    Layer and filament estimation not working
    2.0k
      Please share a gcode file that demonstrates the problem.
      • antoncheezundefined
        antoncheez
        http://bit.ly/2nPk5Mo here is a file that does as described
          antoncheez
          I have solved the problem. The .ngc file format needs to be a .gcode file format upon output. I just never thought this could be the issue. Thanks for your attention
            I'm glad you solved it. But I am curious: why did the file have a .ngc extension, when it appears to be a standard GCode file for 3D printers? I thought all the commonly used slicers generate files with a .g or .gcode extension.
              antoncheez
              the default profile in my sli3er config is .ngc because i started out with an absolutely ancient machinekit setup.
              • Barracuda72undefined
                Barracuda72
                Hi i Capture this Thread for a very similar problem.
                Updated to the actual rc2 version…and change the starting code of S3D so i´m not sure when the prob exactly started.
                I dont get a Layer time..for the DWC theres only one layer..a very long layer 😉
                I changed some lines in my starting code:
                G21 ;metric values
                G90 ;absolute positioning
                M82
                M107 ;start with the fan off
                G28 ;move to endstops
                G29 S1
                G92 E0 ;zero the extruded length
                G1 X-44 Y-75 Z0.2 E0.5 F7000 ; Drop to bed
                M117 Preparing...;Put message on LCD screen
                G1 X0 Y-90 E10 F500 ; Extrude 10mm of filament in a 4cm line
                G1 X44 Y-75 E12 F500 ; Extrude 12mm of filament in a 4cm line
                G92 E0 ; zero the extruded length
                G1 E-0.4 F500 ; Retract a little
                G1 X87 Y-17 Z1 F6000 ; Quickly wipe away from the filament line
                G1 Z5 ; Raise and begin printing.
                M117 Printing...;Put printing message on LCD screen
                guess before that layer time in DWC was ok..but how could that gcode prevent DWC to show correct layer time?
                  Try 1.21RC3 tomorrow when I release it, and if the problem is still there, make the gcode file available to me.
                    Barracuda72
                    made a Scrrenshot..print is already 1:45:00 in progress and still on first layer 😉 https://imgur.com/a/q3tmb of the DWC
                    and this happens with all prints so far
                      Barracuda72
                      ok..updated to RC3 but the problem is the same…only one big layer in the timer..
                        I can't do anything about this without a sample GCode file from you.
                          Barracuda72
                          will upload it later…have to test if its slicer specific
                            Barracuda72
                            ok..made a calibration cube..
                            1. with Cura 15.04
                            https://drive.google.com/file/d/15f5AtY0VROXYdu-Rqe2Fgv7t0LyyHXp-/view?usp=sharing
                            2. with Simplify3D
                            https://drive.google.com/file/d/17FLBhOeISPs6M6-l8X4HPyd2fQa3IvDW/view?usp=sharing
                            most settings are similar except in the S3D file the printer do that little wipe line before the print. Even tried to erase the 2nd G92E0
                            With the Cura file the layer informations are ok..he count each layer.
                            With the S3D file its only 1 long layer in the DWC…first layer 1. sec ( thats the prime/wipe line in my starting code)..2nd layer...endless
                            DWC after the S3D print: "Layer: 2 of 83, Filament Usage: 1598.2mm of 1601.2mm (3.0mm remaining)"
                            strange
                            hmm I should start doing LEGO bricks instead of Calibration Cube..so they are at least useful 😉
                              Barracuda72
                              Already had the spare time to look at the gCode files?
                              • tbahreundefined
                                tbahre
                                Having layer and estimation problems myself. I posted thinking it was a problem with Cura but I'm not so sure:
                                https://www.duet3d.com/forum/thread.php?pid=40787#p40787
                                Also: https://www.duet3d.com/forum/thread.php?pid=40843#p40843
                                • c310undefined
                                  c310
                                  i have similar issue.
                                  you can see that on the picture it shows 96 layers. however file had 6 layers or so.
                                  even looking at progress indicator of 50% and 2 layers printed it gives an idea that there is no 96 layers 🙂
                                  https://1drv.ms/u/s!AhtLyZEPcjv9gc48ed0BtcWa-GX5xQ link to gcode file
                                    Thanks, that's on my list to investigate before the 1.21 release.
                                      @c310:
                                      The reason it thinks you have 96 layers is that your print is only 0.8mm high but you have 15mm of Z hop configured. The large amount of Z hop is confusing the code that works out the total number of layers.
                                        @Barracuda72:
                                        1. with Cura 15.04
                                        2. with Simplify3D
                                        strange
                                        The problem is this line:
                                        The firmware treats it as a printing move because it contains both extrusion and XY movement. Z is very high at that point, which throws off the layer height computation. The workaround is to do the extrusion in a separate move.
                                        The reason that it worked in 1.20 is that in 1.21 the layer height code was changed to allow for slicers that use variable layer height.
