print with no filament in the extruder, does the motor continue turning right up to the end of the print?
                            6. Bad GCode causing M906 or M913 being executed to reduce the motor current. Run M906 and M913 without parameters after the fault has occurred and check the reported values.
                            HTH David
                              ofloveandhate
                              thanks for the list.
                              1. no error messages, so not this
                              2. replaced stepper motor already. replaced cables from bottom of whip to board once. i could replace again, including the wires in the whip. it could be this
                              3. no error, same behaviour with two duet boards, same problems with a heat break and active cooling on the duet. not this.
                              4. same behaviour with two duet boards. same problem on E1. not this
                              5. no, i am not able to move it – the motor does not respond to requests to move. my gut tells me there might be something to explore here. i will also try generating a fail with an unloaded extruder.
                              6. seem likely? will do next fault, combined with #5.
                              7. firmware bug seem unlikely, but we are still unable to rule it out. lack of other reports points to not this, but something with my machine... let's continue to eliminate other causes.
                              thanks soooo much for your ongoing advice and help. i will solve this issue!!!
                                After the fault has occurred, if you try to extrude (with the hot end still at operating temperature) does the motor vibrate or make any noise at all?
                                Are you able to turn the motor shaft or extruder gear by hand, or is it locked?
                                Does M563 P0 report the correct exruder drive number?
                                What do you have to do to get extrusion working again?
                                Another M122 report immediately after the fault occurred may be useful.
                                  ofloveandhate
                                  logging from startup gives this:
                                  2018-02-28 21:27:52 Error: Can't open 0:/sys/oem.json to read, error code 4
                                  ```is that disconcerting?
                                    No, that message is normal. DWC tries to open oem.json but that file is only present in a special configuration used by one of our OEMs.
                                      ofloveandhate
                                      another failure, most of the way through tobel60, with interpolation off.
                                      the gcode console does not have a message about the finishing of printing.
                                      here are the outputs of some reports:
                                      M563 P0
                                      Tool 0 - drives: 0; heaters (active/standby temps): 1 (0.0/0.0); xmap: X; ymap: Y; fans: 0; status: selected
                                      M122
                                      Used output buffers: 4 of 32 (10 max)
                                      RepRapFirmware for Duet WiFi version 1.20 running on Duet WiFi 1.0
                                      Board ID: 08DDM-9FAM2-LW4SD-6JKD0-3SN6N-T2ZVY
                                      Static ram used: 15448
                                      Dynamic ram used: 99288
                                      Recycled dynamic ram: 4048
                                      Stack ram used: 1392 current, 8552 maximum
                                      Never used ram: 3736
                                      Last reset 21:25:40 ago, cause: power up
                                      Last software reset at 2018-02-28 21:32, reason: User, spinning module GCodes, available RAM 11880 bytes (slot 2)
                                      Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0441f000, BFAR 0xe000ed38, SP 0xffffffff
                                      Error status: 0
                                      Free file entries: 9
                                      SD card longest block write time: 2.8ms
                                      MCU temperature: min 29.7, current 43.3, max 60.7
                                      Supply voltage: min 23.8, current 24.3, max 24.9, under voltage events: 0, over voltage events: 0
                                      Driver 0: standstill, SG min/max 0/1023
                                      Driver 1: standstill, SG min/max 0/1023
                                      Driver 2: standstill, SG min/max 0/1023
                                      Driver 3: standstill, SG min/max 0/1023
                                      Date/time: 2018-03-02 09:19:22
                                      Slowest main loop (seconds): 0.077818; fastest: 0.000044
                                      MaxReps: 1440, StepErrors: 0, FreeDm: 240, MinFreeDm 120, MaxWait: 1957299979ms, Underruns: 7045, 3
                                      Bed compensation in use: none
                                      Heater 0 is on, I-accum = 0.0
                                      Heater 1 is on, I-accum = 0.6
                                      Segments left: 0
                                      Movement lock held by null
                                      http is idle in state(s) 0
                                      telnet is idle in state(s) 0
                                      file is idle in state(s) 0
                                      serial is idle in state(s) 0
                                      aux is idle in state(s) 0
                                      daemon is idle in state(s) 0
                                      queue is idle in state(s) 0
                                      Code queue is empty.
