    Slic3r PE 'Send to printer'?
    36
    5.8k
    • AlexLinundefined
      AlexLin
      the PE version has a lot of improvements and has a higher development rate…so I would like to stick with that...but as said the perl script is an option i will investigate
      • bartolomeusundefined
        bartolomeus
        I thought so aswell, but Slic3r is actually updated regularly. Last update is from 26th feb.
        • AlexLinundefined
          AlexLin
          OK I found a solution. It is a bit of a hack where I use the ip address /url to determine whether to send it to an octopi or a duet
          my octopi has address octopi.local
          my duet has address hevo.local
          I needed to do this since the PE version doesn't have the member variables that the orginal slic3r has compiled in c++. And there is no host_type as in the code above. And I have no urge to compile it all ..
          it is a hack an I will need to change it for every new releae..however I'm so use with my octopi just to hit 'send to printer', that it is worth it for me.
          for windows you will need to change the file (1.39 as example)
          C:\Slic3r-1.39.1-beta1-prusa3d-win64-full-201802221543\Slic3r-1.39.1-beta1-prusa3d-win64-full-201802221543\lib\Slic3r\GUI\Plater.pm
          sub send_gcode at line 1459 to
          [[perl]]
          sub send_gcode {
              my ($self) = @_;
              $self->statusbar->StartBusy;
              my $ua = LWP::UserAgent->new;
              $ua->timeout(180);
              my $res;
               if($self->{config}->octoprint_host eq 'octopi.local'){
          		$res = $ua->post(
                  "http://" . $self->{config}->octoprint_host . "/api/files/local",
                  Content_Type => 'form-data',
                  'X-Api-Key' => $self->{config}->octoprint_apikey,
                  Content => [
                      file => [
                          # On Windows, the path has to be encoded in local code page for perl to be able to open it.
                          Slic3r::encode_path($self->{send_gcode_file}),
                          # Remove the UTF-8 flag from the perl string, so the LWP::UserAgent can insert
                          # the UTF-8 encoded string into the request as a byte stream.
                          Slic3r::path_to_filename_raw($self->{send_gcode_file})
                      print => $self->{send_gcode_file_print} ? 1 : 0,
          	else{
                   # slurp the file we would send into a string - should be someplace to reference this but could not find it?
                   local $/=undef;
                   open (my $gch,Slic3r::encode_path($self->{send_gcode_file}));
                   my $gcode=<$gch>;
                   close($gch);
                   # get the time string
                   my ($sec,$min,$hour,$mday,$mon,$year,$wday,$yday,$isdst) = localtime(time);
                   my $t = sprintf("%4d-%02d-%02dT%02d:%02d:%02d",$year+1900,$mon+1,$mday,$hour,$min,$sec);
                   my $req = HTTP::Request->new(POST => "http://" . $self->{config}->octoprint_host . "/rr_upload?name=0:/gcodes/" . basename(Slic3r::encode_path($self->{send_gcode_file})) . "&time=$t",);
                   $req->content( $gcode );
                   $res = $ua->request($req);
                   if ($res->is_success) {
                       if ($self->{send_gcode_file_print}) {
                           $res = $ua->get(
                               "http://" . $self->{config}->octoprint_host . "/rr_gcode?gcode=M32%20" . basename(Slic3r::encode_path($self->{send_gcode_file})),
              $self->statusbar->StopBusy;
                  $self->statusbar->SetStatusText("G-code file successfully uploaded to the OctoPrint server");
              } else {
                  my $message = "Error while uploading to the OctoPrint server: " . $res->status_line;
                  Slic3r::GUI::show_error($self, $message);
                  $self->statusbar->SetStatusText($message);
            I wonder if it would be possible to just do a pull request for Slic3r PE to take the Duet connectivity from the main Slic3r dev branch that already has it working.
            • AlexLinundefined
              AlexLin
              It seems prusa hasn't merged that code from slic3r. I checked the source code of 1.39 and didn't find the changes in PE
              • DADIYundefined
                DADIY
                @AlexLin:
                [[perl]]
                sub send_gcode {
                    my ($self) = @_;
                    $ua->timeout(180);
                    my $res;
                		$res = $ua->post(
                        Content => [
                            file => [
                	else{
                         local $/=undef;
                         my $gcode=<$gch>;
                         close($gch);
                                 $res = $ua->get(
                    } else {
                Thanks, that worked for me on 1.38.5.
                • AlexLinundefined
                  AlexLin
                  nice , somebody else can use it;-)
                  • darookeeundefined
                    darookee
                    @Phaedrux:
                    It looks like it is this commit https://github.com/alexrj/Slic3r/commit/1c74067da09a9a23ce66227b55146af6182d747d, it should be possible to pull it in and build your 'own' slic3r version, but I guess that these are not the only changes needed. 5fbb245b9790193b6924735fd985dc3cd2350ee6 and 13f121e3d952cca33b1ee5fdd73c12d85bf54d0e also mention the duet.
                    Edit: As I said before, I doubt that this would get accepted 😕
                    0 emaker committed to alexrj/Slic3r
                    Octoprint settings functionality expanded to allow upload to RepRapFi… (#4028)
                    * Octoprint settings functionality expanded to allow upload to RepRapFirmware on a Duet controller.