                                      Network state is running
                                      WiFi firmware version 1.20
                                      WiFi MAC address 2c:3a:e8:0b:20:8d
                                      WiFi Vcc 3.37, reset reason Turned on by main processor
                                      WiFi flash size 4194304, free heap 16656
                                      WiFi IP address 10.0.1.2
                                      WiFi signal strength -50dBm, reconnections 0, sleep mode modem
                                      HTTP sessions: 1 of 8
                                      Socket states: 2 0 0 0 0 0 0 0
                                      Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                                      M906
                                      Motor current (mA) - X:1000, Y:1000, Z:1000, E:400:400:400:400:400:400:400:400:400, idle factor 30%
                                      M913
                                      Motor current % of normal - X:100, Y:100, Z:100, E:100:100:100:100:100:100:100:100:100
                                      M350
                                      Microstepping - X:64, Y:64, Z:64, E:16:16(on):16:16:16:16:16:16:16
                                      M408 S4
                                      {"status":"I","coords":{"axesHomed":[0,0,0],"extr":[50225.4],"xyz":[0.000,0.000,430.673]},"currentTool":0,"params":{"atxPower":0,"fanPercent":[0.00,100.00,100.00,0.00,0.00,0.00,0.00,0.00,0.00],"speedFactor":100.00,"extrFactors":[100.00],"babystep":0.000},"sensors":{"probeValue":0,"fanRPM":0},"temps":{"bed":{"current":16.3,"active":0.0,"state":2,"heater":0},"current":[16.3,190.0,2000.0,2000.0,2000.0,2000.0,2000.0,2000.0],"state":[2,2,0,0,0,0,0,0],"heads":{"current":[190.0],"active":[190.0],"standby":[0.0],"state":[2]},"tools":{"active":[[190.0]],"standby":[[0.0]]},"extra":[{"name":"MCU","temp":44.0}]},"time":79008.0,"currentLayer":0,"currentLayerTime":0.0,"extrRaw":[50225.4],"fractionPrinted":0.0,"firstLayerDuration":0.0,"firstLayerHeight":0.50,"printDuration":0.0,"warmUpDuration":0.0,"timesLeft":{"file":0.0,"filament":0.0,"layer":0.0}}
                                      i am able to turn on the heater for the extruder. attempting to extrude yields very slow moves. i can feel the motor running, but it is barely turning. i swapped motors, and it did not solve the problem. i also removed the motor from the machine, and it still is barely moving when i extrude, so it was not physical binding causing the problem.
                                      i will leave the machine errored for a while, hoping that we can try some things together.
                                        Thanks. Please run M92 to check that the extruder steps/mm is still correct. Also M572 to check the pressure advance setting, and M201 and M203 to check the speed and acceleration settings.
                                        • Kezatundefined
                                          Kezat
                                          In the error state are you able to get the extruder to move faster if you manually send a G1 commands that includes a faster speed or will it only move at one really slow speed for any move command?
                                            ofloveandhate
                                            still in errored state:
                                            M92
                                            Steps/mm: X: 800.000, Y: 800.000, Z: 800.000, E: 700.000:700.000:700.000:700.000:700.000:700.000:700.000:700.000:700.000
                                            M572
                                            Extruder pressure advance: 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000, 0.000
                                            M201
                                            Accelerations: X: 1000.0, Y: 1000.0, Z: 1000.0, E: 1000.0:1000.0:1000.0:1000.0:1000.0:1000.0:1000.0:1000.0:1000.0
                                            M203
                                            Maximum feedrates: X: 20000.0, Y: 20000.0, Z: 8000.0, E: 20000.0:20000.0:20000.0:20000.0:20000.0:20000.0:20000.0:20000.0:20000.0