                    * octoprint_host renamed to print_host to enhance code readability.
                    Fixes #4022
                    • robmundefined
                      robm
                      @AlexLin:
                      Nice work, well done. (in lieu of a 'like' button for an individual post) 🙂
                      • mloidlundefined
                        mloidl
                        I don't think prusa will accept a pull request for this issue at the moment.
                        On github i found the following open issue https://github.com/prusa3d/Slic3r/issues/695, seems they will do some refactoring.
                        Today they committed a change which seems to be part of the refactoring.
                        https://github.com/prusa3d/Slic3r/commit/4a90ab1f6a1390df4ce332b342536ee61db6ebfd
                        cbusillo created this issue in prusa3d/Slic3r
                        closed Feature request: Duet Wifi connect #695
                        0 bubnikv committed to prusa3d/Slic3r
                        Merge branch 'octoprint'
                        • thehairundefined
                          thehair
                          We'll see if we get a response to the most recently opened issue on Github https://github.com/prusa3d/Slic3r/issues/935. I'm not too hopeful that the Prusa version will ever add in support for the Duet. I ended up making a post processing script that uploads the gcode file. The script is basically just the perl code that slic3r usually uses to upload files.
                          #!/usr/bin/perl -i
                          use strict;
                          use warnings;
                          use LWP::UserAgent;
                          use File::Slurp;
                          use File::Basename;
                          # Set up filepath and filename
                          my $filepath = $ARGV[0];
                          $filepath =~ tr|\\|/|;
                          my $filename = basename($filepath);
                          my $server_endpoint = "http://192.168.X.XX/rr_upload?name=gcodes/$filename&time=$t";
                          my $req = HTTP::Request->new(POST => $server_endpoint);
                          my $data_file = read_file( $filepath, { binmode => ':raw' } );
                          $req->content($data_file);
                          my $resp = $ua->request($req);
                          if ($resp->is_success) {
                              my $message = $resp->decoded_content;
                              print "Received reply: $message\n";
                          }else {
                              print "HTTP POST error code: ", $resp->code, "\n";
                              print "HTTP POST error message: ", $resp->message, "\n";
                          You'll have to put the address of your Duet where the "XXX" are in the $server_endpoint var. I run all my post processing scripts from a windows bat file which looks sort of like this at the end:
                          pause
                          perl "C:\Program Files\Slic3r\uploadgcodefile.pl" %1
                          del /f %1
                          pause
                          The bat file uploads the gcode file and then deletes it. The first pause allows me to close the command window to cancel the upload/delete command. The last pause allows me to verify the upload worked.
                          This process definitely isn't perfect, but is easier than manually uploading files.
                          Xphomegra created this issue in prusa3d/Slic3r
                          closed [Request] Add duet/reprapfirmware upload (From slic3r 1.3.0-dev) #935
                          • mloidlundefined
                            mloidl
                            I've added the option for sending G-Codes to Duet and already created a pull request for it (https://github.com/prusa3d/Slic3r/pull/1051)
                            Let's see if Prusa will overtake it into their repo.
                            If someone is interested in testing it can be cloned from https://github.com/mloidl/Slic3r/tree/duet
                            Best regards,
                            Martin
                            mloidl opened this pull request in prusa3d/Slic3r
                            closed Added possibility for upload to Duet #1051
                            Phaedruxundefined AlexLinundefined Mordekainundefined 3 Replies Last reply Reply Quote 3
                              Phaedrux Moderator @mloidl
                              @mloidl Great work, I hope they take it for the next release.
                              • AlexLinundefined
                                AlexLin @mloidl
                                @mloidl nice,well done!!
                                • Mordekainundefined
                                  Mordekain @mloidl
                                  @mloidl thanks for the work! great to see it was accepted!
                                  If it's not too much trouble, do you think you could post a release already built with the commit?
                                  mloidlundefined 1 Reply Last reply Reply Quote 0
                                  • mloidlundefined
                                    mloidl @Mordekain
                                    @mordekain I have not yet tried to build a release for another pc than mine. I'll try to create a linux appimage for testing. I'm not able to provide a windows or mac executable.
                                    On the other hand i assume prusa will release another beta or release candiate soon (current beta was released 19 days ago)
                                      Mordekain
                                      New release is up!
                                      https://github.com/prusa3d/Slic3r/releases/tag/version_1.41.0
                                      The new feature works wonderfully, thanks @mloidl !
                                      • mloidlundefined
                                        mloidl
                                        As already mentioned by @Mordekain, the latest Slic3r PE Release 1.41.0 contains the duet upload functionality.
                                        Unfortunately the timestamps for uploaded files are not set correctly. This has been fixed and is already submitted to the master branch, so it will be part of the next bug fix release.
                                          @mloidl great work. Can't wait to try it out. Thanks.
                                          • resamundefined
                                            resam
                                            @mloidl thanks for your work in the Duet integration!
                                            I'm running my Duet behind a reverse proxy with HTTP Basic Auth to add a (thin) layer of security.
                                            Any chance you can add auth credentials to Slic3r? No need for new UI fields, a simple https://username:password@my-fancy-printer.com/ would be sufficient.
                                            I'm not sure if the Slic3r HTTP library already supports this - looks like a custom (bare-bones) implementation based on curl?
